In order to consistently photograph something like milk drops the usual method uses a high-end camera ($500 and up), Speedlite flash ($300 and up) and an optical electronic delayed flash trigger ($120 and up).
There are lots of DIY circuits for this purpose, but they still require a good camera and a high-end flash unit.
And you have to manually open the shutter requiring the photo to be taken in a darkened room.
Here's how you can consistently take the same photos with an simple circuit, inexpensive point and shoot camera, no additional flash unit, all without fumbling around in the dark.
The video above shows the ease of use of this rig and some of the better splashes of the hundreds that I've captured.
I've concentrated on milk drops, but this can be used for many different things. The separation between the laser and the detector could be hundreds of feet apart, or bouncing off mirrors...
Thanks, and have fun spilling milk!
-Brett @ SaskView
Remove these ads by
Signing UpStep 1: Materials
Laser pointer
Door chime
USB Cable
Magnets
Clamp
Shelf brackets
Mini-tripod
Self-Adhesive backed Velcro
Small picture frame (for the plate glass insert)
Eye drops (for the dropper bottle. I poured out the contents as I believe anything
purchased at a dollar store should never be applied to one's eyeballs!)
Here's what you'll need for the circuit (I don't think your local dollar store will have these so you might try an electronics distributor like Digi-Key):
Part/Value Digi-Key Part #
3 1.0 uF 50V Ceramic Caps BC1162CT-ND
1 10 uF 35V Electrolytic Cap P818-ND
1 1K Ohms 1/4 W resistor 1.0KQBK-ND
1 22K Ohms 1/4 W resistor 22KQBK-ND
2 120 Ohms 1/4 W resistors 120KQBK-ND
2 200 K Ohms .5W Multi-turn Pots CT94EW204-ND
1 Green LED P14228-ND
1 Red LED P14224-ND
1 LM556CN timer IC 296-6504-5-ND
1 7404 inverter IC 568-2921-5-ND
1 Photodiode PNZ300F-ND
Please note that the schematic has been revised to use new photodiode.
Visit Our Store »
Go Pro Today »
Depends on the flash, new one use low voltage for the trigger circuit and can be interfaced very easily.
If you have an older flash, you will have to add an SCR to the circuit . It's to isolate the high voltage that the Flash's trigger circuit uses. Some older units have a couple hundred volts DC at the hot-shoe contacts.
Mine is http://www.instructables.com/id/Melody-Muffs-The-Real-Mans-Headphones
hella cool idea btw :P
-TheWaddleWaaddle
You can check by looking at the spec sheet's graph of the 'spectral sensiivity': A red laser is about 660 nm and that falls in the middle this diodes response.
The part "LM556CNFS-ND" is no longer available.
Will this part from digikey suffice? "296-6504-5-ND"
Thankyou! I cant wait to make this project :D
Take another look at the parts list and schematic: I've changed to a photodiode instead of a photoresistor.
The diode version works much better than a photoresistor. I've tried both, and I don't recommend using a photoresistor because it has a slow response and doesn't trigger reliably.
Cheers!
I built this rig and have yet to take any photos (At the last minute, I found out the batteries in my camera were flat - 10 minutes ago, before writing this .... talk about tension).
I know these instructables are open to interpretation and doing things your own way so I have modified this a little.
Firstly, I didn't have magnets or a glue gun. I used glue backed Velcro. I also could not find a laser pointer like the one I wanted (where I could remove the laser easily) so I bought a laser mounted on a circuit board and then shorted out the momentary switch.
Anyway, from the top of the rig down, here is what I did.
I velcro'd an empty clear plastic biscuit tray upside down to the arms holding the laser. I then used a soldering iron to poke some holes in it. I use these holes to poke the particular eye dropper through that I had.
I used the holes to get closer and closer to cutting the laser beam that is below it. To steady the eye dropper through the hole, I used an old drink container lid and some bluetack. (I will try and post photos at some stage).
I created a cross with two pieces of wood. Each 25 cm long, 4 cm high, 2 cm wide. Screwed in the middle to make the cross. On the end of one wooden beam, I screwed on two more pieces of wood which forms the arms. Each arm 9cm long, 2cm wide, 4 cm high. In one arm, I drilled a hole to poke the laser housing through (in my case 1.5 cm diameter). The laser fits snug and does not move.
My laser is attached to a battery tray that holds 4x 1.5 volt AAA batteries. I shorted out one compartment so that the pack delivered 4.5 volts. I then used a soldering iron to poke a hole through in the end unused compartment and used it to put a toggle switch in to activate the laser. I placed Velcro on the back of the battery pack and secured this to Velcro on the laser arm.
I then cut up an old milk carton and put some Velcro on this. This becomes a light guide and shield against lights from above. This is velcro'd to the second arm. Then I attached the Photodiode and leads to some Velcro and attached this to the second arm, under the milk carton.
The laser to photodiode distance is about 20 cm's which is a convenient length. The dropper is suspended about 2 Cms directly above the beam.
The arm was then G clamped to a vertical bar. This is about 46 cm above the plate I will be dropping food coloured milk onto.
I then bought a 5V usb power pack with the USB female a Type cable insert as a part of the power pack. I got a cheap USB A type to Mini USB. I cut this in 1/2. I wired the USB A type end into the circuit as the power source and can plug this into the power pack. I wired the mini usb from the circuit to the camera (just like the original instructable).
The circuit is mounted on a bread board. I used 2x temporary Zif sockets with easy release levers (18 leg) to hold the two ic's. I found some old solid core cat 5 network leads and cut them up as hook-up wire.
I used heat shrink over cable parts I needed to protect or wanted to stop moving about.
