3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Laser cut gear clock - with ChronoDot!
Step 4Cutting the Clock file on the Laser
Using the file Gearclock3.svg and LVL1's Lasercutter, I cut the clock out of 1/8" plywood that I purchased at Michaels.  I am sure you could use other materials, and I will probably make an acrylic clock sometime.
To cut the clock on our laser, I printed to the Retina Engrave software that came with our laser.  Retina engrave allows you to control the laser based upon which colors are in your file.  For example, I set the laser to cut completely though the plywood when the color is black and engrave only a little when the color is purple.
To cut 1/8" birch plywood on our 40W laser I use a setting of 30% cut speed and 100% power.  To engrave on our laser, I use a setting of 100% cut speed and 25% power.  The order is what order the laser uses.  I engrave (purple) first, then cut the red and then cut the black.  I set the repeats to 0 for green, because I do not want to cut any green.  It really is not as difficult as it seems.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
24
Author:bpwagner(LVL1 Hackerspace)
I am a middle school computer teacher with an EE degree. I do programming to pay for my teaching habit. I am also one of the founders of LVL1 - Louisville's Hackerspace.
