"What's in the box?"
"Pain." He felt increased tingling in his hand, pressed his lips tightly together. How could this be a test? he wondered. The tingling became an itch... The itch became the faintest burning... It mounted slowly: heat upon heat upon heat... . The burning! The burning! He thought he could feel skin curling black on that agonized hand, the flesh crisping and dropping away until only charred bones remained.
This excerpt from Dune exactly describes the feeling of getting a tattoo burned into skin using a laser cutter; however, this is just the feeling. When sight, smell, and sound are added, the process turns out to be quite an experience.
The sound by itself (meaning no body parts in the cutter), is probably the easiest thing to deal with. It is just the normal whine of gears, belts and cooling fans. When that sound is mixed in with the sensation of burning flesh, it turns the laser cutter from a simple machine shop tool to a futuristic torture device.
The sight is not too bad, just a light tracing its way back and fourth across the body. As long as you don't think about the fact that the small wisp of smoke trailing the light, is actually vaporized skin, everything will be fine.
The smell is bad. It does not travel far, but when you catch a whiff of the burnt flesh stench, it is quite nauseating. The thought that you have just inhaled some of those vaporized skin flakes, and they have settled on the bottom of your lungs, is the worst.
I am leaving a disclaimer out of this, because any person with access to a laser cutter who is dumb enough to try this, deserves what they get.
Step 1: Ingredients
1. Laser Cutter
2. High Tolerance for Pain
3. Aloe
1-40 of 509Next »
Plo Koon says: Nov 27, 2012. 1:28 PM
why? WHY!?!?
Plo Koon says: Nov 27, 2012. 1:27 PM
u must want that little robot REALLY BAD.
ap0kal1ps3 says: Sep 14, 2012. 1:48 PM
You should probably not put anything on it to heal except for a bandage. This is because unlike a tattoo, you are trying to cause a scar. The aloe or polysporin or vitamin E ointments prevent scarring. I would also like to add that you should begin this process by disinfecting the area that you are lasing with dettol or 99% isopropanol. If you do use anything to soothe the area afterwards, make it vaseline or lotion. I'd recommend vaseline for your purposes, as it will soothe the burn without preventing scarring.
The Cartographer says: Mar 29, 2012. 3:33 PM
You sirs are amazing.
vincentstockdale says: Jan 8, 2012. 3:52 PM
couldnt you put the cream or whatever on your body first and then do this i think it will be the same result with less pain
twisted_clown_23 says: Dec 28, 2011. 9:08 PM
my question is how permanent is this? i don't want to do it if it don't last like a regular tattoo
steambag says: Dec 8, 2011. 12:28 PM
SAFE, CLEAN, RAPID.
zapper067 says: Aug 12, 2011. 6:31 AM
this is dangerous and is not very suitalbe as a instructable.People may hurt themselves with this
ZokiS says: Jul 1, 2011. 9:59 AM
Awesome! This is really hardcore stuff, would do it myself too if I had a laser cutter!
The Metal One says: Jun 22, 2011. 2:15 PM
interesting way to "ink" yourself but how long will the tattoo last?
mary candy says: Jun 19, 2011. 3:36 PM
really sick.
Sorry.
SenKat says: Jan 9, 2011. 9:10 AM
I could only stomach the first page of comments before I had to say something - now PLEASE keep in mind that I think art is awesome, and I am incredibly jealous of artists, with so much talent I could never have ! I am also against ME getting a tatoo - but what I am also against is children running hazardous machinery, scaring themselves, then publishing it on the internet for others to go Ooooooo and Aaaaahhhhhh over. NUTS ! Seriously, I always thought my mother was kidding when she said, "If one of your friends jumped off a tall building, would you do it too ?" Or maybe it was a bridge....anywho - I always thought SHE was insane for saying that, until I run across videos like this one. wow. you are cool. NOT. Anyways, I REALLY hope that since there are so many encouracging remarks, that instructables lets contrasting viewpoints stay published, because SOMEONE needs to tell these idots that what they are doing is stupid, and wrong. If not, maybe I'll be banned for not being positive and courteous. Very well - it is IMPOSSIBLE to be positive and courteous about a child scarring himself with a laser cutter - what's next, slicing off forefingers for fun with a sawzall ?
SenseiTG says: May 13, 2011. 7:08 AM
At first, I was about to point out that your view seems a bit old fashioned, but then I remembered that people have been marking their bodies in various ways since the beginning of time. Branding, tatooing, cutting, piercing is not something new - it's age old. Do you view all kinds of body marking in the same restrictive manner?
Being ignorant does not mean others are too, these guys may very well know exactly what they are doing - though I kind of doubt it, so in a sense I agree with you about the being idiots part, although i'd probably use the words "a bit stupid".
In any case it's not your place to tell people what they should or should not do, although I share your concern about doing potentially dangerous things without knowing what you are getting into. Taking risks though, is part of living a fulfilling life. Mostly it works out, sometimes things go wrong. This can be said about alot of things - even something as simple as crossing the street or driving a car is associated with a calculated risk you decide to take.
I am interested in trying this even though I'm not a huge fan of tattoos but I chose to consult with a dermatologist first and found that the CO2 lasers used in these machines are often 10.600nm infrared light - exactly the same frequency used in surgical laser knives. They have no known side effects and as such, this method of branding is very safe aside from whats blatantly obvious - pain, risk of infection, etc. Actually, it may very well be one of the safest methods of marking your body "available" to date.
SenKat says: May 16, 2011. 4:08 PM
Yeah, I sitll stand by my comments. You really should actually READ them, too before replying, I think. But then again I guess THAT is the hazardous part of all of this, unbeknownst to others. And THAT is as nice as I can be towards your entire comment, so I'll leave it at that ! Have a great one.
SenseiTG says: May 17, 2011. 12:19 AM
Actually I have READ it. Several times now. Obviously you feel I missed something? I meant no offence, but it seems some was taken. Sorry about that. English is not my native language, perhaps I used words stronger than intended.
I do however feel it is not very constructive to call people idiots and I'd say that's a danger - if you have something important to say, this is not the way to get it through except to people who already feel as you do.
Also we obviously have differing opinions about what a child is. I see a young man taking risks, which according to me is an integral part of growing up. I've never enjoyed overly protective environments as they tend to hinder personal development, again - imho.
TheAdamKramer says: Jul 4, 2008. 9:26 PM
Some of the comments over on Engadget said stuff about cancer....is that possible from this? And will the etching last forever, or is it a short term display?
Andyman_perth says: Jul 6, 2008. 1:46 AM
Hi Krammer, I work with these machines and I would say 'very probably not'. The laser is a CO2 laser. That means mid infra-red so there is no UV. I think some people are thinking that it might be 'altering' the skin like sunburn. Its not, its burning the top layers of skin away. Thermal process. Its the same as branding with irons
xenobiologista says: Jul 7, 2008. 5:12 PM
Er...branding with irons goes a lot deeper, from what I understand. It's a full-thickness burn.
Andyman_perth says: Jul 8, 2008. 7:46 AM
Actually this process does go that deep. I will post a pic of mine if I get around to it. On mine I have actually cut back several layers of skin. It might not scar, it looks too neat! Got a nice square edge to it.
cmcgee-1 says: Apr 15, 2011. 12:43 AM
What?! You cut your skin? Seriously?
TheAdamKramer says: Jul 6, 2008. 8:37 AM
awesome! thanks for the info!
Wehrdo says: Mar 29, 2011. 8:12 PM
This has gotta be the most insane Instructable I've seen yet. How do they look two and a half years later? Are they still visible?
khsora says: Mar 29, 2011. 4:39 PM
why the hell would you burn yourself and risk cancer for a tattoo you can hardly see?
skimmo says: Jan 30, 2011. 10:27 PM
thats pure madness
agemma says: Apr 19, 2010. 9:52 AM
Pshh try tattooing with an arc welder then come talk to me
Skwaab says: Dec 31, 2010. 8:25 AM
Your comment made my day.
hintss says: Nov 28, 2010. 4:29 PM
is skin conductive enough for that?
IT_Daniher says: Dec 28, 2010. 7:38 AM
Yes, skin is conductive enough.
I'd advise against it, unless you'd like to look like this:
http://itdnhr.com/static/itdnhr-2007.jpg.
Plasma cutter accident. Lost a good chunk of my left hand.
everywhere says: Jan 1, 2009. 9:16 AM
it looks like fun. i want a think geek logo on my hand
hintss says: Nov 28, 2010. 4:40 PM
whats wrong with the hacker logo?
HaD skull and crossbones?
picture of the laser cutter?
some random xkcd characters?
everywhere says: Dec 25, 2010. 7:36 PM
i didnt know about those sites when i posted that a year ago but the HaD logo would be awsome
hintss says: Dec 25, 2010. 10:27 PM
you should totally do a picture of a laser cutter
snazzyjazzy says: Dec 23, 2010. 8:08 PM
sadly, I SO wanna try that. Looks wicked!
Ikotoo says: Jul 7, 2008. 1:33 PM
I have heard be exposed to lasers for long periods of time can give you skin cancer.
laci37 says: Jan 29, 2009. 10:08 AM
I think if something gives out enough radiation to burn you it can damage the DNA too. It's like strong sun shine, it burns, it causes cancer but who cares?
hintss says: Nov 28, 2010. 4:37 PM
but it burns away the DNA, so theres no DNA to be damaged :P
blugyblug says: Nov 19, 2008. 11:06 PM
But everything causes cancer. Geez ive heard from someone that Meningicoccal vaccines cause cancer. I HATE EVERYONE WHO BELIEVES THIS BULL about cancer, just because its scary doesnt mean you can get everyone to not do something or buy something.
ShadowAssassin says: Dec 24, 2010. 7:37 PM
AMEN! and who cares you gotta live your life anyway :D
tclemmo says: Sep 3, 2012. 2:48 AM
I recently heard that some sunscreen can give you cancer.
What is happening to the world?
Ikotoo says: Jan 3, 2009. 5:37 PM
as do I hate people who think everything gives you cancer. Someone a few days ago told me that if you freeze a water bottle with water in the plastic releases chemicals. Well that it complete bullshit. but L.A.S.E.R. stands for Light Amplification by Stimulated Emission of Radiation. so one could think.
1-40 of 509Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
