3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Launch It! Contest Entry: The Alcohol Fueled Soda Bottle Rocket
Step 4Takeoff! WWWHHHHOOOOOOOOOO!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Right, to fly the rocket, gather the materials described earlier and go back to the first step and watch the videos again. Then come back here. Right, what you need to do is go outside to obstruction-free area. Then dribble 5-10 (amunt of fuel will vary with grade of alcohol, I can fly on 5 drops 99%, but 10 are needed for 76%) largeish drops of alcohol into the rocket. If you haven't already screw on the nozzle. Place your finger or a piece of tape over the hole and roll the acohol around inside for about 30-45 seconds to allow it to evaporate.
Don your safety equipment and move everbody and any flammables away from a patch on the ground that you dont mind lightly scorching.
More on safety:
This rocket emits flaming vapors and hot gases, sends hot plastic flying erraticly through the air, and your dealing with intoxicating flammable liquids, please use that underdeveloped organ stored away in your skull, and exercise caution.
Insert the ends of the rockets launch guidance rods/skewers into the ground at a slight angle unill it is stable. Perform countdown, and when ready to launch remove your finger/tape from nozzle, and at arms length with apply igntion source slightly below (1cm) the nozzle opening. With a whuoosh your rocket will leap forth into the heavens about 20-30 feet and tumble back down to the ground.
If you are using straws instead of skewers, still insert your skewers into the ground as described above and then slide the straws taped to the rocket over them, creating a mini launch tower.
To re-launch, allow the rocket to air out for a minute or so and repeat steps on this page. your rocket will survive 5-7 flights before it will suffer structural failure and melt. At that point you should save your nozzle/cap and make another, using the salvaged nozzle.
Pics coming soon
4 comments
Mar 3, 2009. 6:01 AMsnoobeagle says:
He sure says "right" a lot :)
May 13, 2009. 7:52 PMnutsandbolts_64 says:
you got that "right" lol
Feb 19, 2010. 12:11 AMbeehard44 says:
like Ms. P**** "you get me?
it seems i have been seeing you around instructables lately.....
Feb 19, 2010. 1:26 AMnutsandbolts_64 says:
TELL ME YOUR YM (don't worry we're friends, right H***) I'M DYING (not really) TO GET YOUR YM ID (fakely cries)
Feb 19, 2010. 1:27 AMnutsandbolts_64 says:
oh, and send me your ym to my inbox please
Jan 17, 2009. 9:28 PMPyro the maniac says:
before I even saw this Instructable i saw it on youtube and had to try it i burned all the hair off my arm cuz i left to much alcohol in the bottles stupid on my part! Be cautious its stupid scary to be engulfed in a fireball created by leaving lots of alcohol in the bottle Not even joking the fireball was enough to make me feel like i was totally engulfed
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
106
Author:KentsOkay
Formerly known as RocketScientist2015. College makes you busy
