Launch it: Cheap, Super powerful air gun.
Simple device made of PVC pipe, joints and a PVC ball valve. I made it for less than $25. It is very very very very powerful with an average speed of 200mph with reasonable accuracy and shoots anything that fits in the barrel...works best with potatoes,paintballs, crabapples, and acorns. !!ACHTUNG!! DO NOT POINT AT ANY LIVING THING OR ANYONE. THIS CAN BE LETHAL...ohhh...AND DON'T SHOOT MARBLES, I REPEAT, DON'T SHOOT MARBLES!!
Step 1Supplies
You will need: - 10feet of 3/4" PVC
- 2feet of 2" PVC
- 3/4" PVC ball valve
- Two, "T" joints
- Two, 3/4" PVC caps
- One, 2" PVC cap
- One, screw in Schraeder valve
- 3/8" drill bit for tire valve
- PVC cement and primer
- One, 2" to 3/4" adapter
- 2" Coupler
43 comments
1-40 of 43next »
Aug 15, 2011. 11:38 AMuseraaaaa says:
i do not understand this at all
Jul 17, 2010. 2:43 AMSnibbors says:
anyone play humans vs. zombies? Oh god... the amount of zombies that would cower at the sight of such monstrosities, if they were legal for the game, of course.
Aug 24, 2009. 12:15 PMcoggs says:
Why did you make it so long? I did mine and it's only about 4-5 ft long. I suggest making the air chamber a larger diameter one so it can store plenty of air without being so lengthy. Cutting off a foot or so from the barrel should make it a lot more convenient and mobile IMO. I have mine hooked up to a dive tank that has a low pressure (200 psi) hose with a bike filler at the end so it only takes like 10 seconds to fill.
Oct 15, 2009. 9:15 AMdavmaldo says:
also, it'll go further is the barrel is shorter, less frictional losses.
Oct 15, 2009. 9:14 AMdavmaldo says:
if you wanna increase pressure fast put water in pressure chamber. Noncompressible fluids rock! Also, you can spray everyone with some wateris no ammo is put in!
May 17, 2009. 5:57 PMFull Metal Jacket says:
i made one of these only i used 3" pvc for the tank and a 4 foot barrel (with the 3/4 pvc) and it launched a 5/8 ball bearing about 200 yards no joke! i only put 100 psi in it and used wadding around it. oh yeah it only took about 3 hours for the glue to dry.
Feb 3, 2009. 2:50 PMpotatoecannonfreak1995 says:
a couple of changes for you , you have to wait 24 and more hours for it to dry also dont use a 3/4 valve it doesnt let enough air out
Dec 27, 2008. 7:59 PMtmuterspaugh says:
my Cannon is much stronger than this, mine is made of 3/4 in pvc and it can shoot a AA battery thru plywood when the battery is going sideways, and it can shoot metal rods thru trees.
Aug 22, 2008. 1:53 PMBeav22 says:
do you really need the 2 coupler?
Aug 8, 2008. 7:05 AMkibbler says:
you copied the mythbusters! Bad Boys!
Aug 30, 2007. 6:17 AMpaaiyan says:
Uh, no offense man, but this cannon is not "very very very very powerful." That's really just a run-of-the-mill cannon you've got there. If you want a cannon, look here. http://www.spudfiles.com/forums/gb-semi-t7899.html
That cannon of yours isn't bad, I'm just pointing out that it's not as powerful as you make it out to be.
Jul 6, 2008. 9:05 AMtwenglish1 says:
the way that looks to me is a paintball gun on steroids
Aug 30, 2007. 2:26 PMDeusXMachina says:
I didn't recognize you without the bunny with a pancake av :-P I love that thing! I wish I had one like it but the Guillotine is taking up most of my time. 2000 feet....THAT is very very very very powerful.
Aug 30, 2007. 2:31 PMpaaiyan says:
I got the bunny :D
Aug 29, 2007. 5:41 PMEasy Button says:
So,basically this is a potato cannon?
Aug 29, 2007. 11:17 PMll.13 says:
Yes.
Sep 18, 2007. 7:07 PMguyfrom7up says:
:/ I personally don't like your voice, but that's just me. That cannon was not super powerful, and it looked extremeley dangourous holding a pipe that's bending from being so long (that's what she said!) and trying to shoot something out of it Have a nice day!
May 25, 2008. 10:24 AMfishyfish777 says:
"And trying to shoot something out of it" That's what she said.
Jul 6, 2008. 8:58 AMtwenglish1 says:
"its bending from being so long" thats what she said to me!!!
Jan 26, 2008. 7:30 AMjakkeychain says:
not a potato cannon, potato cannons use a small explosion to shoot theres. This is pneumatic. Which uses air to shoot it, Or at least thats what i think. This doesn't clearly show. I used a Tire Valve to get air in mine, but this instructable doesn't show how to at all. I've made this b4 but out of 1/2 inch pvc to make paint ball gun. And ammosmok is right you don't have enough air to have such a long barrel, u get more air then me and i use a 3 foot barrel.
Jun 2, 2008. 2:34 PMRye says:
Is it necessary to have a long barrel on this sort of cannon?
Jan 27, 2008. 5:15 PMfrankinator says:
if they are pneumatic they can still be called potato cannons they are just pneumatic potato cannons theirs pneumatic and combustion
May 10, 2008. 5:36 AMfinnster says:
y cant u shoot marbles
May 25, 2008. 10:22 AMfishyfish777 says:
they go through anything and are super dangerous.
Apr 20, 2008. 5:54 PMshadow dragon2 says:
nice dace
Aug 30, 2007. 10:19 PMirwinner says:
all right i have seen far to many ball valve cannons on this site, you people don't even know the meaning of true power. i shall enter this contest to show you noobs how its done.
Mar 8, 2008. 8:52 PMpandaboy292 says:
no there is to many knex guns and pen guns.
Jan 28, 2008. 2:18 PMjakkeychain says:
yea i hear you, i just usually think of potato guns as combustion instead of pnuematic, Combustion are easier and more powerful to me. Easier in the since i dont have a compressor so i either have to hook a small one up to car or go manual with bike pump.
Nov 3, 2007. 4:11 PMgunsnbooms says:
Hey this is pretty cool I love using it. Keep Inventing!
Sep 19, 2007. 7:08 PMAmmosmoke says:
Uh, hello dc, it says right on the side that it is rated up to 450psi... for sch40 3/4, and for sch 40 3" its 140psi... He's just fine in that department. But the barrel is far, far, too long! Its affecting your performance!!
Sep 9, 2007. 5:13 PMgunmanx says:
ummm why dont u shoot marbles
Aug 30, 2007. 2:28 PMDeusXMachina says:
Yeah umm....you need to wait like 24 hours, not 2-3 for PVC solvent to dry.
Aug 31, 2007. 10:10 AMirwinner says:
just trust us we know what were talking about. i let a cannon dry for about 2 hours once went to pressurize it and it shot a heavy plastic chamber about 20ft behind just barely missing a friend standing behind me.
Aug 30, 2007. 6:57 AMjoejoerowley says:
Why not attach a little nitrogen tank to it!! Then you will have a "very very very very powerful" spud gun!
Aug 30, 2007. 10:21 PMirwinner says:
becuase that will most defiantly end in a trip to the hospital nitrogen is 1000 +psi i bet the PVC wont take more than 300 psi, and you cant pick up pvc shards in x-rays
Aug 30, 2007. 7:34 AMKiteman says:
Is it just me, or is that thing a bit droopy? It does not look as rigid or strong as you need a pressurised cannon to be.
1-40 of 43next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:9732246250
