3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Laser Starfinder
Laser Starfinder
I've always been interested in astronomy, and often thought I'd like to get a telescope.  Last year was the International Year of Astronomy, marking the 400th anniversary since Galileo first pointed a telescope at the heavens, and learned that there was so much more to discover there.  There were a lot of astronomy related events going on, and it spurred me to delve into the subject again.
By fortunate happenstance, I managed to acquire a somewhat dirty and disused, but quite serviceable 10" newtonian telescope.  Since then I've had great fun finding nebulae, examining planets, and gazing in awe at the detail that can be seen on the moon.
I've had some trouble finding things though.  Using a finder scope (the small telescope mounted on the side of your larger one) is a big pain in the rear.  At one of the monthly star parties hosted by our local astronomical society I saw that someone had a green laser mounted to the side of his telescope in place of a finder scope.  It was amazing!  He didn't have to mess around with anything, he just turned on the laser, pointed it where he wanted to look, and there it was!
I of course thought to myself, "I can make one of those!"  So here I'll show you how you can as well, and save a few bucks off the cost of buying one of them new.  This is a very simple and cheap fix that will definitely make amateur astronomy a lot more fun!
If you should decide to make one of these yourself, make sure to post a picture in the comments section below, and I'll send you a digital patch!
Step 1Supplies
For this project you'll need:
  • a cheap green laser (less than 10 bucks at dealextreme.com)
  • some stiff speaker wire
  • a 2xAA battery holder
  • a flashlight type clicky switch (pack of five for less than 2 bucks at dealextreme)
  • some sugru
  • a strap or some electrical tape
  • something to mount it all on.
For the "Something to mount it all on," you can use pretty much anything that is straight, relatively stiff, has two level sides, and is about 6-8 inches long.  No innuendo intended.  The idea is that if you place something along these lines on the side of a telescope, it will naturally center and straighten itself along the telescope tube.  My original plan was to saw a piece of 1 1/4" PVC pipe in half, but I found this plastic case lid in my stuff drawers, and figured since it was already level and had a flat top it would probably work better.  All I had to do was slice off the ends!
As to tools, you'll need:
  • a dremel
  • soldering iron
  • a hot glue gun
  • a pair of pliers
  • a small flat head screwdriver
  • a ruler
Finally, you'll want to have some strong epoxy on hand, and some sugru to cover everything up.
11 comments
Jun 1, 2011. 7:43 AMtinker234 says:
wow cool
Oct 9, 2010. 4:19 PMhottroc says:
I don't quite get this? It's a great idea for improving your telescope but.....Seems like you have just taken apart a laser pointer you had to buy then reassembled it exactly the same but in a less neat/compact format. Have I missed something here? Would be more useful if you had started from more basic components perhaps.
Oct 11, 2010. 11:03 AMcefn says:
Wow I'd never heard of this before, but I've always been fascinated by the way a laser goes off forever into space and wanted to do something with it. Just using the parallax to help your perception of stars is genius.
Don't annoy the little green men too much.
Oct 11, 2010. 12:02 PMcefn says:
'Tis done. Crazy to vote against myself but I need new insights like this once in a while. Also I've been collecting high-powered lasers for no visible reason for some time, and I should damn well do something with them.
Oct 11, 2010. 1:38 PMcefn says:
You can vote for yourself. Yuk, I feel dirty. But I did it anyway. Thanks for the advice.
I just got featured! Had to tell someone who'd know what it means to me. My family and colleagues will just look at me blankly. I was almost hoping I wouldn't get featured, as it makes me think I'll have to do something even bigger and better next time to make the grade - maybe no bad thing.
Out of interest do you have access to a laser cutter? Do you know who I should recommend to people stateside?
I got lucky and found someone in the next village (Suffolk, UK) who has one and isn't too busy so I get a pretty good service - same day often.
The first proto of the tacticalendar I went through Ponoko UK which was a truckload of cash and they took more than three weeks! Can't speak for the other Ponoko making centres around the world though.
Sep 20, 2010. 6:04 AMfungus amungus says:
It's cool, but there's no LED here.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
306
Author:depotdevoid(depotdevoid on Facebook!)
Like me on Facebook, my poor, fragile ego needs a boost! I post updates about my current projects, and the occasional sneak peak at upcoming instructables! ...
more »
