loading
Step 1: Materials Required
1] LDR
2] buzzer
3] coin cell - cr2032
4] one laser 2mv or more (most important =D)
5] pref board or bead board  or you can do it without using both
6] foam (for the stands)
7] 2n2222 transistor
7] resistor 100 ohm and 4.7k ohm
8] Two Neodymium (NdFeB) magnet
9] metal strip
10] tape and double sided tape
11] a long nail or toothpick
Heyy plz change the circuit diagram i cant understand a thing plz plz change it or label it
Didnt work for me :(
can i use 1k resistor for 100 ohm resistor?and can i use a small speaker for the buzzer because i cant find buzzers in my area?
hi can use a 1k resistor instead of the 4.7 resistor?
Yes you can
can i use a 2N3904 transistor and can i make your circuit without magnets?
Yes you can use 1n3904 and you can make the circuit without magnets
hi.. nicely done! <br>i see you used a cheap chinese laser like i did... but (1) how did u keep the button switched on automatically, and (2) my laser fluctuates slightly so the alarm rings continuously... can you help me out on how to deal with this? <br> <br>thanks!
I used a piece of tape and stuck it around the laser push button so itis continiously on
hi i made da circuit it works fine but the transistor gets hot is there anything wrong in my circuit
which transistor did you use?????
2N2222
which pins of the phototransistor are you using ,it seems you are only using 2 ,iam assuming the base is not connected,to anything,is this right
the phototransistor that i have has only 2 pins not 3 if u have a 3 pin then use only<br>the collector and the base
Iknow u soldered the components on the board but how did u connect them to each other. I would be nice if showed me a pic
Hey robot can i know how u connected everything onto the PCB, like using wires or something else, i have probs using wires cause they break after a few days. Can u plz tell me wat method u used.
i connected all the things with solder at the back of the board
Can u plz take a pic and show me.
Hey robot1398 i didnt actually understand the relay part cause i am not good with relays. It would be easier if u showed it with a circuit. I am using a SPDT relay it has 5 terminals.
i will give the circuit by tomorrow as now i have to make it
its been 2 days when will u give the circuit. :)<br>
i have not made it u should connect the realey from collector of the transistor to the power supply and use only 2 terminals
K i will try , but still try to make the circuit plz.
I forgot to ask how to keep the circuit on after the laser is broken and connected again, how to make the buzzer ring even after that. :)
check out my new instructable<br>http://www.instructables.com/id/LED-Wheel-Effect-Without-a-Microcontroller-/
a relay i think connect it from the collector of the transistor to the power supply
Hi robot1398, thx for the advice and the circuit worked but the LDR i use is really big so when i hit a laser the dosent stop but when i hit a LED flashlight it works. I think i need the same high risestive LDR in a smaller size. If u hav any ideas plz tell me. The ldr to the left is the usual size the one i am using is to the right. In the nixt pic i showed it by hitting the laser. Thx for the help.
you should use the smaller LDR because it is almost the size of the laser beam<br>but the other is too big and the laser beam is too small for such a big LDR
Sry for bieng such a noob but i wanted to know wat type of ldr and buzzer did u use. Thx for all the help.<br>
i used a simple piezoelectric buzzer and the LDR which my local electronic store gave to me.
Hey Author i tried ur circuit and when i connect the batteries the buzzer keeps ringing, i checked the laser and the circuit but it is all correct. Can u plz help me and this is a great instructable.<br>
ok now try aming the beam of laser straight onto the ldr or use a led torch if you cant keep your hand stable if want to stop this change the 4.7k resistor to a lower level
Will this work for sure<br>
yes
C00l *5
thanks
wow its so complecaded.i think its 5*
thanks
Looks like this will just make a POP sound. Then silence...
Oh I see, this is one of those buzzers with built in tone generation circuitry. <br>Nice i'ble.
voted for your both instructables<br>
About This Instructable
24,523views
19favorites
License:
Bio: None of your buisness
More by robot1398:Pocket Sized Morse Code Flasher Arduino running LEDs Arduino fading led
Add instructable to:
