For more similar projects, kits for this and other gadgets, and much more just go to Ocalon Electronics. If your having any problems with getting the circuit to work, or just general Q&A questions feel free to leave them here.
Remove these ads by
Signing UpStep 1Materials/Supplies
1. A single 1000uF Capacitor
2. A 5K Trimpot (larger values will work)
3. CdS Photocell (Cadmium Sulfide Cell)
4. Some Perforated Board
5. A 9v battery and clip
6. The 2N3904 Transistor
7. Several Small mirrors
8. About 5-12VDC Piezo Siren (102dB)
9. Any General Laser (650nm 5mw)
Optional:
8. An L7805 5v Regulator
9. The Project Case
10. A 5 - 9 volt Adapter
I think I may try using just one really big cap, instead of an array. Maybe that will eliminate the delay.
i'll try this too..
given this, i would see the photocell needing to add large amounts of resistance whenever it has light in order to bring down the voltage (so the alarm doesn't trigger) and have less resistance when things go black (in order to trigger and set off the alarm). this is a fair assumption yes?
my photocells gain resistance w/out light and have little resistance with light.. which is the inverse of what we want in order for this to work is it not? am i reading this wrong? did i buy the wrong types of photocells? .. i'm very very confused.. somewhere this logic has gone inverse on me. :)
When the photocell has light on it (low resistance), the the flow wants to go through it to ground instead of through the transistor to ground.
When the light is off, the photocell has high resistance and it's easier for the flow to get to ground through the transistor, which then switches it on and sounds the buzzer. :)
| = Pin
- = space between pins
