Introduction: Lawnmover Becomes a Superficial Motorized Hoe
My New Instructable Covers The Transformation of a Common Grass Mower into Something Similar to a Weed Wacker.
This Project takes a Normally safe Mower and turns it into a Rather Dangerous piece of equipment that in my case, for what I needed turned out fine. This transformed machine can be dangerous both in the actual conversion as well as in the use. So please if you choose to do this "Conversion" please take extra care and precaution as I asume No Liability.
Please feel free to correct or add to my project.
Step 1: Remove the Superfluous Operation
-First I removed the wheels
Step 2: Dressing.
Step 3:
.Now we have arrived at the Heart of the Conversion, The Blade. The blade will be turned "Upside Down" so that the tips will be closer to the ground. Now making it capable of actually touching the ground will be just a matter of slightly bending it by pulling the tips of the blade towards you. After the blade has been "Bent" correctly it should be removed again and sharpened along the New Cutting Side and then remounted.
Step 4: The Ride Height Wheel
Step 5:
It took allot of practice to learn to used the machine, but I figured out it was much easier to use the machine by pulling it backwards than pushing it. Also using multiple passes and taking small cuts seemed to be the best approach.
And I must say The Results Were Really Incredible!
Step 6:
Step 7:
Special thanks to RedMeanie for his substantial aid in the translation of almost all stages of this instructable.
Goodbye to the next instructable. Thanks to the attention!
