3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Laser Image Projector
Step 2Create the Base
Create the Base
In this method, I'm using a long plank of wood about 90cm long, 15cm wide, and 1cm thick. You pretty much mount it on any long piece of stiff material.
Note: the length will determine how much you can distance the first lens from the slide to allow the 'dot' to expand enough to cover the slide area.
Stiffness is essential. For alignment of the laser is often difficult - unnecessary flex will throw the alignment out too easily.
If using rail, rule a straight line up the centre of the plank, and mount the rail dead centre. You may need to cut the rail in order to fit it on the plank.
If not using a rail, create a centre line very accurately! Any holes drilled must also be very much in line.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
6
Author:echo_anomie
