Lasercut Plywood Violin
14,572
240
67
Posted
Introduction: Lasercut Plywood Violin
This violin was the winning entry to the Laserworks Contest @ MADE festival in Roskilde, Denmark in August 2014. The contest rules were simple: build something out of max 5 sqm 3mm plywood within 8 laser cutting hours + assembling time. My contest partner and I created six instruments (violin, ukulele, cajón, monkey drum, ocarina and güiro/rattle) with me being mainly responsible for string instruments.
The violin (as all of the other instruments) can be played but does not sound particularly nice but rather flat. I suppose the sound could be enhanced a bit by creating a body of sound. Please feel free to download my files, hack my design and build an improved version :)
Note added on Nov 19th 2014: I have now finally uploaded my files. I changed the design of various small parts a thousand times during the contest, so I am not sure, which parts exactly I used. I therefore planned to print the violin again from scratch, but unfortunately I do not find time for it, so now I have just uploaded the parts I think I used. There might therefore be some mistakes in the files, but feel free to just change accordingly. And let me know if you think anything is missing!
Step 1: Cutting the Files
I drew everything from scratch in Illustrator. During the contest, I improved small details again and again, so don't get frustrated if you find something that doesn't fit and just change it yourself :)
Step 2: Glueing Small Parts
I have created three square spacers and four round spacers. The squared ones are placed in between the cross bars while the round ones are placed near the edges. The small square holes are added to make it easier to stack and assemble the pieces. Also, you can already prepare the snail. (Please note that there are probably way too many round pieces, as I also used them for another instrument).
Step 3: Bending the Fingerboard
I found it really tricky to bend the fingerboard and tried different things. What turned out to work best for me was to put the laser out of focus by lowering the table with the plywood and then cut deep lines 3/4 through the material (make sure to make a few tests with a small piece to find the right adjustment). To cut entirely though the edges of the fingerboard, I just added one or two layers in the same file, so that the laser would go around the board a few times. This can obviously be done in a more intelligent way ;)
I then soaked the board in warm water which made it contract itself. After having prepared the bottom of the fingerboard (a flat piece and two thinner and shorter pieces on top - see the picture), I glued the wet piece on top and secured it over night.
Step 4: Preparing the Body for Assembling
The 'walls' are made of sliced, bendable pieces of plywood. In order to attach them to the top and bottom of the violin, I have created a kind of retainers that the walls can fit into. The outer side of the outer piece follows the exact shape of the violin while the inner side of the same piece does not (see in the middle at the waist of the violin). This is because I couldn't get the sliced walls to make such sharp turns without breaking.
I glued the inner retainer about 5 mm away from the outer retainer but could probably have made a much tighter fit, so maybe you could try with 3 mm room between the two retainers.
Step 5: Assembling the Body
Now, you need to assemble the whole thing. I started with the bottom and the crossbars and then added the spacers. Next, I attached the walls and finally the top part including the bridge.
Step 6: Finalising the Violin
Finally, add strings and pegs. Voilá!
I just started playing with laser cutters a few months ago (I am a business student and usually have nothing to do with design ;) and this is my first real laser cutting project. I am sure that there are tons of things you could improve, so please feel free to build your own, hack the design and let me know your thoughts and improvement suggestions! I look forward to seeing your new violins :)
5 People Made This Project!
  • Microcontroller Contest
  • Spotless Contest
    Spotless Contest
  • Science of Cooking
    Science of Cooking
He Lee AnnH,
What is the enlargement factor to blow up the PDF files to correct dimensions?
Thanks, Doc
54 Comments
Thanks to LudwigWW I have finally managed to upload the cutting files. The mistake was that I only uploaded the files without assigning them to a specific step. So thanks again LudwigWW for your help! Have fun making the violin everybody :)
I upgraded to premium but I don't see any AI files for download under the download link. It only downloads a PDF with the photos and instructions on it.
As far as I know, Premium is only needed for downloading the actual PDF of the instructable itself, the actual build files whatever format they take (.ai, .dxf, svg., etc.) are available to anyone, anytime. Normally, they should be added as downloads at the time the instructable is created. I have been watching this for 2 years and all I've ever seen is promises to "upload" the files "soon". I don't really believe he had any intention of adding them and now they magically appear as Adobe Illustrator (.ai) files in the comments. I believe he thought he had something going on that he needed to hold back the files for and now that has changed for some reason so he suddenly does have them?
Thank you dhaykus0418 for the mistrust. This is my first and only instructables, I haven't used the site before or after this one-off project, and I have kindly asked for help to upload the files correctly (I can see the ai files in the instructables, so I thought it was correct). Too bad that you for 2 years haven't felt the need to help out instead of just watching the issue. What exactly do you think I needed to hold the files back for? Seriously, I find that quite interesting :D Have a nice day, and please start helping us beginners <3
P.S. I am a she, not a he :)
hello friend! i run an after school music program and we will be making cardboard violins with the children to teach them all the different parts of the violin and how to properly take care of the instrument before giving them they begin playing the real one. your design is just awesome! would you be willing to share the files with us? thanks in advance!!!
Hey,
Thanks for your comment. You can download the files from the site if you are a premium member.
Best,
Lee Ann
Hey :) I'm also interested in your awesome design, the thing is I'm not quite sure what you mean by premium member... I have an account and there's no signs of an upgrade option
Where can I get the files
There are two .ai files (under 'Download') with everything that needs to be cut. Enjoy :)
Hi, for me the .ai files are missing, the only download there is for the pdf of instructions. Could you upload them when you get the chance?
