Step 1: Materials Required
2] buzzer
3] coin cell - cr2032
4] one laser 2mv or more (most important =D)
5] pref board or bead board or you can do it without using both
6] foam (for the stands)
7] 2n2222 transistor
7] resistor 100 ohm and 4.7k ohm
8] Two Neodymium (NdFeB) magnet
9] metal strip
10] tape and double sided tape
11] a long nail or toothpick
Step 2: The circuit digram
the transistors back is facing you.
base-middle pin
collector-left pin
emitter-right pin
Step 3: How the circuit works
you can change it between 1k to 100k to change the sensitivity
for this circuit i recommend 4.7 or lower
Step 5: Make the stand for the laser
2] then cut a small slit kind of a thing as shown in the pics
3] pierce a toothpick to give stability
Step 6: Make the stand for the circuit
2] stick it on the side of the door or where ever you kept your precious things
3] stick a metal strip on it
4] stick a magnet on the circuit board with the help of double sided tape
Step 7: Now set up the alarm
now keep the laser on the slit in the foam piece and on it such that the beam falls on the photo transistor
when you will interrupt the beam a sound goes off
Step 8: Make it with a phototransistor
heres how-
you will need
1] buzzer
2] photo transistor [dont have one see next step i will show you how to make one]
3] 2n3904 transistor
4] coin cell
Step 9: Make the photo transistor
1] carbon tetrachloride
2] AC126 transistor
if you cant get a photo transistor you can make it with a AC126 transistor
first take a AC126 transistor and remove its metallic cap.then wash the inside with carbon tetrachloride till the white paste like substance is completely removed.Now cover the transistor with a transparent glass cap to protect it from moisture and damage.in this way your photo transistor is ready.
Step 13: All done
hope you like this instructable.
rate,vote and follow for more instructables
Visit Our Store »
Go Pro Today »
i see you used a cheap chinese laser like i did... but (1) how did u keep the button switched on automatically, and (2) my laser fluctuates slightly so the alarm rings continuously... can you help me out on how to deal with this?
thanks!
the collector and the base
http://www.instructables.com/id/LED-Wheel-Effect-Without-a-Microcontroller-/
but the other is too big and the laser beam is too small for such a big LDR
