loading
Step 2: Making a Mould
I need a mould for pouring molten lead in to unfortunately the best thing for this is a metal mould but they cost money unless you have a home foundry to cast your own. I decided that I would use what I know and make it from plaster which I had kicking around.
using my non-drying modelling clay I made a ball of roughly the right size, then made a rough cone which will form my sprue.
I cut it in half and lay one half on my desk.
Make a small ball and cut that in half and place the 2 halves on either side of the part to be cast, make them staggered, these will form our key for the mould making sure it will only fit together in the correct way and aligned correctly.
using the modelling clay build walls all the way round the part but make sure the bottom of the cone/sprue is butted up to one of the walls.
mix up your plaster to the consistency of thick cream, only mix up enough for this half of the mould, pour this in to the mould all the way to the top of the walls.
Agitate (shake gently) the mix to dispel any bubbles.
let your plaster harden then remove the walls and turn the mould over.
remove the small ball parts we used for the key, and then using a hobby knife carve off the edges of the key points so there's no overlap.
now place the other half of the part on top of the one in the plaster, line it up and push down lightly to make it stick.
now build walls again high enough so they come above the highest point of the part.
coat the plaster and the 2nd half of the part in a thin coat of petroleum jelly, this will act as a release agent and stop the plaster sticking to its self so we can separate the 2 halves.
now mix up some more plaster and pour it in to the 2nd half, agitate again and then wait for it to harden.
once its hard remove the walls and separate the mould, remove the clay from the mould.
now you can wait for a couple of days for the mould to dry out or you can cheat, pop the 2 halves on a baking tray separately, pop in a cold oven then put the oven on low and leave for a few hours to get the water out the moulds.
do not cast with wet / damp moulds, they will crack/crumble or explode.
would it be possible to pre-heat the mold in an oven/toaster oven to try and reduce the effects of heat shock?
thats exactly what i did when i started but between casts it cooled too much, i should have put it back in the oven betwen casts
<p>the 'frog' of a house brick makes a fantastic ingot mould- you can pour them shallow for small amounts..... never any problem with sticking, and they hold the heat well.</p>
<p>I have about 50lb.s of pewter plates. They are scratched beyond saving I was wondering if I melt them, could I use them for making jewelry? </p>
<p>yes- our art college was buying battered old pewter mugs as it was a lot cheaper than buying 'new' ingots.</p><p>I am concerned by the use of plaster moulds on this page- ANY moisture in the plaster and the hot metal will splatter all over the place when it hits and makes steam- 'warming the moulds' is not enough. traditional bronze moulds were plaster and crushed ceramic (brick?) baked for 24-48 hours to melt out the wax and properly dry the mould, lead and pewter can now be safely cast in high temp silicone- which means you can do a run rather than single objects. </p><p>Melting lead? well ventilated space, fume mask if you are doing this regularly, always wear Eye Protection- stupid not to?</p>
I can't see why not, you could make molds out of plaster, as long as you heat the molds before you pour they should come out well.<br><br>when you have done some post them up here, it would be nice to see.<br><br>try a bracelet you could do that flat then bend it to shape afterwards should be nice and easy.
<p>I appreciate your will in teaching these things to us. My problem is different: I have to make a mold to cast lead from a piece I can not duplicate or make myself. It's a rectangular piece (1X1X4&quot; long), that has two 'rings' around itself, made out of steel. Do I need to make a plastic or clay mold out of it?</p><p>Thanks,</p><p>john</p>
Hmmmm, well you would need to make a mole that flexible, so I would use silicone to make a block mold of the original probably a 2 part mould. Then pour hot wax in the mould to make a wax copy. Using that you can use a technique called lost wax casting. Coating the wax in plaster letting it set the. Slowly heating it to melt the wax out. Then you can pour lead in that, break the mold to get the part out.
<p>I joined specifically so I could post on this instructable because I have some questions.</p><p>1) I assume since I didn't read it in page five that you didn't use a release agent when you poured the lead into the mould, is that correct?</p><p>2) I plan to use your instructions to make open faced press moulds for moulding bases for the game Battletech. The bases are just flat hexagons roughly an inch and a quarter from any two opposing flat sides. I would assume I would just replace your half ball and half cone with one or more of the bases for the game, pour in the plaster as per page two, then follow the rest of your instructions?</p><p>3) Is there a specific kind of plaster I should be looking for?</p><p>Thanks so much for all the inspiration thus far.</p>
no release agent, if you are pouring just hexagons you could probably just use half a mould. plaster wise, it depends on how many casts you want really, but almost any will do but you want to make sure its really dried out before using it otherwise it will crack.<br><br>any reason you are not using a silicone mould and pouring it with liquid plastic? probably be cheaper.
