Leather Coloring Pencil Case
Introduction: Leather Coloring Pencil Case
You want to make A pencil case, Don't have enough money, No problem, I well teach you how to make it
Step 1: What You Need ?
You need this tools :
1- Scissor
2- Ruler
3- Marker
4- Rubber
5-Coloring pencil
Step 2: Draw
First, You need to draw a line into the leather piece using the cover of the coloring pencil box, Now you have copy of the cover
You can use the marker or a pencil
Step 3: Amendment Measurements
Now You want a case larger than the box
You want to use the marker or pencil to amendment measurements, Get 2 CM length And 6 CM width
Step 4: Cut It
Now cut the piece, And make another one to make a cover of the case
Use Step 2 But now you no need use to cover of coloring pencil box, You need to use the leather piece that you cut it and draw a line using the edge of piece
Step 5: Divide the Piece to the Number of Colors
I have Derwent Artist 36 box, That mean I have 36 pencil
Divide the leather piece to 36 column use the ruler and marker or pencil
You have a piece like picture 2
Step 6: Divide the Piece to Put Rubber
I use the rubber to hold the pencils, draw another lines in the leather piece cross the piece
Step 7: Making a Hole
make a hole the insert the rubber into it, make a hole in the lines you draw in previous step, Use scissor to make it, Be carefully don't make the hole big
Step 8: Insert the Rubber
Insert the rubber into the leather piece, use the ZigZag style
Step 9: The Style
You have this style (In the picture), You have 2 sides to put the pencils into it
Step 10: Insret Pencil Encoding
As I said before I use Derwent artist, This type of pencils use coding, Each pencil has a special coding, Use the marker to write the coding of the pencil
Step 11: Done !
Use the second piece of leather to maker a cover of the case and some rubber to get a style
Done !
    • Paper Contest 2018
      Paper Contest 2018
    • Trash to Treasure
      Trash to Treasure
    • Pocket-Sized Contest
    Nice pencil holder. Do the pencils usually stay in place or do they ever fall out?
    No its stay, but you should pull the rubber strongly
