3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Laser Trip Mine
Laser Trip Mine
This instructable will teach you how to make a laser trip mine.
If someone steps in the lasers path I have gotten it to set off a L.E.D., but you can make it set off other things.
You are going to need:
1. Laser.
2. Photocell, perferably a big one.
3. PNP switching transistor
4. 2 nine volts
5. potentiometer
6. L.E.D
*DONT POINT LASERS INTO PEOPLES OR ANIMALS EYES*
Step 1The Laser
The Laser
Attach the laser to the switch and the 9 volt. Make sure everything is compact so that later if you want you can put it in a box. Also to make sure the laser doesnt get burned use a resistor.
95 comments
1-40 of 95next »
Dec 29, 2011. 12:17 PMDearden805 says:
So basically when the laser loses contact with the photoresistor it supplies power to the LED? That means you could wire in anything that ran on a nine-volt. Please correct me if I am wrong.
Jul 13, 2011. 11:40 AMlukeD says:
I have a program for you, Yenka called. it is free if you take the home license. good luck.
LukeD
http://www.yenka.com/en/Free_student_home_licences/
Jun 1, 2011. 8:42 PMamruth says:
Can someone give me the PNP transistor number like for NPN we have 2N2222 or 2N3904.
Jun 7, 2011. 9:15 PMrobot1398 says:
for 2n3904 its 2n3906
Aug 3, 2009. 1:00 PMthe "wow shammy" says:
would a dvd player's laser work?
Jan 12, 2011. 8:35 PMGameNox says:
Sorry, no. You need a laser BURNER to make it at least cut through paper. I know there has been some confusion about that....
Laser readers like DVD ones read tiny bumps in the CD/DVD. The burner makes those bumps.
May 21, 2011. 10:11 AMARJOON says:
can i use a laser pointer
Jan 21, 2011. 5:32 PMthe "wow shammy" says:
hard drives contain magnetic reading heads not lasers, right?
Jan 21, 2011. 6:28 PMGameNox says:
Yeah, I think so.
Apr 13, 2011. 7:36 PMtechno guy says:
Can you make some schematics for this?
Jan 7, 2009. 6:11 PMSparklesam says:
I tried hooking this up to a buzzer, but It isn't working at all. Please if anybody has any advice I'd like to know
Apr 7, 2009. 5:48 PMCubie2 says:
Most buzzers will not just work because they have electricity flowing through them, in fact if you were to open something like say... The Operation game you would find that the buzzer will usually even have a transistor of its own.
Apr 20, 2010. 3:44 PMDigy says:
 you should try this instructable if you want a buzzer I am building one and it works except it won't stay on when tripped, so I am in the process of finding a different type of transistor.
Oct 31, 2010. 4:54 PMrrrmanion says:
Google set reset transistor then either get the buzzer to run of the maximum (~5v) or use a relay type thing, to up the voltage
Dec 11, 2010. 7:35 AMDigy says:
I actually figured out u need a relay to get it to stay on after activation.
Nov 20, 2010. 3:11 PMerveli says:
How many ohms is the potentiometer?
Oct 23, 2010. 10:04 PMcoilsinamotor says:
is it pnp or npn?? cuz for most switichng applications ppl use npn
Dec 26, 2009. 10:13 PMYoung Genuis says:
Do you need the potentiometer? I can't seem to find one so if it wasn't there I wouldn't mind.
Apr 20, 2010. 3:45 PMDigy says:
 Yes, it affects the sensitivity of the photocell, basically it is a variable resistor. You can find one at tri-state electronics on northwest highway in mt propect illinois if you around cook county (Chicago-land).
Dec 18, 2009. 9:15 PMminerug says:
It would be better to get a B216 kit from Jaycar and hook it up to a relay, which in turn is hooked up to a siren or something
Oct 26, 2009. 5:40 PMColonel88 says:
Can you post a simple circuit diagram, like maxxxem's but just the bare bones approach?
Aug 19, 2009. 8:49 AMmaxxxem says:
I modded your circuit a little to make LED light or 15 or 30 sec
Jul 9, 2007. 2:44 PMScissorman says:
Cool project. What rating is the resistor to protect the laser?
Aug 17, 2009. 6:29 AMColonel88 says:
that is a waste of energy.
Jul 9, 2007. 7:22 PMpyro13 says:
so how do u raise the amps??!?!?!
Jul 9, 2007. 10:31 PMpyro13 says:
ok can u please explain, for a dummy who knows nothing about electronics, how to turn a 5$ lazer pointer from walmart into something that can burn paper with minimal cost.
Jul 18, 2009. 9:50 PMjman11 says:
go to http://daedallasers.com and pick up a blue ray laser diode
Jul 10, 2007. 10:51 PMT3Hprogrammer says:
1000mA=1A...
Aug 16, 2007. 8:09 PMcooter1974 says:
halo456456, you have same misconceptions about basic electricity/electronics. I'm not saying that to offend you, but to try to get you to do some studying/research (example - 100mA does not equal 1amp, it equals .1amp) You can't take a power source and a fixed load and "increase the amps". You can increase the power source capacity, but it will deliver no more current than the load requires.
Jul 9, 2007. 10:04 PMpyro13 says:
whats it called?
Jul 18, 2009. 9:47 PMjman11 says:
do you think this would work for a multi stage coil gun?
Apr 26, 2009. 11:35 AMsanty22 says:
put it into a HL laser tripmine papercraft and it would be VERY COOL
Apr 1, 2009. 12:51 AMimakethings says:
when the laser beam is tripped will the buzzer ring continuously?
Feb 19, 2009. 2:41 PMPKTraceur says:
try expresspcb.com they have a PCB maker which you can order from them, and a schematic maker, which I use alll the time. It's free, and awesome. -RoAr
Jan 3, 2009. 9:46 PMian25 says:
This is how I visualized the schematic. Hope it helps. Great Instructable.
Schematic.psd(612x792) 456 KB
Dec 10, 2008. 3:23 PMsdaw says:
could you just make a schematic using paint? it would be much easier to understand.
1-40 of 95next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
11
Author:halo456456
