Leaf Vacuum Extension Using a Leaf Blower
Introduction: Leaf Vacuum Extension Using a Leaf Blower
Problem:  I have gutters that are on the roof of a two story house and even with a ladder, maneuvering to them to clean out leaves is precarious.  Here I present my solution.  I've taken my leaf blower/vacuum and grafted on a flexible "gutter extender."  In all this extends the reach of the vacuum to 7 feet.  I have attached a broom handle to the end to help maneuver the top and I put a 90 degree bend to help position the vacuum into the gutter.  The materials are wide enough that leaves don't clog it.  The total cost for new materials was $15.90.  12.49 for the Flex-A-Spout Downspout and 4.39 for the 90 degree bend.  Here's how it's made.
Step 1: Attach the Flex-A-Spout Into the End of the Leaf Vaccum
I cut the square end off the vacuum and then drilled a hole to fit a bolt going outwards.  I put washers inside and outside and fixed it with a nut.  I wrapped some weatherstripping around the Flex-A-Spout to make a tight seal.  I drilled a hole in the leaf vacuum and then fixed it all together.  There is enough play to get the bolt to go in easily.  Then I wrapped three layers of duct tape to make sure it is a solid connection.  When I don't need the extension, I just remove the duct tape and unscrew the bolt.
Step 2: Attach the 90 Degree Bend and the Control Stick
The 90 degree bend goes in the end of the extender.  Then I used a wire hanger to fasten to the end of the spout.  I then stapled the hanger to a broom handle and put duct tape around that to increase the strength.
Step 3: Drank a Beer
It's thirsty work.  This step is optional.
Step 4: The Grunambuloover in Action
This is a picture of the unit cleaning out a low level gutter.  The real beauty is when you are cleaning out the upper stories.  I find that i can still use the unit to pick up leaves on the ground too and in some ways, having the extension makes that job easier.  But I can take the extension off in about a minute if need be.
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    • Paper Contest 2018
      Paper Contest 2018
    What would happen if you attached the leaf blower to the bottom side of the gutter? :)
    Looks great! But why celebrate such a great idea with an ipa?
    That's a clever idea! Nice to see more of the stuff from your site on here.
    Thanks that is how I did it except for the broom handle I like they way you did it.
    Now I know it will work. Thanks for the video.
    dUCT tape getting in a shot at the original use. :)
    Great idea. I've had neighbors doing all kinds of wonky and sometimes unsafe maneuvering to get the leaves out.
    I was thinking that perhaps some dryer vent hose with it's end supported by the telescopic painters pole (very light but strong) might be helpful for a design like this as well.
    and earplugs for when the motor is on the shoulder lol...
    love it!
    I thought about that and looked at it but in the end feared the sharps it might pick up would shred the plastic. It would be interesting to try so let me know if you do.
    I originally thought this up during a recent storm/flood where I had to go on a ladder to clear a gutter that was clogged and flowing into my sons (newly painted) room.
    Nice. I've been doing this for the past 10 years with a Rigid 6 Hp shop vac. Used my snow roof rake 15 foot handle. Duct taped the vac hose to this ( Fred Green would be proud) and fashioned a goose neck from a section of my plastic dust collection piping and voila vacuuming leaves from my hard to reach eavestrough.
    Good design. Like the goose neck idea. My shop vac was lower Hp and when I first tried this I used 1 inch PVC pipe and that could suck up mats, which wasn't bad, but could not slurp them down. I'd think your rig would do the job well.
    If I could make a suggestion.
    There is a similar commercial product and it has a U shaped piece at the end that goes in the guttering. That will make it a little easier to use, and the machine a lot further away from your ears.
