You will need:
- Conductive fabric. I used Cobaltex from Less EMF http://www.lessemf.com/fabric.html
- Wonder Under or some other iron-on adhesive sheeting (you can get it at fabric stores)
- Laser cutter
- Clothing iron
- Flux
- Soldering iron
- Stuff you want to solder
- rhinestone glue (like Gemtac) for gluing your components to the fabric.
Remove these ads by
Signing UpStep 1Ironing on the wonder under
Leave the paper on, that is the side that you will be lasercutting.
I'd like to use it in a conductive shirt I'm making, but was wondering whether you've had any issues with shorts from the positive and negative conductive traces crossing? I will have quite a few close together so I'm worried they may cross since the shirt is flexible and short out.
One other question...I found someone who has a Universal machine but newer than the one you most likely used. Do you remember the wattage of the machine or the setting that you used to cut the traces? We were also interested in whether or not it was a CO2 laser.