<p>Mostly because I have two full lead sheets (about 25 pounds or so each) and around 15 to 20 pounds of pewter/lead/palladium/raladium sprue and shavings from miniatures that I'd like to make use of, and I prefer the weight of metal bases for the larger minis, though your idea of silicon moulds and plastic bases for lighter minis would probably work well.</p>
I know this is a while after you posted this, but two questions. 1) what kind of table did you use when pouring your plaster mold? I've never worked with plaster before and I don't know if &quot;sticking to the table&quot; is something to worry about or not. 2) I have a Coleman two burner camp stove...will that really be hot enough to melt pewter? I know pewter has a melting point close to 500 degrees F, and people in the chat say a camp stove would work...I just didn't realize camp stoves got that hot. Thanks.
if you are worried about your table just put some plastic down or put it on a plastic board or glossy piece of card.<br><br>yes a camping stove would be fine.
<p>i studying about lead casting,, nd cast from lead acid baterries,,we can produce upto 95% of lead from an baterry but the problem is antimony and salenium,,how can i reduce these two element..both have high melting point than lead,,if we are going to reduce antimony so lead will ixidised ,,and either going to cast lead,,,so the recovery in only 60%,,,so what can i do,,,</p><p>pls help me,,to figure out the problem,,</p>
<p>I know it has been a long time since you asked this, but whatever.</p><p>Antimony's melting T&deg; is about 630&deg;C, and lead melt at just 330&deg;. So if you just heat your thing between these 2 temperature, you'll be able to isolate the lead (liquid) and the antimony (solid).<br>I hope I help anybody =)</p>
Honestly, i have no idea, I didn't study chemistry at school :-( probably best to google it.
<p>could you use silicone as a mold? It's supposed to have heat resistance up to 700&ordm; F</p>
I guess so, never tried it, there is silicone that will work well with heat
<p>would I be able to cast molten pewter onto a fissured table top that has been made out of wood? The voids are linear streams where the wood has decayed. The rest of the lumber is sound and hard.</p>
<p>hmmmm, maybe, I would soak the wood first to prevent burning, and then quench the metal right after pouring by pouring cold water on it. I would try it out on a test piece of wood first.</p>
<p>Please don't do this, you will end up very sorry and probably inside an ambulance! Moisture and hot lead do not mix, in fact they result in an explosion - usually meaning boiling hot lead being sprayed all over. Wood really isn't the best type of mold - rather look at using ceramics (not plaster of paris) or one of the commercially available mix kits.</p>
<p>I cast lead fishing sinkers and here's a few tips:</p><p>#1 Avoid moisture (water) on or in the lead, causes explosion (liquid lead every where, including you if close enough)</p><p>#2 Preheat your molds if you can. Helps with flow and gets rid of moisture.</p><p>#3 If your going to do a lot of casting take your bulk lead and make ingots first. This helps two ways. It allows you to get ride of the impurities and also makes adding lead to your pot easier. Typical ingot casting pan is cornbread cast iron pan. You can also use stainless steel measuring cups (allows to to make any size ingots based on what your doing).</p><p>#4 Wear long sleeve shirts, welding gloves, and some sort of face protection (face shield). If your casting outdoors (Preferred) a simple dusk mast will be fine as long as you have airflow and your not hovering right over the melting pot a lot. Of course the level of protection is up to you. You feel you need a respirator then use one.</p><p>Lead is a poisonous heavy metal that over the many years of use has been linked to many deaths and cause of many illnesses. It is being phased out thru the USA (Starting to ban the use of lead in fishing weights, lead bullets, and other stuff). The use of lead is entirly up to you, but please check your local and state laws concerning it and it's use.</p><p>One phrase I always live by &quot;When in doubt, check it out!&quot;</p>
Safety Note -- As a jeweler, I appreciate the qualities of pewter. The problem is that lead is a heavy metal poison and should be handled approiately. <br> Do not melt lead without very good ventilation and/or appropriate respiratory protection. <br> Always wear an apron and a work shirt that you can take off so as not to minimize cross contamination when working lead and lead based white metals. <br> Also, look for &quot;Britannia&quot; metal. It is a lead free pewter that works really easily. <br> <br>Just my 2 cents for what I consider to be one of the top 10 coolest sites on the net.
Find old car batterys. Empty the Acid out into a plastic bucket. Mix up some drain cleaner.(draino) Pour it into the battery shake it up a bit. Then pour the contents into the Acid in the plastic bucket. This will neutralize the Acid in the battery case &amp; the bucket. Smash open the battery &amp; there you have lead. Put a little Draino in the pot when you melt the lead, otherwise it tends to be acidic &amp; will slowly eat through the bottom of your tinnie, (boat) <br> <br>That's what we did when we were kids. There's nothing wrong with us, with us, with us. ;-) <br> <br>Go to your local fishing store. They have sinker moulds, if you just want round lead balls. Don't put a greasy wire through where normally the holes would be.
