3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Leather Didgeridoo
Leather Didgeridoo
A didgeridoo made out of leather and sealed with epoxy.
Leather is a great material for first-time didgeridoo builders, because it's relatively easy to obtain, not too expensive (especially if you keep an eye out for sales) and doesn't require any expensive tools or prior knowledge.
You should expect to spend around 10-12 hours on this project, although it can be done in 6-8 hours after you have already made a couple.
The initial cost for all of the materials and tools is around $200 and you'll have enough materials to make at least 2 didgeridoos, maybe 3. The cost per didgeridoo, excluding tools and re-usable materials, is around $50 - $75.
I got started crafting didgeridoos out of leather because I don't have the know-how, tools or space needed to make "split and hollow" didges out of dried logs, and I don't live somewhere with a ready supply of yucca or agave stalks. After some brain-storming and searching, I found a guy that makes leather didgeridoos ( Marko Johnson ) which inspired me to try my hand at it.
I've made a variety of styles of leather didgeridoos. Hand stiched, "triangle", "triangle spiral", sectional, and the simple "wrap and epoxy" style which I will describe in this instructable. I've added some pictures of some of the other styles of leather didges that I've made, if you're interested.
After a while of building leather didgeridoos, I got interested in the physics of didgeridoos, especially in the area of how the bore shape affects the playability and sound of the didge. I did some reading in some acoustic journals, and eventually made a program to calculate what is called the "acoustic impedance" of a didgeridoo with an arbitrary circular bore shape. I've recently created a user-friendly interface and released the code as open source. You can get it here.
One of the great things about this method of making didgeridoos is that it is relatively easy to construct the didgeridoo so that it has specific bore dimensions. This appeals to me because it allows me to design a didgeridoo before hand, using my DidjImp program, and then build the didge and see how it sounds. This allows me to experiment with different designs and learn more about how to make a didgeridoo with specific playing characteristics.
I hope you find this instructable useful. If you do make a leather didge using these instructions, I would love to hear about it! And I would love to hear any feedback you have.
Note: Some of the images are hard to see at the small size shown on the page. I've uploaded full size images, so you can click on the "i" buttton at the top left of the image and choose to view the original image which will be a lot larger.
Step 1Tools and materials
Here are the tools needed:
Razor/Utility knife - $4-$9
For cutting out the leather. My favorite is this
Yard stick - $5
The metal ones are the best. The cheap wooden ones tend to be not very straight. Ideally it should have millimeter markings (1/32in works too, if you prefer the "English" system.)
"2 yard" yard stick (optional) - $15
Again the metal ones are best. The markings aren't important. This is only used in the first step, to draw a long straight line. You can use the "1 yard" yard stick instead, or anything else with a long, straight edge.
Carpenter's square or similar - $5
It's best if it has millimeter or 1/32in markings. If not, you can use the yard stick to measure instead.
Hack saw or PVC pipe cutter (optional) - $4
This is needed if you are going to build a PVC frame
And the materials that that are needed:
1 Leather hide - $90
You want a thick vegetable tanned hide, at least 12oz or so. Tandy's cheap 13-15oz saddle skirting works well. This will be enough leather for at least 2 didges, possibly 3.
Epoxy (at least 12-14oz) - $20
You can buy 64oz of the "Klear Koat" epoxy here for $20 (not including shipping), or you can find a 16oz kit of Envirotex Lite in some local hardware stores for around $20. Other types/brands of "tabletop/bartop epoxy" would probably work too. You'll use around 12-14oz of epoxy per didge, so if you buy the Klear Koat you should have enough for several didges.
Fumed Silica (Optional) - $3.50
Used to thicken the epoxy for the final outside coat.
Latex gloves - $10
For working with epoxy
Pencil - $1
Ye olde wooden pencil
Pencil sharpener - $1
Any cheap pencil sharpener will do
Elastic Medical Bandages - $10
You have a couple of options here. You can get a regular "ACE" type bandages, either the self-stick kind, or the kind with the little metal fastener things. You can reuse this type of bandage, assuming you don't get much epoxy on them. These are $2 a piece for a 2" wide bandage, which is an easy size to work with. You can get a wider bandage, but it's a bit harder to keep "flat" while you wrap it on the didge. You'll need around 5 2" bandages or possibly fewer if you use a wider bandage.
You can also buy woven cotton bandages in bulk for pretty cheap, but they're not as re-usable. They tend to get stretched out after a couple of uses.
String - $3 (or $25)
Used to draw the curve at the wide end, and also to hang the didgeridoo from the PVC frame while epoxying. You can probably use cheap cotton string which you should be able to find at walmart on the cheap (froogle.com says $3 or so). However, I like to use a type of string called "lacing tape", which comes in either nylon or polyester (among other materials). It is a flat, braided string, is quite strong, and holds a knot very well. I use this stuff for *everything*. It's around $25 for a 500 yard spool, but it's a bit hard to find. The good thing is that 1 spool will last a long long time. The place I got it from last time isn't selling it any more unfortunately. After a bit of a search, it looks like you might be able to get it here. Either nylon or polyester is fine. You want size 3, with the synthetic rubber finish. White is cheaper, but you can get black if you want :)
Masking Tape - $4
Used to hold the string in place while drawing the curve at the wide end, and also to help seal the mouthpiece end of the didge when epoxying the inside. You don't want to use duct tape or packaging tape, because the tape will stick to the leather too much and damage the leather when you peel it off. I use 3M's blue masking tape.
