Laser Tyndall Effect
6,822
6
Published
Introduction: Laser Tyndall Effect
About: You can try my projects AT YOUR OWN RISK. There's infinite ways to damage or destroy persons and property. I can't think of them all. Kids use adult supervision. I've lost count of the number of items that I...
You can use a simple cat toy (laser pointer) to demonstrate the Tyndall effect. "The Tyndall effect, also known as Tyndall scattering," according to Wikipedia "is light scattering by particles in a colloid or particles in a fine suspension." You can use the laser to test three different mixtures: colloids, suspensions, and solutions. I'll demonstrate Tyndall scattering in a colloid (milk), in a suspension (dirt), and a solution (sugar) with a cat toy (Laser pointer).
My Twitter
My Facebook
Parts Needed:
250 ml beaker
Spoon
Eyedropper
Tap water
Cat toy (Laser pointer)
Milk
Sugar
Dirt from garden
First, you can test the Tyndall effect using ordinary tap water. You won't be able to see the laser beam piercing through the air, and you won't be able to see the laser beam in the beaker since there is nothing in ordinary tap water to cause Tyndall scattering.
Step 1: Colloids
You'll need an eyedropper with a small amount of milk, a spoon, and a beaker with 250 ml of water. Squeeze a few drops of milk from the eyedropper into the beaker and stir. Shine the laser through the beaker and you should now be able to observe the Tyndall effect.
You'll notice that you can't see the laser beam piercing through the air, but you can see the beam in the diluted milk and water mixture. A glass of milk is an example of a colloid and the Tyndall effect is what gives it its translucent appearance. Milk is mostly an emulsion of milk fat and water. An emulsion is "a suspension of small globules of one liquid in a second liquid with which the first will not mix" (source). Oil and vinegar do not mix, but vinaigrette is an emulsion of oil and vinegar. "Emulsion" is used to describe a colloid of two or more liquids (in the case of milk, milk fat droplets dispersed in water) as opposed to, say, an aerosol colloid like fog (water droplets dispersed in air). The milk fat globules are too small to be seen with the naked eye or even through an optical microscope, but (unlike a solution) are large enough to scatter light and create the Tyndall effect. Colloids are visually homogeneous (uniform throughout), but microscopically heterogeneous (lumpy/grainy--in this case, the globules of milk fat remain separate from the water). Generally, colloids cannot easily be filtered nor settle at the bottom of the beaker.
Step 2: Suspensions
Stir 5 grams (1 teaspoon) of dirt from your garden into a beaker with 250 ml (about 8 ounces) of water. Before the dirt settles, shine the laser pointer through the beaker. You should be able to observe the Tyndall effect before the particulate (the particles of dirt suspended in the water) settles to the bottom of the beaker. Suspensions are heterogeneous (lumpy/grainy—the grains of dirt suspended in the water). Particles in a suspension are usually large enough to see with the naked eye or be viewed through an optical microscope. They are often large enough to be filtered from the water, and, of course, will eventually settle to the bottom of the beaker.
Step 3: Solutions
Stir 5 grams (1 teaspoon) of table salt (NaCl) into a beaker with 250 ml (about 8 ounces) of water. Stir until all the salt (solute) dissolves in the water (solvent). When the NaCl dissolves in water it separates into sodium (Na+) cations and chloride (Cl-) anions too small to be seen with the naked eye and will not scatter the light from the laser beam. Solutions are homogeneous mixtures, that is, the water molecules, sodium cations, and chloride anions are uniform throughout the mixture. The mixture is stable (the salt, once dissolved, won't settle to the bottom of the beaker) and the salt cannot be filtered from the water.
Shine the laser pointer through the beaker containing the saline solution and, well, nothing interesting was supposed to happen. But you can see the Tyndall Effect in my sample of table salt and water. (See picture 1 above.)
I read the ingredients in my box of salt and included with ordinary sodium chloride are calcium silicate, potassium iodide, and dextrose. It appears, then, these other ingredients cause the water to be slightly cloudy--their particles in suspension large enough to cause Tyndall scattering.
To better demonstrate the Tyndall Effect in a solution, I decided to dissolve sugar in water. (See picture 2 above.)
And there you have it: you won't be able to see the laser beam piercing through the air, and you won't be able to see the laser beam in the beaker. When sugar (sucrose) dissolves in water, sugar is broken down into smaller and smaller particles until eventually the sucrose molecules are too small to be seen with the naked eye and will not scatter the light from the laser beam.
Step 4: Conclusion
To conlclude, you can demonstrate the Tyndall effect with a laser pointer to see Tyndall scattering in a colloid (milk), and in a suspension (dirt).
Milk is mostly an emulsion of milk fat and water. The milk fat globules are too small to be seen with the naked eye or even through an optical microscope, but (unlike a solution) are large enough to scatter light and create the Tyndall effect.
When you stir a teaspoon of dirt in the beaker of water, you should be able to observe the Tyndall effect before the particulate (the particles of dirt suspended in the water) settles to the bottom of the beaker. Particles in a suspension are usually large enough to see with the naked eye or be viewed through an optical microscope. They are often large enough to be filtered from the water, and, of course, will eventually settle to the bottom of the beaker.
You shouldn't be able to see the Tyndall effect in ordinary tap water since there is nothing in ordinary tap water to cause Tyndall scattering. You also should not see the Tyndall scattering with sugar dissolved in water--when sugar (sucrose) dissolves in water, sugar is broken down into smaller and smaller particles until eventually the sucrose molecules are too small to be seen with the naked eye and will not scatter the light from the laser beam.
    • Oil Contest
      Oil Contest
    • Woodworking Contest
      Woodworking Contest
    • Planter Challenge
      Planter Challenge
    1 Questions
    If home made Colloidal Silver is basically IONS...and you shine a laser through it and see a red trace, doesn't that prove that in fact you do have Silver Particles therein?...If product is only IONS, and IONS do not reflect light, then what else could the red trace in the product be?...thanks
    Sorry for the delay in responding to your question. I'm not sure what home made Colloidal Silver is, but commercial Colloidal Silver is, by definition,"a colloid consisting of silver particles suspended in liquid" (Wikipedia) and NOT silver ions.
    2 Comments
    Question - Could this be done in the sky with artificial clouds/Chemical, maybe lighing a light or laser from space or ships... and would it/Could it, make pictures like a holographic image or something of that sort. could this be done with this effect?
    I don't think this is a serious question, but, no, you probably won't be able to do these things with a simple cat toy laser pointer, lol. OTOH Laser light shows have been around for ages. To see the lasers requires an aerosol colloid (glycol or water droplets dispersed in air) made by theatrical smoke machines. The firs example that comes to mind is a music video from 1984 ("Relax" by Frankie Goes to Hollywood): https://www.youtube.com/watch?v=rCp2h5jslKY
