Lathe Turned Pen
Published
Introduction: Lathe Turned Pen
This Instructable is on how to make your very own hand turned pen, in the indestructible I will be explaining how and putting in some tips to go with it. This is my first instructible :D
Step 1: Obtaining Supplys
Here are some supplies you will need to turn your own pen, they include:
1. wood lathe
2. a cheisel
3. a pen kit of your choice, mine come from pennstateind.com
4. a wood blank of your choice (acrylic also works but I wouldn't recommend if this is your first pen turning)
5. wood polish
6. super glue or another strong glue (gorilla glue etc.)
7. sandpaper
8. strong paper towel
9. patience, for me that can be the hardest thing to get :)
Some unnecessary things only for tips:
1. q-tips
2. guitar string
3.wax
4.potato
Step 2: Preparing Your Blanks.
1. First to prepare your blanks you need to cut into rectangles the correct size, then depending on your kit you cut the blank to a more specific size. (For this instructable I am using a basic to block size which is used in many pen kits)
2.Once your blanks are at the correct size you will need to drill them straight through unless they came pre drilled.
3.Now you ready to glue your blanks, take your super glue, (etc) get something to cover the surface of whatever you are working on along with some q-tips and spread it over the brass tube included in your kit. TIP! If you would like to make the glue stick better scratch up the tube with some sandpaper. TIP! To help prevent glue getting within the brass tube plug up the ends with something easily removable I use either pieces of a slice of potato, or wax. Now place/slide your glue covered tube into the hole within your blank.
Step 3: Start Woodturning
1. Place your blanks on the metal pole that goes across the lathe, make sure the pole is locked in place but not to tight. Now turn your lathe on and start carving holding your chisel.
2. Have Fun, make your own shape and grip or whatever curves you want.
Step 4: Sanding and Adding Burn Marks
1.To sand choose your sandpaper and try to smooth it all out till you can't see any slight chips you may have caused while turning.
2.To add burn marks when your done sanding you will need some guitar wire and a way to hold it tightly onto the wood. First make a groove using a high speed steel blade, then you hold the guitar wire across the groove until a puff of smoke comes up.
Step 5: Polishing
Now to polish your pen, take your paper towels and rip off a good sized piece fold it up so there's some towel between your finger and the spinning blank.
Next put some of your polish on the towel, then apply blanks with lathe on.
Step 6: Putting It All Together
Take your blanks off the lathe and place onto a press, now put the kit and blanks in order and press them together nice and tight.
Step 7: Admire Your Work!
Admire and use your very own custom pen, it would be great to see some of the pens everyone makes so if you make any post them with a comment on here. (:
Step 8: Warning
Follow the guide and rules for using power tools.
Step 9: Some Examples
I will be adding any pens I make to this step for examples to this instructable. (gonna add more pictures soon :) )
    • Make it Move Contest
    • Casting Contest
      Casting Contest
    • Woodworking Contest
      Woodworking Contest
    2 Comments
    nice tutorial. can't wait to see more. great idea to use a potato!
    The pen looks awesome, I just wish there some in progress pictures. It can really help people to replicate your amazingness!
