3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Leather Didgeridoo
Step 3Determine the bore dimensions
The first step is to figure out what shape of bore you want to build. In general, you want a small enough mouthpiece that you can play easily (1.25" to 1.5" diameter or so), and a gradual taper towards the end.
You can use my DidjImp program to help design the bore. You enter the bore dimensions, and then you can see what note that didge will play.
Here are the dimensions for the didge that I will be building in this article. The first column is the distance from the mouthpiece, and the 2nd column is the diameter of the bore at that location.
0m (mouthpiece) - 30mm
.628m - 40mm
1.256m - 60mm
1.78m - 100mm
This didgeridoo should play a "D" (73hz)
1 comment
Sep 12, 2010. 11:57 AMCarved from Creation says:
superb dude
How do you use the didjImp program, I cant figure it out
thnx
Sep 12, 2010. 1:32 PMCarved from Creation says:
Nice one dude, many thanks
keep on didgin
TOOT
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
5
Author:JesusFreke
