3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Laser show for poor man
Here's another useless but cool looking "must build" gadget for every romantic geek.
Let me introduce PIC microcontroller based three axis laser spirograph.
Check link below if you want to see more patterns
Laser patterns gallery
Step 1Gathering stuff
Gathering stuff
Design is quite simple and employs regular parts and components but you are free to change/modify it in way you like.
At first prototype I used blank DVD as reflective material but later I discovered more practical way. Technology of making FS mirror is described in my article
DIY Front Surface Mirror
Originally I'm very lazy man so I've chosen programmed microcontroller PIC18F1220 (can be replaced with PIC18F1320) to handle routine job.
PIC implements 3 channels PWM generator.
Actually it's the same engine as one I used in my IKEA light project just code is adopted for PIC18.
PWM signal toggles MOSFET transistor 2N7000 (Id 200mA). Mirror actuator is connected as load to MOSFET.
As mirror actuator I used 5V 200mA CPU cooling fan. It's easy to mount mirror on its flat side.
Device accepts 5V and 12V fan with maximum current 200mA . Voltage is selected by jumper.
Green laser pointer is rated at 3V so I've made LM317-based voltage regulator with adjustable output.
Cheap 5mW green laser module:
http://www.dealextreme.com/details.dx/sku.10094~r.32746761
What else will you need?
Dozen of resistors and capacitors, potentiometers, toggle switch, power jack, prototyping board, box of proper size and power supply unit.
304 comments
1-40 of 304next »
Apr 4, 2012. 5:52 AMSavoJr says:
303 comments! Sweet! =) Anyhow, have to ruin that beautiful number with my comment.
If you ppl. build DIY laser show equipments consider to add glass art in front of beam.
It should be already weakened by other means though, because directions of the reflections would be more uncontrolled, and it has potential danger to cause eye damage.
It would look good, that's for sure.
Another nice one is to get holographic lenses and put those in front of the device. I found those from EBAY.. were meant to be for lasers, and had good looking effects.
They cause beams to spread out effectively. Seller guy demonstrated that in some of his videos and showed demo where was more than one lens in use at the same time. Impressive stuff!
Aug 12, 2011. 11:47 PMbbsbb says:
Nice Job.
Could you also send me the BOM for the parts? How much will it be if I buy them from you?
Thanks
Jan 24, 2012. 7:25 PMcmcgann says:
I know that it has been a long time since you posted this, but could you also send me a list of prices for the parts and the preprogrammed PIC or an unassembled kit?
Jan 24, 2012. 10:38 AMmirogajdzik says:
That is great !
Jan 13, 2012. 10:49 AMDjandco says:
Self cooling too!
Bonus!
Nov 27, 2011. 9:35 PMKitty2011 says:
great picturer, have you got other colour graphic, such as blue or red?
Nov 20, 2011. 12:06 PMtautius says:
Does anyone have made one of these on an Atmel microcontroller?
Oct 21, 2011. 7:27 AMonezhou says:
i seriously want do one as same as yours ,but my patterns are very simple and ugly, i don't know how to solve my problems,would you like give me the nuclear advice thank you very very much.
Oct 23, 2011. 9:26 PMonezhou says:
thank you !
Sep 11, 2011. 2:35 PMrhans says:
Hello, you would pass me the schematic image of what you did when you made this PCI: http://www.instructables.com/image/F3ENCQ6FCZERBZZ/Brain.jpg
If you are willing to pass me, this is my email: rafahans@ibest.com.br
Aug 11, 2011. 2:49 PMmjaffe says:
Mine was a speaker, wrapped with a balloon with a front surface mirror siliconed on... amazing.
Jul 11, 2011. 10:12 AMNE patsrock says:
it isnt really for a poor man and i cant even make it
Feb 24, 2010. 11:12 AMwilliamyjk says:
Can you please send me separate pricing for:
1) a programmed PIC
2) circuit board only
3) full, un-assembled kit
Thank you.
Jul 10, 2011. 10:40 AMl19bal says:
Hi could you also send me separate pricing for:
1) programmed PIC
2) PCB Board
3) full un-assembled kit
Thank you.
Mar 21, 2010. 7:32 PMjohnston1991 says:
hi,  could i have a price for the pre-programmed pic please
many thanks
Jul 10, 2011. 7:43 AMmacnomad84 says:
How easy are these enclosures to drill?
Nov 21, 2010. 11:41 PMeffste says:
i want to make a laser show that analizes 3 frequency and depending on the frequency there will be a different colour of laser.. for example if the frequency of the sound right now is from 0Hz to 300Hz than the laser which is producing the light will be red. If it is from 300Hz to 5KHz the laser which is producing the light will be green and if the frequency is higher than the light will be blue. I will use matlab to generate different frequencies and dump them into the microcontroller. Any ideas on how to do this?
Jul 10, 2011. 7:36 AMmacnomad84 says:
analogue vu meter basically...
microphone -->LM386--> 3x Hi-Q BPFs
Each output would swing between 0-5 V depending on the signal strength in each frequency "bin" made by the BPFs.
Could run each signal into a threshold detector/comparator circuit to turn the lasers on/off.
Mar 20, 2011. 7:07 PMbpark1000 says:
You will need an RGB laser set, with each one analog controllable. The 3 lasers are combined onto one beam with dichroic mirrors. You could have a computer looking at the music frequency output, and using a look-up table to drive the lasers.
Dec 30, 2010. 5:23 AMTreknology says:
The reply is very simple, "color organs" are used at discos and clubs. You just need one shrunk down to power your lasers without burning them out. If you want to be really smart, direct the three lasers through a prism so that they combine to form white light and then throw that on the mirrors, as your music changes the density of each primary color, the output of your display will change accordingly. (If been thinking of this for a raster-scan laster projector.)
Nov 22, 2010. 1:41 AMeffste says:
but how will i input a song if i don't have a microcontroller?
Jul 3, 2011. 8:10 PMpbergeronronronron says:
could i replace the whole pic circuit with three of this circuit? http://www.instructables.com/image/FGH9VJOFHTAIQK6/Part-List.jpg
Jul 10, 2011. 7:31 AMmacnomad84 says:
neat.. don't have any PICs lying around, but think i may whip up a manual PWM w/ this circuit for shiiiiizles
Jul 10, 2011. 12:53 AMvishalapr says:
This is really cool! I am going to make one for myself!
Jul 9, 2011. 10:32 AMpbergeronronronron says:
i just thought of something else to use as mirror!
as simple as a hard drive platter!! it has no imperfections!
im going to try this as soon as i find a scrap hard drive
May 26, 2011. 3:51 PMhollowpoint says:
would it be possible to use mirror tint for the mirror rather then an actual mirror?
Apr 24, 2011. 7:45 AMcoolo52 says:
this is a very neat spirograph i probably wont make it though
Apr 11, 2011. 11:32 PMshnyfher says:
Hi can i get a pcb board and the microcontroller from you?
1-40 of 304next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
90
Author:AP Digital light