This all leads off to the A470 camera running CHDK. This is behind a small piece of glass (As recommended in the instructable) and I got some further pieces of wood to cut some notches in to hold the glass up vertical (As shown in the instructable but not discussed).
As my camera and flash both fall behind the glass, I have used a DVD cover to raise the camera and tripod to the correct level.
I then tweaked the sensitivity pot so that the drops from the dropper trigger ever time.
Now I just need some batteries and further tweaking.
Wilst I did have attery power, I also discovered setting the camera to the playback mode and triggering the laser beam, causes the camera to cycle through the images. Me thinks this might have other uses !!
Maybe setup an enterence laser to your home, someone comes through the door and a display panel cycles a picture on the camera displayed on a tv. Could be fun for things like birthdays with various images coming up on the TV.
I bought new batteries, but they do not last long in the A470. Not long enough for me to get everything working. The A470 seems to drain power. I bought a power adaptor for the A470 and think I found an issue with chdk a470-101b-0.9.9-953-full.
If I power from the mains power pack without CHDK loaded, it works fine. If I use CHDK after one flash, the camera tells me it is flat, change batteries and then it shuts down the camera.
Still working on it ...
could this be easily set up to connect to an event counter? eg if you wanted to count how many drops went by...my application would need to count a 2-10msec break and count up to 20 such events a second....my application needs a separation of 6 m but you have answered the distance issue.
mickyj - where did you gets the bits in Oz?
The photodiode is the only obscure part. Any visible light photodiode should work. The datasheets will usually have a graph called Relative Spectral Sensitivity. Ask for a photodiode with a range of sensitivity that includes 650 - 670 nanometers (a red LED laser's wavelength).
Yes, I contacted Digikey about 1 week ago (just before your post). There is about a 2-3 month delay on the same items I can't get in Australia. Hopefully I will get everything just after christmas. I will have to book mark this instrucatble and come back :)
Let us know how it goes.
Awesome instructable.
Thank you!
There is one thing I don't understand: how can i set the delay for the camera to start capturing after the drop has passed the laser and interupted the beam?
i will be very gratefull
I just just did it with an Alpha 700 from sony,
give me your cybershot model, maybe it's the same connector for remote command :)
(I'll write a little how to for the alpha)
While it may be possible to do this with another brand of camera, I don't have a Sony camera with which to test any modifications to the circuit. I really would like to help you but I can't safely make any recommendations.
CAUTION: BLATANT VOTE PANDERING FOLLOWS:
This instructable is entered in the Digital Days Photo Contest, and a Cyber-shot is the top prize. If I should happen to win that camera I will be ABLE to test a modified circuit. So please VOTE for this instructable and if I win, I will do my best to post an instructable using the Cyber-shot.
-Brett
This set-up really depends on having a Cannon camera that's compatible with CHDK.
Unfortunately, I'm so slow when it comes to building things that it's just not feasible.
Does this cirquit also work as a normal switch ?
So what I want is, I want to controll my external flash with it. So I get 2 wires from the flash and if the have contact to each other the flash fires. So can I connect these to wires to the cirquit ?
Greets and thx for answering.
http://www.hiviz.com/tools/triggers/makeown.htm
I'm going to try to modify my circuit to do the same.
I've updated the parts list to include the Digi-Key part numbers. They have a toll free number and the sales people are very helpful.
No, I'm not trying to promote Digi, it's just the only big supplier I know of that has all the components...
You may also use a photodiode that is sensitive in the red to infrared range only, which will inherently filter out anything below "red" in the spectrum.
I like your Soldering Kit 'ible
thanks for explanations. I think I couldn't explain well what I was thinking. Between laser device and photodiode there is a line that laser goes on. when milk drop go across this line it cuts laser beam and all system start work and camera shoot the photo. This line between laser device and photo diode is 3 or 4 inches away from the plate that is full of milk. When paint drop cut laser beam it pass 3-4 inches to reach the plate.This takes a very short time like 10 milisecond. And camera is programmed to take photo 10 milisecond after the laser beam cut.
My airgun bullet has speed nearly 1000 f/s. so the distance between laser beam and target must be far more than 3-4 inches. That is the distance that I must find. Thanks again for your explanations
From what I’ve read, sound triggers are the best way to get the shot you’re after.
Here’s a link discussing that: http://nitpicker.blogspot.com/2007/03/how-to-trigger-strobe-for-photographing.html
The pellet may be moving too fast to even trigger my circuit. I have the laser as close to the dropper bottle as possible, so the drop is moving slowly when it passes through the beam.
With even a cheap green laser (i.e. one rated <1mW) you could probably trigger a setup like this or similar from half a mile away (although then you come up against beam divergence - the way the beam diameter expands with distance). Red lasers don't have quite the range and haven't nearly got the brightness of green - though only to our somewhat biased eyes.
In any case, you shouldn't have an issue with distances on the scales you'll be dealing with.
Plus, the photodiode is quite sensitive. The spec's on it say it's tuned to blue light, with red dropping the sensitivity to more than half. But blasting it with a red laser more than makes up for that.
For a quick range test, I bounced the beam off of 2 mirrors and through two panes of glass, covering a distance of about 75 feet. Instead of the small red dot it normally produced, it was spread out about a centimeter (half inch). The circuit still worked perfectly.
Let us know how things work out!
Very nice project.
Good Instructable.
Cheers :)
The number of caps in the shopping list is incorrect. Quantities 3 and 4 are in the wrong order.
Thanks for pointing it out! It put it back the way it was.
Any ideas would be greatly appreciated!
Link to my shutter release: http://www.instructables.com/id/Olympus-Evolt-E510-Remote-Cable-Release-Version-2/
(_)
Wired remote
.. TO MY WORKSHOP!!!!
