Layered Swirl Earrings
Introduction: Layered Swirl Earrings
I wanted to try out this layered swirl earrings which I had been thinking over since the Jewelry contest came up.Finally I managed to do it.Yes! my idea worked out well,and it is quiet easy to make.So go ahead and try it out.
Step 1: Requirements
What you need to make this pair of Earings
Craft wire
Glass beads in two colors
Round nose plier
Wire cutting Plier
A pair of earring Hooks
3 Rods -in different sizes -I have used a knife sharpaner and two screw drivers
Step 2: Cut Wire
Cut wire in three sizes.The longer you cut,the more beads you need and the earrings will have more swrils
You must cut a little bit longer than the required size,and cut of the excess wire later.
Step 3: Insert the Beads
The longest piece of the wire I cut is 14 inches.
I had a small amount of red beads, so I mixed it with the white glass beads.Fill your wire with beads.When you are filling make a small twist on the other end, to prevent the beads falling.If you want you can do with just one color only.
Step 4: Wrap.. Wrap ..wrap......
The longest piece of wire is wrapped onto the thickest rod. That's the knife sharpener number 1.
The second and third beaded wires have been wrapped on the screw driver.While wrapping make sure that the beads are intact close to each other.Cut the excess wire and using the round nose pliers to twist a small loop on both ends on all three beaded wires.
Step 5: Attatch Together
Attach all three beaded wire rolls together the smallest being on top, by inserting a small piece of wire through the loops on both ends.You can slowly curve the bead rolls to make a nice shape.Once you connect the bead rolls together twist the wire ends together and turn it under so that the wire joins are not visible.(image 4) Please refer images ,you will understand better.
Step 6: Fix the Hooks
Finally fix the Earring hooks and admire your great work.
Thank you for taking time to view my lovely pair of layered swirl Earrings.
    • Trash to Treasure
      Trash to Treasure
    • Paper Contest 2018
      Paper Contest 2018
    • Pocket-Sized Contest
    I can't believe I missed this ible! Love everything swirly, nice work :)
    Great idea nice ones... :)
    Nice design! Also, well documented :-)
    Quite lovely....Thanks for sharing :-)
