3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Laser cut gear clock - with ChronoDot!
Step 21st prototype
1st prototype
For the first prototype, I just wanted to see if I could get the stepper gear thing working at all.  I cut a spur gear for the stepper, a small stand with a hole in it to press fit the stepper motor and a larger gear that would be the clock mechanism.
After assembly and a quick program, I decided that the clock needed to have two gears (and thus two stepper motors) - one for hours and one for minutes.  I also discovered that the numbers needed to always be right side up as the gear traveled around.  Thus, the 6 needed to be upside down in the drawing as well as the 3 and nine needed to face outwards.
Another cool thing I discovered during my first prototype is that the Arduino has enough power to step these motors without having a driver circuit.  This makes the clock considerably easier to make!  Here are a couple of links to tell you about how to hook up the Arduino to the stepper I used...
http://ryanschenk.com/2010/03/driving-a-040-stepper-with-arduino/
http://profmason.com/?p=173
I also began to think about my gears.   In my prototype, I used a 10 tooth gear for the gear connected to the stepper and a 100 tooth gear for the ring.  100 really does not translate well into hours or seconds so what else could I use?
My stepper gear has 10 teeth and this actually works well because the stepper I am using has 20 steps per revolution.  Thus I can step the stepper 2 times to move exactly 1 tooth.
Therefore, for my minute hand, if I use 60 teeth, then each 2 steps = 1 minute = 1 tooth of movement.
Similarly, my hour hand has 144 teeth because if we divide it by 12, each hour has 12 teeth and therefore each tooth is equal to 5 minutes!  Really, the clock does not have to have a minute ring at all.  The hour ring can tell you what time it is.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
24
Author:bpwagner(LVL1 Hackerspace)
I am a middle school computer teacher with an EE degree. I do programming to pay for my teaching habit. I am also one of the founders of LVL1 - Louisville's Hackerspace.