<br>Mr. Jay. You are absolutely right! <br>Tired of working with molten lead. If it were so poisonous, I would be killed by lead poisoning. <br>
Casting is fun! Very nice instructable. <br> <br>Please also mark the tins/spoons/pans in some way so that they are never used for foodstuffs again by accident!!
thats not going to be an issue, the tin ends up blue at the bottom and has lead stuck to the bottom, just a little. and the spoon is bent
where did you find the lead? <br />
they were off cuts, i got them off my dad who collected a lot of it years ago, you could try asking a builder is he has some off cuts but some times they keep it and sell it to a scrap yard.
in the us, we don't use much lead in homes anymore. wheel weights are lead. pry them off of old car rims, and cut out the steel rim clip.
intresting, what do they use for flashings?
for roof flashings around vent pipes we have a product that has an aluminum, or steel plate that mounts to the roof, and a neoprene gasket that fits around the pipe with a water tight seal. i replace the old lead ones that leak all of the time. most other flashing is made with either aluminum, or a neoprene membrane with adhesive on both side that seals around fasteners. the epa has regulated the use of lead in homes, in both paint, and materials. i have worked on some old houses that still had lead plumbing, but we haven't used it in decades. i know in europe they still have buildings with lead roofs. never saw one here.
Old fishing weights can be made of lead.
You must be single and live alone. When I was a kid, my mom would have shot me for doing this on her stove. Now my wife would kill me just the same. I think maybe a single burner stove out side would be needed for this. I may just try this to make diving weights using a muffin top tin like you did. I think I will try to heat it with a propane torch in a tin can. Good Photos.
I would have used a camping stove but i couldnt find it, my cooker is right by the back door so fumes are not an issue. <br /> <br />my mrs is really understanding she knows i do mental stuff now and then and has come to accept it.
At first I melted scrap lead into ingots using a charcoal BBQ and a hair dryer as blower. I got a 2 metre metal tube &amp; put one end in the fire and the hair dryer blowing in the other end (so the girlfriend's plastic hair dryer was not melted). I just set the cast iron pot in the fire. The charcoal melted lead fast &amp; easily. I melted 100 kg of scrap with charcoal before changing to the camp stove. Altogether my $6 cast iron pot has melted about 900 kg of lead. 8 kg in the iron pot is as much molten metal as I can safely lift and pour. Some people use ladles which is easier but takes longer. <br>
lead + cooking tin = geeeeeennniiiiiiuuuusss
You could just buy some steel bearing balls
Ball mills usually need to have &quot;non sparking&quot; balls...
give that man a star, yes most people use ball mills to grind materials for pyrotechnics, so you dont want any sparks otherwise you could blow your self up. <br /> <br />and I also wanted to use what I had around me, and I'm out of work at the moment so I dont have the money spare to buy ball bearings for test.
So you shouldn't be breathing in or licking fingers when working with lead? <br /> <br />Or rather, you should be wearing respiratory protection and gloves to avoid being poisoned? <br /> <br />Yikes!
Thanks for this Instructable. From my own experience I would not recommend melting lead indoors. Lead fumes are both toxic and stinky. <br /> <br />A Coleman stove and a small inexpensive cast iron pot work well outdoors. Proper clothing and safety gear are a must - long sleeves,shirt buttoned, long pants, leather boots or shoes, good gloves, and most importantly eye and/or face protection. Some people also recommend a lead respirator mask - they are not expensive, and melting lead does produce a lot of fumes. <br /> <br />A good rule to follow is: never add cold scrap to a pot of molten lead. Some scrap - range lead or wheel weights, for instance - has holes or voids that may trap water. Adding these to the melted lead can cause molten metal to spatter - sometimes violently - from the pot. <br /> <br />Rule of thumb: Fill the pot, melt it, then pour the pot empty. You can then safely refill the pot with fresh scrap, and do another melt/pour cycle. <br /> <br />Thanks for the writeup. Casting can be enjoyable and useful. Have fun and stay safe. <br />
If you're casting modern pewter (90 Tin, 9 Antimony, 1 Copper) the fumes are not that much of an issue. Lead - yeah - well ventilated space, activated charcoal respirator, don't get your metal any hotter than you need to. (If it turns a slip of printer paper a golden brown after 15 seconds or so, it should be good.) <br /> <br />The big safety issue is making sure the plaster is REALLY DRY. If you have a drop of free water in there it will boil, and you'll get a very exciting demonstration that steam has a volume of more than 1200 times the same amount of water. Don't ask me how I know this.
must wear respiratory protection to avoid inhaling fumes.
Make sure wash your hands, also dross is easy inhale.
yes indeed, dont eat food or put your fingers near your mouth without washing your hands first
About This Instructable
164,289views
222favorites
License:
Bio: One day I shall own a Delorean.
More by n1cod3mus:Giant Wooden Connect Four Butterfly Coat Rack from off cuts Silcone Matrix Mould / Cavity Mould
Add instructable to:
