Learning to Make (confidence, Knowledge)
342
Posted
Introduction: Learning to Make (confidence, Knowledge)
Step 1: Where to Start?
Start with a problem
Step 2: Problem Identified!
House drains are blrurbling and coughing up yuckky stuff!
Step 3: Old Metal Pipe Needs to Go!
I didn't take pictures of the dramatic battle sequence, but you can imagine it... A long, long time ago... The only original pipes in the house was my main stack and about 5 ft of low sloped drain pipe that had all food and gunkky discharge...that sounds pretty bad... But like a washer, kitchen sink, and dish washer. 30+ years old. Oh and hard water too!
Step 4: Procedure
I had to cut out the original horizontal pipe at 2 places, measure, cut and assemble PVC parts, then replace gunk pipe Mcnasty.
Guidance:
take your time and measure a thousand times, then you just do it; if you have to, cut it larger then it needs to be, you can always can take a little off as needed.
Step 5: I Did What I Had to Do!
I did it!!! And the best part is... I know that I can do more!!! I thought of the time before I tried and wish I just looked at a annoying problem with the conference and knowledge that you can do it.
P.S. Get input from a knowledgeable acquaintance, friend or family member that you would trust your life and well being with before you attempt to do anything that I write about. You may need much more assistance then I would be able to promise.
P.P.S. You can do it!!!!!
  • Gluten Free Challenge
  • Sew Warm Contest 2018
