Laser Shooting Game
55,113
356
44
Published
Introduction: Laser Shooting Game
This laser game is a simple project that utilizes an Arduino mini. All target boards have an Arduino, sensors, and servo control ports. Shooting the target center triggers the servo and the board falls flat.
Step 1: Step 1:What You Need
Bill of material:
1. Shooting Target board PCB (attached gerber file)
2. Servo
3. Photo diode x 3
4. IR transmitter x 1
5. IR receiver x 1
6. 9014 NPN transistors x 3\
7. Pins and socket
8. Arduino Mini x 2
9. SMD components (Caps, resistors)
10. CD
11. Target board graphic (CD size)
12. Toy laser gun
Step 2: Step 2: Soldering
Assembly all components on the PCB.
Step 3: Step 3: Prepare the Target Board
Cut out the and stick it on the CD by glue
The diameter of the CD is 120 mm and the inner diameter is 15 mm.
Step 4: Step 4: Glue the PCB on Servo Arm
Use the hot glue gun to glue the assembled PCB on the servo arm.
Please reserved some space between the servo and the PCB. As the servo chassis may collide with the PCB during servo arm moment.
Step 5: Step 5: Stick the Target Board on the PCB
Use hot glue gun to glue the CD (target board) on PCB
Step 6: Step 6: Tidy Up the Cable
Connect the servo with the PCB.
Shorten the servo cable or tide the cable with string.
Please reserved some cable length for servo movement.
Step 7: Step 7: Upload the Firmware
1. Install the IR remote library and complie the arduino program
2. Upload the firmware to Arduino mini
Step 8: Step 8: Modify the Laser Gun
1. Open the laser gun
2. Cut out the PCB
3. Replace the PCB with Arduino Mini
4. Solder the power wire to Vin and GND
5. Solder the laser diode wire to Pin 3 and GND
6. Solder the sound trigger wire to Pin 13
7. Download the firmware to arduino mini
Step 9: Final Step: Make More Target Boards and Enjoy the Game
Kit Contest
Second Prize in the
Kit Contest
    • Oil Contest
      Oil Contest
    • Creative Misuse Contest
    • Clocks Contest
      Clocks Contest
    44 Discussions
    where did you get the toy gun with the built-in laser from? I can only find IR solutions and I guess they won't work
    bsg68
    2 years ago
    Would the arduino uno work too?
    yes, it works on Arduino UNO too
    bsg68
    3 years ago
    How much did all the materials cost
    Around USD$25 ~ $30, but its relatively cheap in China region.
    Depends on how you source materials.
    Arduino and Servo are the most expensive stuff in the BOM.
    thanks for adding the updated schematic,,,, but i will be happy if you explain to me the function of the transistor and IR transmitter and receiver, an why did you use it instead of connecting the photodiodes on analog pins and using ADC functions you can know if the led is on the photodiode or not ? (btw i read all the comments but i still miss this point)
    In this project, the main challenge is the environment light.
    There are two possible light that make the target board false trigger or not function well.
    1. Background light - it made the sensor output signal saturate and Arduino cannot receive significant signal and trigger the servo.
    2. unexpected flash light - it give significant signal and it cause false trigger.
    I found out TV remote did a good job on these problems and give reliable control / response. It gave me the solution of IR remote coding method.
    However, IR transmitter usually give a wide angle of transmission. You can consider it is broadcasting the code. But I need a narrow angle or single point transmission to give gun shooting experience for the player. This is the reason why I choose laser instead of IR transmitter.
    IR receiver has DC filter, AGC (Automatic Gain control) amplifier and stable digital output. It save me a lot of analog to digital components / design effort. However, the IR receiver does not response to RED laser signal. that is the reason why I need to use photo-diode to convert laser to IR transmitter.
    In order to increase the sensor region, I choose to use multiple photo-diode to receive the signal. Those transistors act as the driver to deliver receive signal for IR transmitter.
    I hope you can understand the circuit seem stupid and using "Laser --> photo-diode --> IR transmitter --> IR receiver --> Arduino". But it is worth to add 2 common components and save lots of time in avoiding complex coding / circuit.
    It's very interesting the "optical coupler" solution you adopted into the receiver circuit. Do you think possible to replace the 3 photo-diodes with a solar cell in order to obtain a larger target surface?
    yes, it is possible to use solar cell to replace the photo diode and I think it probably work without any circuit change on circuit.
    However, there are 2 concern while using solar cell as sensor.
    1. The solar cell output may saturated when too much light shine on cell. And too weak signal deliver to circuit.
    2. The solar cell may not sensitive to laser beam signal.
    If you tested solar cell work well in this design, please kindly leave us the comment or video.
    This is some great toy to play with :) Great Job.
    Do you maybe have some component codes for the Photo diodes, the IR transmitter and the IR reciever?
    With friendly greetings,
    Ashwin Zondag
    Hey folks i have made an uglier version of the same :) Instead of light sensor employed an LDR..check it out
    Its looks crude as it was made in couple of hours..plz suggest improvements that i can employ
    http://www.ebay.com/itm/laser-pistol-set-electronic-target-shooting-gun-safe-Dartboard-game-IR-rifle-/251413551424?pt=Model_Kit_US&hash=item3a896a5940
    So if I wanted to make something like GhostBlasters (http://sallycorp.com/dark-rides/interactive/ghostblasters/) or (http://youtu.be/jCPYlzXxpDA), how would I make it recognize when I hit something and relay that back to a main arduino running in the car?
    I think there is a computer link up all sensors, guns and score boards on each car. When specific gun hit the sensor, computer recognized the gun signal and score at specific car.
    is there any way you could post an ible showing how to do it w/ an arduino due or uno.........would be a great help thanks:)
