Lawn Tractor Tool Carrier
2,442
16
6
Published
Introduction: Lawn Tractor Tool Carrier
About: If I can make it myself, I will. If I think I can make it myself, I'll try. If I can't make it myself, I'll improvise.
Here's a simple and cheap tool carrier for a lawn tractor. It cost about $5.50, and makes it easier to carry yard tools while mowing the lawn!
Step 1: Parts and Tools Required
Parts:
Waste paper basket - This one is from Home Depot, and is made of nice rubberized plastic that should hold up well outdoors. Cost $4.99
Bolts (2 or 3)
Nuts (2 or 3)
Washers (2 or 3)
I used 1/4"-20 x 1-1/2" bolts, but a larger size or more of them can be used if you want to carry more weight
Tools
Drill
Drill Bits
Socket wrench or crescent wrench
Measuring tape
Marker
Step 2: Where to Mount
Find a flat spot on the back of the lawn tractor body. You will be drilling through the body, so make sure you locate a spot that has no wires or mechanical parts behind it.
Measure and mark a location for 2 or 3 bolts that fits the width of your waste paper basket. Drill these holes to the size of your bolts, insert the bolts, and put nuts on temporarily.
Step 3: Align the Carrier
Find the height you want for your carrier, keeping ground clearance in mind. I set the bottom of mine right on the hitch plate. Once you are satisfied, press the waste basket against the bolts from the inside of the basket. The bolts will mar the soft plastic, making it easy to drill in the right spot.
Step 4: Make Some More Holes
Find the bolt marks on the waste basket, and drill these out. While you have the drill in hand, add some drain holes to the bottom to let water run out.
Step 5: Attach
Remove the nuts, mount the basket on the bolts, and put washers and nuts on the inside. Done!
Step 6: Use!
There you have it! This makes it easy to carry shears, a large drink, gloves, trash bags, and my favorite - the long reach pick up tool!
    • Stick It! Contest
      Stick It! Contest
    • Backpack Challenge
      Backpack Challenge
    • Oil Contest
      Oil Contest
    6 Discussions
    Fantastic! Simple! I always struggle to pick up all trash before mowing to keep from having to stop and get a piece. With the grabber tool, this would be a snap. Thanks!
    Welcome! I got my grabber tool from Harbor Freight for $2. It's amazing how easy it is to grab even small stuff, and it can also withstand some weight. It's good for small twigs, branches up to 2" diameter, fist sized rocks.... just great all around!
    Go for it! Let me know how it works out! After almost 5 months, the Home Depot waste basket still shows no sign of weathering.
