For this project I used:
Xylol
Plywood or 2x6
Masking Tape
Rubber Gloves
Color laser prints.
Paper Towel.
Remove these ads by
Signing Up
Remove these ads by
Signing Up
PDF Downloads
As a Pro member, you will gain access to download any Instructable in the PDF format.
You also have the ability to customize your PDF download.
That means you can do this on any porous surface, but don't try it on metal or most plastics (plastics would dissolve anyway...)
Rock on!
And since toner melts down with heat, you could try transferring using an iron,
using a normal laser black /white print.
Also I dont think xylol is nice to your lungs! :-)
Cheers
http://faz-voce-mesmo.blogspot.pt/2012/06/seemecnc-e-instructables.html
it is mainly used for painting and illustrating.
