3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Laser Triggered High-Speed Photography
Step 4The Laser
The Laser
The laser pointer has a momentary switch but I wanted a slide switch that would allow the laser to remain on without me holding the button.
The Dollar store magnetic door chime not only had the slide switch that I wanted, but also it used the same kind and number of batteries that the laser does. This was cheaper than buying just a switch from an electronics supplier.
I removed the tiny circuit board from the door chime and installed the working guts of the laser in its place using the chime's switch and battery holder.
You don't have to go to this extreme if you don't want to. Just use a rubber band rapped around the laser pointer to keep it turned on.
Like the photodiode, I hot-melt glued some magnets on the back.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
207
Author:Frivolous Engineering(FrivolousEngineering.com)
In December 2009 I published The Most Useless Machine Ever. 2011 formed The Frivolous Engineering Company Inc. in order to supply Useless Machines to the masses.
