Introduction: Laundry Sorter
Picture of Laundry Sorter
I saw a laundry basket organizer on Etsy, it was made out of wood. The unit was over $200. Since I was looking for a temporary solution to fix a problem we decided to use PVC.
Materials
(4) 1” x 10’ 450 Schedule 40 PVC Pipe
(3) Laundry Baskets 1.7 Bu./ 60 L, Length: 26.0 Width: 18.38 Height: 12.5
(12) 1" PVC Tee Fitting
(8) 1" 3-Way PVC Elbow Fitting
(4) 1" 4-Way PVC Tee Fitting
(3) 1" PVC Cross Fitting Connector
Tools needed
PVC Cutting Tool
Rubber Mallet
Tape Measure
Crayon or Marker
Step 1: Measure and Cut PVC
Picture of Measure and Cut PVC
If you are using smaller or larger baskets, you will need to adjust your measurements. Our measurements were so that the holder would fit in a certain area and be large enough to hold the laundry baskets we choose. We used a crayon and marker to mark the PVC and lined up the marks with the PVC cutting tool. (4) 1” x 10’ PVC Pipe cut to:
(8) 1” PVC Pipe cut to 15”
(18) 1” PVC Pipe cut to 6”
(18) 1” PVC Pipe cut to 12.5”
Step 2: Assemble Bottom & Top Layer
Picture of Assemble Bottom & Top Layer
For each Layer you will need:
(4) 1" 3-Way PVC Elbow Fitting
(4) 1" PVC Tee Fitting
(1) 1" PVC Cross Fitting Connector
(6) 1” PVC Pipe cut to 6”
(6) 1” PVC Pipe cut to 12.5”
Connect the PVC pipes and Fittings. See photo for correct orientation of Fittings and location of PVC pipe sizes.
Step 3: ​Assemble Middle Layer
Picture of ​Assemble Middle Layer
You will need:
Step 4: Build the Unit
Picture of Build the Unit
Attach (4) 15” PVC Pipe to top of the 3-Way PVC Elbow Fitting on the bottom layer (see photo)
Step 5: Build the Unit
Place the Middle layer on top of the (4) 15” PVC Pipes from the Bottom layer. (see photo)
Attach (4) 15” PVC Pipe to top of the 4-Way PVC TEE Fittings on the Middle layer. (see photo)
Place the Top Layer on top of the (4) 15” PVC Pipes from the Middle layer.
Step 6: Secure Fittings
Picture of Secure Fittings
Using the rubber Mallet, Tap each of the Fittings against the floor.
Step 7: Completed Laundry Sorter
Picture of Completed Laundry Sorter
Step 8: Add Back Support
Picture of Add Back Support
Our unit is wedged in between two units and a wall but if yours will be more open you may want to add back support. All you need to do is change out some of the fittings and add support poles.
Material List for Unit with Back support
(5) 1” x 10’ 450 Schedule 40 PVC Pipe
(9) 1" PVC Tee Fitting
(6) 1" 4-Way PVC Tee Fitting
(1) 1" 5-Way Cross PVC Fitting
(5) 1” x 10’ PVC Pipe cut to:
(10) 1” PVC Pipe cut to 15”
MillennialDIYer (author)2017-11-14
Oh...and me hope for a Laundry Sorter that would sort my laundry for me... ;)
tomatoskins (author)2017-11-14
What a great idea! Much better than the piles of laundry I have around my room. :)
About This Instructable
643views
12favorites
More by flyinggems:Laundry Sorter
Add instructable to:
