Laser-cut Honey Labels by RakeMyLeaves
Featured
A laser cutter is a great tool to make some sweet (Boom! Honey Pun!) labels. Without a laser cutter projects like this would require an expensive custom die-cut or an eternity of exacto knife hell. The laser cutter can cut a large quantity of labels quickly and use a more detailed design than a die-cut. I made my labels to use on little jars of honey from my first year of beekeeping. We sent them out as client gifts for our graphic design business. I think this type of label would be great for all kinds of homemade food products like jam, salsa, and canned goods. The cut labels allow you to highlight the georgous food inside the jar.
For this project you will need: a vector-based label design, paper for you label, access to a laser cutter, clean jars, a supply of scratch paper, and spray adhesive.
Step 1: Design
Use a vector graphics editor like Illustrator or Inkscape to create your design. Measure the jar you're using to get the right size. Make sure all the elements of your label are connected so you have a single piece once it is cut. You can get a good idea what different colors will look like on the computer. Print out your design, cut it out roughly, and wrap it around the jar to make sure the size and style are what you want. When your design is complete you'll ususally want to export it as a SVG or EPS. Check with your laser-cutter people to see what file setup they prefer. If you would like to use my design on your own honey, there is a pdf attached to this step. Just promise to tell everyone how fantastic I am.
turbobug says: Sep 14, 2012. 9:03 PM
cool labels one more reason to get a laser cutter
Penolopy Bulnick says: May 1, 2012. 11:55 AM
Awesome! Best honey label I've seen and pretty darn great label in general! What a great way to make labels!
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
