Step 9Technical notes: effect of inside line-drying on heating and air conditioning
have air conditioning or not.
In hot, humid conditions, the evaporative cooling will still happen, but the added humidity may make the air overall slightly more uncomfortable, so it's better to hang the clothes outside. But the two effects partly cancel, so it's still OK to hang clothes inside if that's most convenient.
In the winter, many houses are overly dry inside, and the added humidification can be helpful. The small evaporative cooling effect will need to be overcome by the heating system, but, unless you have electric heat, this is reasonably efficient and much better than running an electric humidifier, and that's before even considering the energy savings from avoiding using the dryer.
If your house is very dry in the winter, this may be an indication that there are air leaks in the building envelope or ducts. If you get it sealed well enough that humidity gets higher than you'd like, it may be time to consider installing a heat-recovery ventilator. That will allow bringing in fresh, dry air and exhausting stale, damp air, without losing the heat in it.
In summary, drying clothes indoors can be beneficial to the indoor climate if it's dry inside, in either winter or summer. If it's humid inside, it would be better to dry the clothes outside, but it's still a lot better to line-dry them inside than to use a dryer.
I have an ongoing disagreement with a friend about whether it is more efficient to use my gas dryer to dry a load of laundry or to hang dry the clothes inside, in a big house which uses gas heat. I feel hang drying takes advantage of the ambient heat and dry air of the wintry months, when it's raining and I can't hang dry my clothes outside. He always contends that the dryer is an appliance designed to dry clothes, so it must be more efficient, and that hang drying would cost more kWh of energy in the end, because the whole house gets colder and has to be heated more.
Any idea how one could actually measure the efficiencies of each approach?
(Actually, if it's cold outside, even if the air exiting the dryer is at room temperature, it's wasting a bunch of energy, because for each cubic foot of air blown out the vent, there's a cubic foot of air sucked into the building from outside, which has to be heated by the heating system.)
On the other hand, with the clothes hung inside, the only extra heat you need is exactly the amount of heat needed to evaporate the water--that's how much the building is cooled by having them drying inside.
Since you have provided a really thoughtful answer, I wonder if you can imagine a scenario in which it would be less efficient to hang-dry one's clothes. And someday when I get a chance I'll try measuring the temperature as you suggest so we can have hard proof!
