3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Laser Pointer Amplifier
        Everybody would like a laser pointer that can burn through stuff. The problem is that lasers like this are very expensive. My prototype may or may not be able to achieve that but if you invested enough money into it, achieving brag-worthy lasers is definitely possible.
        My laser amplifier prototype design can make lasers brighter and stronger and is certainly a fun project to build. Nobody can deny that amplifying a laser is amazingly cool. Plus with this type of project you can always invest more money and time in it to tweak out the glitches to make it better and better. Laser projects are very facinating and tend to spark new and better laser project ideas.
        WARNING: I am not responsible for any damage caused by this device. Lasers can damage the eyes and possibly cause permanent blindness so always keeep laser away from face and wear proper eye protection.
Step 1Gathering the Parts
Gathering the Parts
       You will need several parts and tools for this project.
PARTS: plywood, nails or screws, mirrors, metal or wood dowels, laser pointer, lasing medium(look it up online if you don't know what  I'm talking about, crystal or glass mediums work best), a couple rubber bands, 4 brad nails, and a short string of white Christmas lights.
 TOOLS: glass cutter, hot glue gun, drill, pliers, masking tape or stapler, pencil, saw, wood glue, and a ruler.
11 comments
Jan 8, 2012. 8:50 AMLaserDave says:
Nice effort with your project. My only comment would be that the title should be changed so that people won't go through the time and expense building such a device when it has absolutely no chance of doing what is claimed.
I understand that you wanted to put this together to compete in a contest and that you were pressed for time, but that doesn't make it work nor does it make it fair for people expecting it to. Perhaps a more accurate title might be "Laser Pointer Amplifier Simulation Concept", since the output power will most certainly be less than you put in.
It's good to see you are interested in lasers and I encourage learning all you can about them. Maybe a good demo might be to dissect a small green laser, mount all of the components on a board and get that to lase. I think you'd be surprised at how precise the alignment must be for it to work, but it might well be worth the exercise. Use a camera/monitor arrangement to see the invisible IR energy to do your alignment, and don't forget to use goggles.
May 15, 2011. 9:25 AMspikec says:
Dude I commend you for your efforts and that's a cool looking box you got there, but you cannot just "add" energy from the christmas lights to the laser beam. Tiny incandescent bulbs are a far cry from the flash lamp setup at the National Ignition facility...
Here's a primer on coherence that explains the science behind it:
http://en.wikipedia.org/wiki/Coherent_light
You can build a cheap laser burner out a dvd or cd burner diode, which can be setup to output far more wattage than your typical off the shelf laser pointer. There are plenty of stuff out there on how to do it both here and on LPF...
Also, here's an instructable that will help you make some suitable mirrors for your laser work:
http://www.instructables.com/id/DIY-front-surface-mirror.-1/
Apr 25, 2011. 8:33 PMSolion says:
I am afraid that the physical properties of light do not work like this. while you can collimate a laser into a smaller spot for high concentration of energy over the area of that spot, adding reflectors in a lit box will not amplify anything . in fact you will loose some energy in each bounce because of refraction. your mirrors are not first surface types.
Now had you taken a green laser .......
May 6, 2011. 10:51 AMhivoltage says:
building a flash lamp lasing cavity to pump a solid state laser and bouncing a laser pointer through a box full of Christmas lights are entirely different things. any light from the bulbs inside the box will not be coherent and will not able to amplify the laser since it is not in phase. lasing mediums work by creating a population inversion and allowing light already resonating in the cavity to trigger the release of further energy by the excited atoms, allowing all the added light to be in phase. plain glass is not a workable lasing medium because it doesn't have the right properties to allow a population inversion to occur, and light bulbs are nowhere near powerful enough to pump any kind of lasing medium.
Apr 19, 2011. 12:59 AMmakincoolstuff says:
i think a couple neon lights or noble gas lights would make it really powerful
Apr 19, 2011. 6:09 AMruss_hensel says:
Have you measured the power gain? Or estimated it?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:amazingly awesome instructions
