3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Laser Vortex 2.0 - Starburst Vortex
The Laser Vortex was extremely popular last year and many made one this year as well. The wormhole like effect is great for many different themes. Last year I used Deep space; this year is was a portal into another realm. Made with spar parts and maybe a trip to the hardware store, you can have one in just a few hours.
This new instructable will show you haw to build a Laser Vortex with extended range, sharper display, less noise and the ability to create a starburst vortex. You can use this instructable to fine tune your old one or create a better one from scratch but this time you may need to salvage some junk parts or order some materials. You can take it as far as you want.
Step 1Gather Your Tools & Materials
These are the materials I have used for best performance of the Laser Vortex. The Make Controller Kit was used for creating the Starburst Vortex and as a power supply. I'll offer some alternative power options when we get to these steps.
Parts:
Six inches quarter round trim
Small piece of laminate flooring (aprox. 5.5 inch by 2 inch)
1/4 inch by 5/16 inch Tee Nut
Insulated alligator clips
3/4 inch first surface/front surface mirror
Mini camera tripod
Precision drive motor and head salvaged from a CD or DVD player
5 mW Green Laser Pointer
One wire tie
Small electrical wire (a 6 foot network cable with the ends cut off works great for this)
Heat shrink to cover the wire connectons
MAKE Controller kit (for the Starburst Vortex effect and power supply.)
Tools:
Hack saw (for cutting the quarter round trim)
Wire cutters/Side cuts
Drill and 1/4 inch drill bit
Hot glue gun and glue sticks (low temp glue works fine)
Hammer
Multi-meter (to check connections)
Fire (for the heat shrink)
30 comments
Dec 22, 2011. 4:10 PMBeergnome says:
So my presumption here is that the starburst effect is coming from the mirror type used and not anything you are telling the laser to do?
I run a laser vortex for Haunted brewery tour every year and all that is using a old ATX computer power supply Jump the green to any black to activate. a Case fan wired to yellow and black to spin a regular mirror mounted offset to the middle of that fan.. green laser pointer aimed at that fan. It's a constant "cone" and with the smoke machine gives a good "walking towards the light " effect.
on a regular computer power supply, the orange leads give you 3.3v and should be safe for a standard laser pointer using 2 AA, or AAA's you might want to throw a 330 resistor just to be even safer though ;)
the Mirror in question here looks to be the same mirror used by the CD-rom drives laser reader. that can just be pried off and used, but it is a very small target to hit. 2mm square usually.
most high speed CD rom motors are of a brush-less motor type and require three conductors to be energized via a special driver board to work. With a standard two pole motor, you can simply put a 10K potentiometer between in line with it to manually control the speed of the motor
A great little instructable! its giving me bigger and badder ideas for next years display!
May 30, 2011. 6:16 AMtinker234 says:
wow reminds me of stargates
Oct 20, 2008. 8:44 PMbearsinthesea says:
I pulled a motor out of a computer cd drive, but it is not a straight DC motor with two leads. It has 15 leads, and the motor jiggles back and forth when i power some, but i never get it to just spin.
I am guessing this is because it takes signals to adjust the Constant Linear Velocity used. ( http://www.pcguide.com/ref/cd/constSpindle-c.html )
I suppose i'll just get a cheap DC motor from the local electronics store.
Oct 21, 2008. 9:06 PMbearsinthesea says:
It is a Samsung 'High Speed' drive, but doesn't say much more than that. The circuit board has a date, 2001.08.15, on it. Shame, because of the nice mounting area it would be easy, as you say, to put the mirror onto.
Sep 21, 2010. 11:13 PMDIY-Guy says:
Hmm, lots of leads on the "motor" you say? ... Could be a stepper motor if it only makes a little jiggle when you apply current. Just a passing thought.... Maybe you could try sending pulses and see if it rotates.
Good luck with that motor!
Aug 15, 2010. 8:15 AMlovephileo2 says:
Thanks for the instructions. I love this laser so much. I just got mine a month ago for my Vortex Optics.
Oct 20, 2008. 2:56 PMbearsinthesea says:
Where is a common place to get a mirror of that type and size? The hardware store?
Oct 11, 2008. 7:08 PMdanielemur says:
awesome Instructable. I was thinking of using the circuit from an old bike light that flashes to get the starburst vortex.
Nov 3, 2007. 6:20 PMrimar2000 says:
Good job! My cheap laser pointers they overheats after some seconds of continued use, and they spents. ¿Is this normal?
May 17, 2008. 3:07 AM_soapy_ says:
Try adding a cooling fan, as found on a RAM cooler or a video card.
May 17, 2008. 1:29 PMrimar2000 says:
Thanks for the idea, but the cooler is more expensive than the laser.
May 17, 2008. 4:20 PM_soapy_ says:
Well, not much is cheaper than a £2 laser that burns out after an hour, but a heatsink or small cooling fan will only set you back £5 or so.
Dec 19, 2007. 5:16 PMheavy.metal.nguyen says:
That's the same laser I have!
Dec 21, 2007. 6:14 PMheavy.metal.nguyen says:
I just got mine last week of amazon. How much mas yours?
Dec 22, 2007. 3:31 PMheavy.metal.nguyen says:
Mine was like $17 from amazon.
Nov 8, 2007. 12:30 PMrimar2000 says:
Mever, thank for the explanation.
My ex laser pointers (both went to the waste) they were REALLY cheaps: 1.56 U$S each. I can't buy a U$S 50 laser pointer. I live in Argentina.
Nov 13, 2007. 1:37 PMchicoson123 says:
Very nice. I experimented with your first laser vortex and had similar results as this one by simply using a marker and blocking out certain parts of the mirror to keep the laser from reflecting. Of course it won't give you as much control as this one, but it's a bit cheaper and easier. I also wanted to see if it was possible to find something the would reflect the laser in a different color and also add it to the mirror, but no luck finding anything. Also, cutting up a CD or DVD and using that as the mirror will split the beams.
May 17, 2008. 3:09 AM_soapy_ says:
Adding a colour filter to a green light will simply mean that either you get less green light or none at all. You can only selective filter a mix of light to get another colour, without serious optics.
Nov 14, 2007. 10:40 AMchicoson123 says:
Yes, the only information I found about changing the color of a laser was by using pressurized gas, which would change it's frequency depending on the gas and pressure.
http://www.etl.noaa.gov/about/eo/science/raman/
They say "simple", but I don't think the average person would have the equipment they use lying around the house.
Thanks again for the great instructable.
Nov 3, 2007. 2:39 PMjoejoerowley says:
Great instructable!! Good use of the make controller kit.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
11
Author:mever
