Laser-cut ripple clock by fungus amungus
Featured
It's a wooden clock with lots of concentric circles that mimic ripples in a pond. Cut with a frickin' laser beam. I wanted something that was abstract and yet still had the basic functionality of a clock. It's a little bit of work with Illustrator and a bit of time on the ol' laser cutter.
Step 1: Designinating
This clock was designed in Illustrator with lots of circles. The process for this is pretty straightforward if you've used Illustrator or other vector-based programs before. It pretty much goes like this:
  1. Make lots of circles
  2. Move them around until you're happy with the look
  3. Use pathfinder to break everything up into individual pieces
  4. Delete what you don't need
  5. Use pathfinder again to combine everything that's left
The results you want are two files. One for the top layer of the clock with the design and another that's just two circles for the bottom layer.
The image here shows the progression of the design. Each row has the same vectors, but with different strokes and fills.
Hiyadudez says: Apr 23, 2012. 10:22 AM
That's one cool nipple ripple clock!
;D
Jenius says: Sep 10, 2012. 10:57 AM
+1 (pre-edit)
but, yeah... +1, cool clock, kept simple... love it.
gmjhowe says: May 8, 2012. 4:40 AM
Love it. Perfect simple design for a laser cut clock.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
