3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Laser Surveillance System for under $20
Step 7Give it a Try - Taking it further
Listen for voices. You should be able to hear the low frequencies of any conversation inside the room of the targeted window. If you cannot hear anything, try banging on the window! That should produce a VERY loud sound from the amp.
If you get this project to work, the worst thing you could do is stop there! Try to build on the project. Try more than one laser, or getting more distance, or whatever comes to mind. One thing I have done to extend the project is to send music over the laser beam, and even sending two channels of music using two lasers polarized at right-angles to one another.
Feel free to leave some comments.
Happy experimenting!
14 comments
Jan 5, 2012. 11:14 AMHevnsDevl says:
I've made basically the same device, only with a crude amplifier (transistor circuit) and headphones instead of the pre-amp; but I keep on hearing feedback although I can clearly hear when the laser shines on the phototransistor. Even while someone is knocking on the glass I still only hear feedback, could it be that I'm saturating the transistor (I've only done this at a range of about 10m) ?
Mar 25, 2010. 3:28 PMDjdavies83 says:
sending 2ch stereo over laser using polarized beams is interesting, the cheap plastic "REAL-D" 3d glasses you get from cinemas for about 75p ($1) would be a start.
 what about the receiver? a kinda 2way mirror at 45D to split the beam in two then use two phototransistors?
Sep 22, 2006. 2:19 AMmunzer says:
Would one be able to do the same, but in reverse? Could a signal or vibration be sent to the window by the lazer? Could a signal be strong enough to vibrate the window?
Jan 25, 2009. 6:43 PMcurecreator says:
This link isn't direct laser communication but it is a way to transmit data through laser beams (especially sound)
http://www.metacafe.com/watch/2225704/make_a_simple_laser_communicator/
It has only been tested by transmitting sound but other encoded data should work to.
Also this actually is direct communication except it is transmitting data in area of affected particles that cannot be heard (the electromagnetic spectrum)
Aug 29, 2007. 10:45 AM_soapy_ says:
No chance. Thermal shock from that much laser would shatter the glass long before any noticeable vibration was set up.
Feb 11, 2010. 4:22 AMbeehard44 says:
Which is cooler...
stick C4 in any object, light it and it will instantly be cooler.
Aug 9, 2007. 2:40 PMCapricorn.san says:
whilst you cannot rely on the photon momentum to generate vibrations, with a powerful enough laser, one could generate localized heating in certain areas to generate thermal differentials that vary with time. These differentials could generate enough stresses to cause the glass to vibrate. It does however rely on the thermal properties of the medium you want to vibrate and the power of the laser. and you have to have some nicely coordinated movement of the laser to create this thermal wave.
May 20, 2008. 5:55 PMHuggyBear says:
My only concern would be the light that is not reflected by the window. Like others have said, there would be a giant dot where ever the laser was pointed. An IR laser would probably work but setting up the system would be extremely difficult (you have to aim it correctly even though you cant see it). Other than these dilemmas which I dont blame you for, your construction is awesome. Something I most definitely have to try when I come across a laser pointer.
May 1, 2007. 11:01 AMfreewheeler says:
cool,the only disadvantage is that it will not work on frosted glass,as the relected beam will be too weak to reach you.
May 29, 2007. 4:47 PM_soapy_ says:
That makes no sense. You are getting the reflection from the outside face of the glass. What is more likely is that your target will notice a huge red splodge on his frosted white window, and guess something is up!
Jun 5, 2007. 12:32 AMfreewheeler says:
yeah,i suppose you are right... ;-(......................unless the frosted side faces you,as it will get reflected in all sorts of directions
Jun 7, 2007. 2:00 PMJames (pseudo-geek) says:
um......DUH use an IR laser!
Jun 8, 2007. 8:06 AMfreewheeler says:
ferfect,as my math teacher used to say.
Jun 7, 2007. 2:01 PMJames (pseudo-geek) says:
oops.....it would appear that htis topic has already been discussed....IR disperses too fast. maybe UV??
Jul 23, 2007. 9:13 AMgallamine says:
Where'd you get this info? IR doesn't disperse in air, in fact, almost all freespace laser comm. is done using IR lasers. You can get UV lasers BTW - well, not in any accessible form.
Jul 25, 2007. 7:55 AMgallamine says:
Yeah, i was trying to find a good source, but most are technical papers. The Wikipedia page on FSO is pretty good - http://en.wikipedia.org/wiki/Free_Space_Optics
Also, think about IrDA and your tv remote - those are "near infrared" though.
I think a lot of FSO is in "far infrared", like 1500 - 1800 nm.
Jul 25, 2007. 2:07 AMJames (pseudo-geek) says:
oh. I jsut heard somewhere else on instructables that it does. probably wrong
Mar 22, 2007. 3:48 PMtrackzero says:
Oh, forget the surveillance system, then...where's the instructable for this window melting laser you mentioned? :)
Nov 5, 2006. 6:56 AMnrdesign says:
well done instructable! i'll try this out!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
15
Author:navaburo
I am a student and hobbiest. I'm into physics, linguistics, sailing, electronics, hacking (not cracking), music, and the like. I post most of my project stuff on my blog: http://hotwigati.wordpress...
more »
