3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Scale Wooden Crossbow
version 2
version 1
In this Instructible I will show you how to:
-Create your own scale (1m,1m) crossbow that is powerful enough to punch holes into various items.
-Bow saftey
-where to get materials
-what tools to use
-prices and information
-general tips on fine tuning
(4 years later: please note that I no longer post to this website, I post my projects here now: http://sites.google.com/site/paulmprojects/ )
Step 11: gathering materials & general instruction information:
Materials:
-a 2/4 (preferrably a soft wood like pine)or any wood that is wide enough for your adapted crossbow.
-at least tow peices of bamboo
-kite string (a nylon string NOT WIRE)
-a wrappable wire
-door latch (see photo)
-string
-assorted nails and screws (of the 2" and 1" varity)
::note::All these materials came from a mere two stores; Home depot(wood and door latch) and Dollarmart (bammboo and kite string)
Tools
-hammer
-screwdriver
-file
-nippers
-pliers
-file (small)
-sandpaper
-saw
::note:: I used a band saw, although it is not made for wood, you can use any other saw you see fit (wood saw that is)
149 comments
1-40 of 149next »
Jul 29, 2011. 5:03 AMbwells2 says:
Could it hunt game?
Apr 30, 2011. 3:02 PMJim123456789 says:
did you add a like a rail to the firing ditch
Mar 12, 2011. 11:50 AMknex gun instructions says:
that door latch is called elbow cacth
Jan 9, 2011. 2:40 PMmeburnfire says:
Say, would 1/8th inch 3 strand twisted nylon cord work as the bow string? Cuz thats all that I have, so would it work better or worse?
Oct 11, 2010. 3:49 PMEgor22 says:
Well my Friends sister told about this site and she was right about how awesome it is haha
Jan 20, 2009. 9:42 AMmatthiasofgondor says:
I couldn't find peices of bamboo like that anywhere I looked around town. What exactly did you use and what were they called?
Jan 4, 2010. 7:30 PMwangtrevor says:
im not sure but would i pvc pipe work
Jan 24, 2009. 8:58 AMmatthiasofgondor says:
i may have been confused on the thickness of the bamboo than. If at all possible do you think you could give me guestamate of the thickness and length? Thanks for the help :D
Jul 17, 2008. 5:17 AMminerug says:
Since the crossbows of old had steel or metal bow bits (I don't know the proper term) is there any instructable that have metal bow on a wooden stock arrangment?
Nov 18, 2008. 5:47 PMred-king says:
by bow bits do you mean the limbs and the trigger?
Nov 18, 2008. 11:54 PMminerug says:
yeah, I probaly maen the limbs
Aug 29, 2009. 6:39 PMPhoghat says:
If youwant to use a car spring, iy's going to have to be de-tempered, rebent, and tempered again. I saw one made on TV. Meanwhile, try<br/><a rel="nofollow" href="http://blog.modernmechanix.com/2006/08/01/build-a-hunters-crossbow/?Qwd=./MechanixIllustrated/12-1953/crossbow&Qif=crossbow_0.jpg&Qiv=thumbs&Qis=XL#qdig">http://blog.modernmechanix.com/2006/08/01/build-a-hunters-crossbow/?Qwd=./MechanixIllustrated/12-1953/crossbow&amp;Qif=crossbow_0.jpg&Qiv=thumbs&Qis=XL#qdig</a><br/>
Oct 16, 2008. 2:46 AMgrevious says:
and when ur done that post it aswell please? :D
Aug 8, 2008. 12:04 AMminerug says:
Ok
Mar 21, 2009. 6:20 AMknex gun instructions says:
is there a name for the door lacth?
Mar 21, 2009. 6:16 AMknex gun instructions says:
what kind of string did you use?
Feb 16, 2009. 5:46 PMShadowblade52 says:
hey im confused about one of the measurements at the bottom of the drawing. Why is the 5 cm mark put on there on not closer to the top?
Jan 31, 2009. 5:07 PMchickenliver123 says:
hey, i love this instructable, cannu tell me where to get the door latch?
Jan 24, 2009. 4:14 PMhughligen says:
bamboo is really inefficient for bows/crossbows. try yew (type of wood) it's what most bows used to be made out of. nice instructable though. :)
Jan 20, 2009. 9:44 AMmatthiasofgondor says:
what is a reef knot tie? it seems (according to the picture) similar to a slip knot?
Jan 1, 2009. 9:05 AMkaos863 says:
I made a composite bow using high carbon steel and red oak. It has a pull of 80lb.
Dec 13, 2008. 12:43 PMShadowblade52 says:
Hey you said to use a small file. What exactly is that for and what size is it exactly?
Dec 14, 2008. 11:19 AMShadowblade52 says:
okay thanks haha but what do I use it on because i couldn't see where you used it...
Aug 2, 2008. 6:59 AMMethAne says:
hello there. I made a crossbow these days, and it's pretty different from the yours. now, i have a question; can i use the fishing wire?
Aug 2, 2008. 7:15 AMMethAne says:
and yes, my trigger is a clothepin and one elastic
Nov 10, 2008. 1:57 AMQwertyuioLP says:
I've got a different trigger kinda like yours but is doesn't use elastic bands to hold it down. What I did was cut about 1-2 cm off the bottom of a wooden peg whacked a nail through the top and cut it off about 1/2 way. Then I just glued it on and put a nail through the back of the peg. Works wonders.
Nov 4, 2008. 10:37 PMcheeseboy says:
nice, it looks very cleanly done
Sep 20, 2008. 5:46 PMnaruto 777 says:
i might make one of these, differint firing mechinism tho, my friends little brother likes to shoot use with wimpy airsof, lets see if they shoot me if i have one of these, oh one sugestion, if you make a longer bolt (so the point is over the edge of the xbow) and you put cloth on it, you can put the cloth on fire and you have a fire bow! or you could fill up a peice of cloth with gun powder, stick a long fuse in it, you got a bomb, you put that on a bolt or arrow (probably wont go far) you have an explosive arrow/bolt, DISSCLAIMER: I'm not resposible for what you do with this information, so if you burn yourself, or blow yourself up with this, IT IS NOT MY FUALT!!!!!!!!!!!!!
Aug 1, 2008. 6:58 AMAsish says:
I have some questions. 1. how do you take of the head of the nail for the arrow 2.when you wrap string in the center of the bow and you drill a hole in it, wont it get tangled up 3. can you please make a video on how to make it thank you
1-40 of 149next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:paulm(Paul's Projects)
I am now an engineering student
