Step 5Techniques: Decorating
Take a pie plate and either with a knife (like in my case) or the fork poke a few holes in it. Check and make sure you have an inch or so of water left in the pot. Place the pie plate upside down on top of the pot. Did you place your opposite colored chocolate in a plastic sandwich bag? Now would be a good time to do so while you wait for the pot water to boil.
The idea behind this is that since a bowl has already been dirtied a second bowl would be adding to the problem. So why not melt the chocolate in a sandwich bag instead? When you are done you can just throw it away. Besides, if you by now after reading this paragraph opted to instead reach for another bowl consider this: you will have to transfer the contents of the bowl into the bag anyway to do the kind of decorating I am talking about. You choose.
I can see it now:
Cooking in a sandwich bag and just how much plastic is entered into my system will be a hotly debated issue in the comments below. So lets talk a little here.
"Chocolate melts at body temperature, about 95 to 100 degrees F." LINK
I am sure everyone has gotten chocolate on their finger before.
Sandwich bags are made of polyethylene.
LINK (page 7)
LDPE (Low Density Poly-Ethylene) melts at 248F.
LINK
Besides I am merely assisting the rapid melting of the chocolate by flashing it with steam, I am not, nor do I recommend that you boil or otherwise cook the bag and contents for prolonged periods of time.
(Stepping off my soapbox)
OK where was I? Ah yes, decorating. Needless to say I melted my chocolate in the freezer bag. For those of you who are looking at their sandwich bags right now don't worry, those work fine too. I melted the chocolate by placing it on top of the pie plate for a few seconds on each side and kneading the contents until a smooth consistency results.
For those of you who used another serial bowl, melting is just the same as the dip. Good luck transferring it to a sandwich bag. Tip: Get a second set of hands (hope you have kids!).
Pick one of the lower corners of the bag and snip off a tiny bit with scissors or a knife. Pick up the bag with the upper opposite corner and twist until you hold in your hands the very tool that cake decorators use. Squeeze a little onto the wax paper you laid out earlier, if the string is too tiny cut a larger hole. Be careful here because if you cut off too much at one time you will ruin the bag. You want to shoot for a string a little thicker than a rice grain.
When you are all set go to town on those strawberries. Just blindly going over all of the strawberries yields surprisingly good results. To step it up a notch you could pick three or four grouped strawberries and go in straight lines. Going one step further and going the opposite direction will make a checkerboard pattern. Heck, make little dots while you are at it. Be creative.
After you have decorated put them in the refrigerator for an hour or two to harden the chocolate.
4
comments
Add Comment
Add Comment
