Learn How to Join in the Round With Circular Knitting!
Published
Introduction: Learn How to Join in the Round With Circular Knitting!
About: Creatiknit.com ♥ Knit & Crochet designer ♥ Blogger ♥ Mom ♥ Tea drinker with a flair for all things whimsical & woodland ♥ Hi, I'm Angela, and I am the pattern designer behind CreatiKnit! I remember long a...
You’ve cast on the right amount of stitches, and you’re ready to start your project. Now the next big step…join in the round!
This fun technique is easy to learn and will allow you to work all those circular knitting patterns you’ve always wanted to try.
So let’s get you started on your next knitting journey!
Step 1: Getting Started
First, make sure your stitches aren’t twisted, they should all be facing upright with the cast on edge towards the bottom. Begin by inserting your right needle into the 1st stitch on the left needle. Lift that stitch off and over onto the right needle. It will now stay on the right needle.
Step 2: Next, Lift That Stitch Off and Over First Slipped Stitch, Onto the Left Needle. It Will Now Stay on the Left Needle.
Step 3: Now, Insert Your Left Needle Into the Original 1st Stitch on the Right Needle. (Not the Stitch You’ve Just Slipped)
Step 4: Next, Lift That Stitch Off and Over First Slipped Stitch, Onto the Left Needle. It Will Now Stay on the Left Needle.
Step 5: ​The Two Stitches You Transferred Will Look Criss-crossed
These two stitches have now connected your work, and you are ready to start knitting in the round. Place a stitch marker onto the right needle to mark the beginning of the round. The new 1st stitch on your left needle is now the 1st stitch & beginning of round.
Step 6: You're Now Joined in the Round!
And now ready to go forth and knit circularly! Find a variety of easy & fun circular knitting patterns HERE to get you started.
Happy Knitting!
    • Pets Challenge
      Pets Challenge
    • Stick It! Contest
      Stick It! Contest
    4 Comments
    My pattern say to slip last 3 sts from other end of needle onto a spare needle holding spre needle behind work with points facing the same direction as work k2 tog-- using 1 st from circular needle and 1 st from spare needle 3 times Is there a video of this Just is not computing in my mind Thank You
    Thank you so much for your explanation, I will definitely try the circular knitting needles, using 4 needles always becomes a disaster.
    this is where I normally give up knitting. Are you knitting here with 4 needles or just one which can go round? And what is the difference?
    I am knitting with 1 set of circular knitting needles, with the plastic cord between them.
    Double pointed needles are when you are working with 4 or 5 needles.
    You can knit in the round using both of the above methods. I like circular needles better for seemless looking projects, since you can see where you join when using double pointed needles (they are called ladders).
    When working in the round on small things like socks, double pointed needles are usually better for such small circumferences.
    Sometimes it just comes down to preference.
