Step 5Tripod Mount
To screw the wood base to the tripod, a 5/16 inch Tee Nut was used. Once again this was found in a local hardware store for less than a dollar but you will usually find these in the nuts and bolts department.
To install the tee nut to the wood base, a hole about ¼ inch deep was drilled on the bottom just big enough for the shaft of the nut. It is best to center the hole to ensure a well balanced mount but be careful not to drill directly over the screw securing the clamp unless there is space for it. The tee nut is then hammered into place and ready to be mounted.
The final product mounted to a small tripod. Remember when attaching the laser pointer to tighten the bolts enough to hold the laser in place but not break it. The bolt for the button should only be tightened enough to hold it down.
Add Comment
