Laser cutter, start slicing stuff for under 50 dollars
Step 6Follow me as I discover a laser cutter
This isn't so much of a step, but a story. This shows me discovering the stepping, the power of the laser and the first time I cut anything out. If you want a better view of how this actually works, or for more a different perspective on some difficult parts this might be a good place to get it:
Here we start with an overview of my lab, and also all the parts, a basic diagram of how things are set up. A close up view of the "print head" is here if you're curious:
I also get the stepper motors going here!
This is part two where I find out what it means that I have two stepping scanners connected:
This is the part where I take you to show you the power of the laser. You can see the beam outside, and also you can watch as I hold it to burn paper by hand:
Now you can watch as the entire setup is connected and hooked up. Hear my surprise when I actually get it to cut a diagonal line:
lastly hear me as i try out postscript sending for the first time, watch the scanner as it cuts, you get a nice close of up how it's all hooked up.
And that's it, I hope this extra story line helps. This is a fun project, and if anyone wants to improve it I'm sure it can be done. Show me your best!
All the best.
-Bilal
22 comments
Jul 21, 2011. 9:02 AMUQONYX says:
You should be able to create classes in the files for different types of materials that will also control the speed of the cutter. That way you can have an even cut on the material. You should also focus several dvd or bluray diods at a central ppoint or even get a burning laser diode(link)----------> (http://shop.ebay.com/items/?_nkw=200mw+laser+diode+650nm+Kip+Kay+project+suitable&_sacat=&_ex_kw=&_mPrRngCbx=1&_udlo=&_udhi=&_sop=&_fpos=&_fspt=1&_sadis=&LH_CAds=&clk_rvr_id=249109212700&satitle=200mw+laser+diode+650nm+Kip+Kay+project+suitable) and magnify it with lenses. Either way, its an awesome project and it looks real cool.
May 6, 2011. 12:12 PMBigTW says:
FRKN SWEET
Nov 11, 2010. 6:49 AMgemguy says:
cool ideas! my question is... what about using something like this to cut rocks?
yeah, i do cut rocks by hand but this idea would be so much easier and cooler.
any ideas on how powerful a laser must be to cut silica?
Thanx in advance!
Dec 25, 2010. 5:12 AMnutsandbolts_64 says:
Very powerful is how I'll say it is. Unless you can concentrate the laser by a lot you won't be cutting anything. By the way, a 1 watt laser is dangerous enough, a kW laser (I dunno what I'm saying) can be barely moved. You might as well motorize your drilling technique.
Jan 6, 2011. 10:02 AMilpug says:
get an old tile saw and modify it. lasers are impractical
Jan 7, 2011. 11:43 AMgemguy says:
Have one...lol they make laser engravers for rock and jewelry applications, but they are spendy.
Sep 2, 2010. 12:41 AMrlimosenero says:
hi, do you have another site that I can view all your works..coz I can't open all views here...I am really interested in these kind of stuff and would like to build bigger or in large scale...
Jan 28, 2010. 11:30 AMperfo says:
Could you use something like a Fresnel lens to concentrate say 20 of these things in to spot to get faster/deeper penetration? If Mr Lasermaster thinks you will need 20 watts to cut 1/8 " then as it seems you can buy 1w laser diodes on eBay, using 20 or 30 of the blighters in a matrix, concentrated with a Fresnel should do the trick. Should it not ?
May 13, 2009. 1:28 AMsolsed says:
brownie points for playing 'that time' by regina spektor! :) love that girl! :)
Oct 16, 2008. 7:08 PMcuaz64 says:
Hi, Good work, What kink of lase I need to cut metal?
Feb 11, 2009. 12:47 AMsensoryhouse says:
You'd be better off with a plasma cutter.
Nov 13, 2008. 8:07 PMiBurn says:
......One that's really big......and REALLY expensive........
....like.......REALLY expensive....
Jan 1, 2009. 10:13 AMKEYBOARDISBROKEN says:
try aiming several dvd burners on the same point
Jan 19, 2009. 5:12 PMlasermaster3531 says:
to all comments above about cutting metal, think about this. to cut construction paper you need 200 mW plus. you would need a laser capable of several watts probably 20+ . to cut 1/8" plastic you need at least half a watt.
Jan 19, 2009. 8:40 PMiBurn says:
Going sheerly on the fact that his name is "lasermaster3531"....I'm going to believe him.
Jan 20, 2009. 11:25 AMKEYBOARDISBROKEN says:
lol depends on how thick it is too...
Jan 21, 2009. 11:22 AMlasermaster3531 says:
yeah. aluminum foil would be easy. try angle iron.
Feb 11, 2009. 12:49 AMsensoryhouse says:
who needs to laser cut angle iron?
Feb 11, 2009. 3:53 PMlasermaster3531 says:
I'd say, anyone with some angle iron that they need to cut and that have a laser cutter and nothing else to cut it with.
Jan 3, 2010. 8:18 PMiBurn says:
Who cares if you have something else to cut it with?! If I have a laser that can cut through angel Iron, you can bet I'll use that just because it's gonna look cooler than a hack saw.
Jan 21, 2009. 12:12 PMKEYBOARDISBROKEN says:
lol try propane tank...
Jan 28, 2009. 10:04 AMDerin says:
BOOM
Jan 28, 2009. 4:06 PMlasermaster3531 says:
yes.BOOM!!!!!!
Jan 28, 2009. 5:48 PMiBurn says:
BOOM only begins to describe it...
Mar 15, 2009. 4:10 PMWafflicious says:
Ka-boom?
Jan 29, 2009. 9:21 AMlasermaster3531 says:
yes,indeed. the fireball on it's own would look like a mini neuclear blast. the heatwave would ignite anything within a 50-yard radius. that is, if yoy managed to cut the whole tank open at once, otherwise the tank would just act like a rocket.
Jun 14, 2009. 5:42 PMiBurn says:
I can haz?
Jun 15, 2009. 6:26 PMlasermaster3531 says:
you can what?
Jun 15, 2009. 6:37 PMiBurn says:
I can haz giant lazor and propanes?
Jun 15, 2009. 9:29 PMlasermaster3531 says:
if you haz mucho cash, maybe.
Jun 16, 2009. 2:30 AMDerin says:
Derin Industries sells those items if you like.We also give %30 pyro discount to these when bought together.Of course,to keep prices down,im adding this label:
MADE IN CHINA
Jun 16, 2009. 10:11 AMKEYBOARDISBROKEN says:
how about 'propane tanker'
Jun 16, 2009. 5:20 PMlasermaster3531 says:
maybe.
Jul 20, 2009. 3:11 PMiBurn says:
Knock it off guys, I'm gonna start drooling.
Jul 21, 2009. 9:40 AMKEYBOARDISBROKEN says:
massive 2,000,000 gal. tank filled with napalm....
Omnomnomnomnom
Jan 21, 2009. 12:08 PMiBurn says:
Now we're starting to talk beyond this instructable...
Nov 30, 2008. 3:21 PMthinker says:
depends on the metal aluminium can be cut quite cheaply think of how easy it is to burn through pop cans
Nov 30, 2008. 3:24 PMiBurn says:
Point taken. But it would still take this laser a while to cut through aluminum, unless you spray painted it black or something...
Mar 12, 2009. 9:50 PMjohnjay says:
would it cut thin metal (in your example a soda can) if the laser simply moved slower? Thanks for the great instructable!!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
132
Author:lamedust
Bilal Ghalib is interested in doing things that surprise him and inspire others. Let's create a future we want to live in together. I still sorta run the design and imprint company modati.com. I make...
more »
