I did all my laser cutting at TechShop San Francisco. It was my first attempt and 2 of the 3 boxes that I made worked out but one broke when I tried to bend the lid into place. I tried 3mm MDF, aromatic cedar "laser wood" from www.laserbits.com and birch "laser wood" from the same. The MDF cut and bent perfectly; the cedar burned quite a lot in the cutting (more on that later); the birch cut well but it was too thick to bend.
[Update] I've now improved the design (pictured) and it works perfectly with birch as well as the other woods. See the final step for the updated design files.
Materials:
- ~3mm laser ply or MDF.
- 6 x 10mm M2 screws and nuts.
- 1 x wireless sensor node (mine is my own design but a friend of mine has written up a very similar one, from which mine is derived)
- 1 x laser cutter, I used a 60W Epilog Helix.
Remove these ads by
Signing UpStep 1: Designing the box
Here's how I built up the design (sorry for the lack of screenshots of the working):
- Set the file to be 24inches x 18inches, which is the bed size of the laser cutter I was working with.
- In File > properties add a 1mm grid. (I prefer to work in metric
- Draw a 6 cm square for the base. I didn't worry about details like the screw slots at this stage.
- Draw half-circle for one side and extend down from the ends 1cm to give a flat portion; close the base.
- Calculate the required length for the top = PI * 3 + 2 cm = 11.5cm
- Create a rectangle of that length and 6cm tall.
- Using the grid snap, draw one copy of the living hinge pattern.
- Clone the pattern along the length of the lid.
- Using the path editing tool, refine the shapes, drawing in the pegs and T-slots for the screws. I used a 1mm grid for 90% of the work. For precise pieces like the T-slots, I selected nodes that needed to be "off grid" and manually entered the coordinates.
- Using the grid, draw in 2mm circles for the screw holes. For the antenna hole, I used the snap toolbar to turn on snap to cusp and snap to centre and then let the centre of the circle snap tot he end of the line. Then I used the path tool to edit the line to remove overlap.
- Finally, I added some rounder rectangles to the end piece for air holes and cloned the end piece.
- I was planning to cut different types of wood that have slightly different thicknesses and I didn't want to have to alter the design for each type so I made the pegs stick out past the end of the slots and curved the ends. On a thinner material, they stick out a bit further but no matter.
- I made made the pegs slightly wider than the holes (by 0.2mm) in the design to account for the kerf of the laser beam.
Visit Our Store »
Go Pro Today »
Regardless of TechShop SF's use of CorelDraw, you don't need to use it. Printing from Acrobat Reader works just fine, as the Epilog driver mimics a printer driver, and can be used from any program (it must print a vector image to cut).
I did have problems importing some file formats to CorelDraw, as it appears you have found. Since I primarily work on a Mac, I am happiest just using PDFs for the actual cutting. The same trick works with Inkscape on Windows.
Beautiful work, by the way, and great instruct able. Now I want to find some reason to make one of these (or I could just make something pretty).
saw kerfs on the underside 2/3rds the way through 1/2 inch apart would look better and finish better plus some epoxy glue added later upside down to the kerfs would make it strong enough to stand on
Kewl project!
Keep on with Inkscape. It's the future!
I thought this was made from one of the solid woods you listed at the begining ( that will teach me to skim and comment lol)