Plastic Drop Cloth - $3
This is used while working with epoxy, to prevent it from getting on the floor.
3 Plastic graduated mixing container - $1.50 total ($.50 each)
To mix the epoxy
1 package of mixing sticks - $2
To mix the epoxy
Silly Putty - $1
To help seal the end of the didge when epoxying the inside
1 plastic grocery bag - $0
Used to seal the end of the didge when epoxying the inside
Optional - if you want to build a PVC frame to help hold the didge while you
epoxy the inside and outside.
4 10' long 1-1/4" Schedule 40 PVC pipe - $4 each, $16 total
8 'T' connectors to fit above pipe - $1.50 each, $12 total
4 90 degree elbows to fit above pipe - $1 each, $4 total
Note: if you buy the Klear Kote epoxy from U.S. composites, you can order some fumed silica (aka aerosil-cabosil), graduated plastic tubs, wooding mixing sticks, and latex gloves from them at the same time.
Total Cost: $220 - Assuming that you have to buy everything that is listed. There's a good chance you will have some/most of the tools and materials already, and you can leave off some of the optional items to save a bit more. Most of the stuff can be re-used if/when you make more leather didges in the future.
24 comments
May 4, 2011. 9:56 PMbuilderkidj says:
Whats a didgerodoo?
Jan 24, 2012. 3:38 PMwilgubeast says:
Aboriginal wind instrument. Like a trombone without all the bends.
Sep 12, 2010. 11:57 AMCarved from Creation says:
superb dude
How do you use the didjImp program, I cant figure it out
thnx
Sep 12, 2010. 1:32 PMCarved from Creation says:
Nice one dude, many thanks
keep on didgin
TOOT
Jan 4, 2009. 7:09 PMVintiquities says:
I love this Instructable. Great job. I have a nephew that would love to have one of these. He learned how to play in elementary school and has kept going with it. He will be in High school soon. I think it will make a great present for him. Thanks so much!
Nov 20, 2008. 3:50 PMchariotmaker says:
Was able to make four didges from the hide from Tandy. Laced two and glued two before the epoxy. One doesn't have a good tone so am starting it over. Overall great instructions. My first one turned ot to be the best, the tone is incredible. Looks as good as any I've found on the internet sites. Also made one from a tree limb (I am a carpenter and furniture maker by trade) and it is too cool as well. Now making an ashiko drum. Thanks for your awsome instructions. Applause here. The Chariotmaker.
Dec 2, 2008. 2:23 PMchariotmaker says:
downloaded some pics of didges and boxes. Where they are is beyond me. Where do downloaded pics go?
Nov 22, 2010. 5:12 AMchariotmaker says:
I will take some pics soon and send them in along with some "boxes" I make on a bandsaw. They are pretty amazing. Thanks again. Dennis.
Jul 22, 2008. 3:54 PMFunkNattidelic says:
hey JesusFreke, your DidjImp program wont download properly to my computer. every time i download it and try to open the file, there is an error report. Is there anything i can do about this? Thanks
Jul 23, 2008. 1:10 PMFunkNattidelic says:
Maybe thats the problem, = P. ill comment back on whether it works or not.
Jul 23, 2008. 12:45 AMFreshPineSent says:
Awesome, but I prefer a PVC pipe with a straight fitting on the end. Ghetto 4 instruments 4 life.
Jul 21, 2008. 1:39 PMFunkNattidelic says:
is there any other adhesive that i could use? i have a large bottle of wood glue in " the lair " ( my good friend benny101 calls my basement the lair) and i was wondering if it would work. Also, i have some stuff that looks like leather left over from my Bagpipes, but it is actually Naugahyde, also known as upholstery vinyl. would that be okay to use?
Jul 22, 2008. 10:15 AMFunkNattidelic says:
ahh ok. thanks for the info. = )
Jul 21, 2008. 12:32 PMalexsolex says:
Hi I bought my first didgeridoo in an ugly shop (a stupid not dried bamboo tube that broke a couple of days after I got it...) Then I saw it was only a "tube", so I made some of my own using PVC pipes and making some shapes by heating some places on the tube. Then I bought a real one, made of eucalyptus and traditionnaly curved out by termites. Then I had the awesome chance to build my own when I went to Australia with an aboriginal man. (went to the forest, check for the good tree, cut it, and finishing it by hand) I made my mind how to build my own here in France with no termites and no eucas... I thought to many ways but never ever thought about making it using leather and epoxy ! Very interesting way ! I wish I could see one of yours to check the sound ! Good job
Jul 21, 2008. 11:31 AMmasterochicken says:
pure awesomness
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
5
Author:JesusFreke
