Learn to Draw...Part One
2,826
9
Posted in CraftArt
Introduction: Learn to Draw...Part One
About: I'm a mad scientist that's not so much bent on world domination, but just to get rid of those pesky skateboarder kids down the street who can't seem to figure out that when a car comes...GET OUT OF THE WAY!!...
I saw this topic on the burning questions list, so I said to myself,"I'm an artist, so I should help ya'll out (besides the fact that I want a prize!)." That's what I'm hoping to accomplish here. The first thing ya'll need to know is that no one starts off as a good artist, I don't care what you've heard. Ya'll have to PRACTICE, not just say "I can't draw."
To start, I'll go over some basics with y'all (If you haven't noticed, I'm from the south). Most important thing to do is draw LIGHTLY, I can't stress that enough. If you bear down too hard, you'll make indentions in your paper that mess up your art. Also, put a few sheets of paper inbetween the sheet you're drawing on and the table. First you should practice CIRCLES. your circles will get progressively better. Draw 'em on everything! If you're in school, draw on your notes; if you don't go to school this drawing WILL be more difficult for you to get good at (due to the fact that you aren't confined to a desk all day with nothing to do BUT draw), but don't get discouraged! It's not that hard in the first place!
You should also practice the two othe basic shapes of ALL things: Squares(including rectangles), and triangles. If you don't believe me just look at the world around you...ya'll will see how they fit together. PRACTICE PRACTICE PRACTICE!
If y'all need help, I'll do my best to respond and work with you, posting your comments with the appropriate steps will help me out a lot though.
Step 1: Making Your 2D Shapes 3D
So you've got the first step down, Congratulations! Y'all are one step closer to being a good artist, since after this that's what you will be. Now, we'll start on shading (for this you should use a regular wooden pencil, pens and mechanical pencils can be used, but since ya'll are beginners use wood, make sure you have a good pink (not black or green or whatever) or kneaded eraser that won't leave marks on your paper(eraser marks, ironically, do NOT erase). If you don't know what a kneaded eraser is, it's a gray clay-like eraser, don't worry it's not required, but if you want one you can buy them at Michael's or some similar craft store. Now to the fun part (if this isn't fun for you, you should figure out why and try to fix the problem, otherwise, you won't be the best you can be.) take your pencil and draw a circle, don't worry if it's not perfect that's not what we're going for now. After you've drawn the circle decide where you want the light to come from. my drawings will always depict the light as coming from the upper left, you may wish to do the same. Light is the most important part of your drawings, without it they will appear flat and unrealistic. Luckily, it's very easy apply light to ya'll's drawings. start by lightly shading the entire circle; this will be the "color" of the circle (soon to be ball). Then, erase a SMALL circular section in the upper left quadrant of the circle. this is the reflection of the light. (the reflection's shape depends upon the light source, but for now, all light sources will be ROUND). Now begin to darken the opposite side of the ball, it should be pitch black on the "edge" and gradually fade to the base "color" of the ball as it nears the reflection. Now your circle is a ball, but something's missing...What's that thing that follows you wherever you go?....Oh, that's right, a SHADOW! draw the outline of the shadow starting from the base of the ball and moving to the left and up at about a 25 degree angle, or whatever looks right for your sphere. Then, loop back around to the left and bring the outline to the sphere about half a quadrant (22.5 degrees) above the base. Fill in the out line DARKLY. Wow! That looks so much better than that plain old circle! PRACTICE! Don't quit on me now!
Step 2: The Cone
So, you've got the sphere down, let's try CONES. They sound hard, but believe me they're one of the easiest shapes. Draw an equilateral (same length sides all around) triangle LIGHTLY. Now make the bottom side slightly ROUNDED, like an upside down ice cream cone some little kid dropped on the floor. Shade the entire cone like you did for the circle (base "color"). the light will be coming from the top left again. Use your eraser and erase a section on the left of the cone. It should be triangularly shaped. (big at bottom) It does not have to go up to the tip, but close to it. It should, however, touch the base(but don't erase the line that shows the outline of the cone!). Darken the right side, gradually lightening as you near the highlight(reflection of light) and pitch black at the edge. Shadow time! It's a bit different than the circle, start at the bottom, but a little to the right of the center. Then go straight right and slightly up (diagonally) and stop where it seems appropriate. Now, go straight left and even more slightly down until you hit the cone. Fill in the shadow and...Presto! It's done! Yay for practice!
Step 3: Cubes! ......you Might Want a Ruler, It's Not Considered Cheating!
Now for cubes, they're easy too! Actually all of this is easy, you just don't know it, once you do it, you're like "Man, I could draw all this time and I didn't know it! First draw a "Y" shape. It should be equilateral, and all of the angles should be the same. Think of it as a bicycle wheel with three spokes. (Leave out the rim, silly!) Now, draw a line going straight down from the right and left tips of the Y. They should be the same length as the "stem" of the Y. Draw lines connecting the bases of the lines, so it kinda looks like a book. Here's the hard part...draw two line from the right and left tips of the Y that above the stem. You'll be able to tell if it's not right, but if y'all drew LIGHTLY ya'll can fix it, no problem.
Once it looks right, shade the diamond on top VERY LIGHTLY (remember the light's from the top left). Shade the lower left diamond just a little bit darker, and the third diamond should be DARK. Now, slightly darken the right (and a little bit up) part of the top diamond; also, darken the right half of the right side diamond just a LITTLE bit, make sure all shades blend together. Leave the other diamond.
Shadow time again! (music and cheers) Our next contestant is Mr. Cube! He's a proffessor from Indiana who enjoys snake wrangling and doubles as a lion tamer on the weekends! Wanna see what you're playing for? (drumroll curtains part) It's a brand new SHADOW! (cheers)
Start by drawing a line from the base of the stem straight to the right and ever so slightly up, then anothe line diagonally up and right from that. Not bring it back to Mr. Cube moving slightly upwards. Don't worry, the pictures will explain much better than words. fill in the shadow...done! Now go PRACTICE some more. Feel free to experiment with light. Now ya'll just have to wait until the next installment, which will be PERSPECTIVE.
    • Trash to Treasure
      Trash to Treasure
    • Space Challenge
      Space Challenge
    • Science of Cooking
      Science of Cooking
    3 Comments
    Part II ! We want part II. (I've been drawing circles and cones now for 3 years now. S'getting a tad tiresome)
    Thanks for posting this, it'll be really helpful. But...please stop spelling "y'all" like that. :) Thanks again!
