3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Launch It: The Paper Catapult.
Step 2The Throwing Arm.
The Throwing Arm.
  • last photo ←
We'll do the hardest single piece first.
The throwing arm has two ends (doh!), which both need folding properly to make it work.
1. Cut out the arm (cut all solid lines, score all dotted lines), and use the cocktail stick to pierce holes at the dots.
2. Fold the whole thing into a square-section beam. Glue the full length of the flap and allow to dry. You will be able to tell which way up the beam goes by looking at the writing down the sides.
3. At the "flippy end", fold the two narrow flaps over and glue their outsides. Fold the long central flap over the narrow flaps and pinch gently along the corners to make it stick. Glue under the end of the long flap to stick to the underside of the arm.
4. At the bucket end of the arm, there is a flap connected to the top surface of the beam. Glue under the end of the flap, and press it down into the beam - it should stick to the inside of the lower face of the beam, and block off the end of the beam at the same time, preventing ammunition slipping down inside the arm, which would be inconvenient.
5. Glue the outside face of the two side flaps and fold them over to make the back / end of the bucket. You should have one flap left - lift it up and stick to the outer side of the two flaps you just glued.
The arm is done. Set it aside for now.
13 comments
Mar 5, 2012. 4:36 PMsmpash says:
by cocktail stick you mean tooth pick right?
Mar 7, 2012. 7:17 PMsmpash says:
well in the us they are the same thing thanks though
Jul 19, 2010. 9:03 PMa_person says:
for astetic reasons one of the instructables logos is backwards on the throwing arm
Dec 19, 2010. 1:12 PMlunius says:
I noticed that too... It bugged me throughout the building process...
Kiteman, I'm going to put a mod on my catapult and perhaps make an 'ible for it, but I will point out that it is merely a mod, and that your genius is the cause for this amazing work of art :D
May 31, 2010. 6:20 AMJcBeaver says:
Thanks for the template
Sep 27, 2009. 11:21 AMnailguy says:
Hi made a comment that was last school year so i came back to make another one
Jul 4, 2009. 10:22 AMjp226693 says:
awesome
Apr 23, 2009. 3:46 PMnailguy says:
Thanks for the good pics i was stuck on this for a while but then i looked at the pics thx
Aug 25, 2008. 3:02 PMlobo_pal says:
Thanks for the great job on the pictures, really makes it easier.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
832
Author:Kiteman(The Complete Kiteman Shop)
"Happiness is a shed full of power tools." If you need help around the site, or with a project, feel free to contact me.
