Everyone needs to channel a little Gandalf in their life from time to time. I find my own outbursts to be taken much more seriously when I'm donning this wizard-like costume. Well, slightly more seriously.
My apparent need to walk around in flowing robes, wielding staffs, and quoting various lines from both Lord of the Rings and Harry Potter made it clear to me that I would need a proper mask to really be legit and garner the respect I clearly deserve. So I set out to create one based on my own features to make it as life-like as possible.
Step 1: Sculpting
I happened to have a plaster cast of my own face, but this could also be done on a styrofoam head with the prominent features mapped out to match your own. Using my own face allowed me to follow the contours more closely to create shapes that would look like my own natural aging.
I gathered some reference photos to help me along, and sculpted on top of my face cast with plastalina clay. Here you can see my first rough sculpt, followed by some refining I did. Since I was going to cast this in latex, I knew that every detail was important.
Step 2: Molding
I used WED clay to create a base and walls along the sculpt. Next, I mixed up the Hydrocal and spread it along the sides of the sculpt, and drizzle over the top. It's important to do this slowly and carefully, as you want to make sure you pick up every detail.
After pouring the initial coat of Hydrocal over the sculpt, I continued to mound it up and create a flat top to the mold. When the mold is turned over, this creates a flat base which makes it easier to manage.
Step 3: Pouring the Latex
I used very basic mask latex for the casting, which is super easy to use. I poured the latex into the mold, sloshed it around to make sure that to get it in all the tiny spaces, let it sit for a minute, and poured out the excess. Then I tapped the mold a whole bunch to get out any air bubbled (believe me, there will be air bubbles - esp around the nose!
After this layer of latex was set, I repeated the process several times until the mask was as thick as I wanted it to be.
When the final layer of latex was set, I removed it from the mold and dusted it with cornstarch to keep it from sticking to itselt. Traditionally, talcum powder is used, but it's so bad for your lungs, why risk it!
Next I cut away the excess latex and hand sewed it to a wool hood so it would fit over my entire head. Trying it on was like looking into a creepy future-mirror. Note to self: moisturize daily!
Step 4: Painting
You need special paints or at least a latex base to mix with your paints for latex masks. Again, Monster Makers has a great selection of supplies to get you going.
I had a hard time getting a nice balance between a warm flesh tone, and an old wizard pallor. You can see I started with a slick coating of flesh tone, and painted in some dark shadows. Next I added veins and liver spots to really add some aging. I didn't get too detailed, but tried to hit it just enough for some realism.
Step 5: Adding Hair
Ventilating is exactly like the latch kit rugs of ages ago. You feed a loop through one hole in the lace, and pull the loose ends through the loop and tighten the knot. This technique gave me lots of control about how the visible edges of the hair would look, and I'm really please with the final result.
Since facial hair is usually much coarser, I needed a completely different set of hair for the moustache. I scavenged a cheap, frizzy white wig, and sewed the hair directly through the latex.
Step 6: Finishing
Now when I shout “I have not passed through fire and death to bandy words with a witless worm!" people take me seriously.
More or less.
Visit Our Store »
Go Pro Today »
Can you tell us what everyone won? Bet the prizes were great... and I'd love to know!!!
Great Work!!
A tip for those who might wish to follow in your footsteps would be PLENTY of reference photo's - not just of yourself, but 'wizards' in general and any ancestors/older relatives you're told you resemble. Or you could try and find somewhere/some software that can 'age' you electronically.
Of course, that may be more time (and, potentially, cost) than people might be able to devote to this, but it might be worth consideration..;-)
And finally, Scooch, could you re-design your glasses or try some coloured contacts, please..?
Whether that would suit either of us, I don't know - but the 'super weird' look would certainly add a dimension or 2 to your Wizard persona.
I should have made myself clearer, but I just don't think your glasses work in the 'Scoochmaroo The Grey' picture - they're too 'Earth-bound', rather than being rooted in Middle Earth.
