Introduction: Leather Guitar Strap
Picture of Leather Guitar Strap
Watch project videos from Weaver Leather Craft Supply here.
Project Summary: We’ll show you how to make a beautiful leather guitar strap with supple water buffalo leather, ¼" nickel spots and a crisp belt buckle set. Complete with beveled and grooved edges and an adjustment on the back, this is a leather guitar strap that combines both form and function.
Approximate Time to Complete: 2 hours
What You’ll Need:
  • #2200 Double Cap Rivets, Nickel Plated, 1/4" (02200-NP-1/4)
  • Deluxe 4P Snap & Rivet Setter (65-6275)
  • Fiebing's® Leathercraft Cement (50-2124)
  • Skife Knife (3025)
  • Paper
  • Pencil
Step 1: Begin to Make Buckle Strap Billet Pattern
To make the buckle strap billet pattern, start with a piece of pattern paper cut to 1" x 14". Draw in a center line lengthwise and make a mark at the center of that line (7" from both ends). This line will be the center of the keeper.
Step 2: Make Marks 5/8" on Both Sides of Keeper Line
On the center line make a mark at 5/8" to the left and 5/8" to the right of the keeper line.
Step 3: Mark Rivet Holes
Picture of Mark Rivet Holes
Starting with either mark, measure away from the keeper line 2 ½" and mark. Make a second mark 1 ¼" past this mark. These four holes will be rivet holes to secure the buckle and keeper.
Step 4: Draw Oblong and Round End
Picture of Draw Oblong and Round End
Draw in a 1 ¼" Oblong punch between the two center rivet holes (center in the 2 ½" spread) and draw in a round end punch on one side or the other roughly 3/4" away from the last rivet hole.
Step 5: Mark Pin Hole and Round End
Picture of Mark Pin Hole and Round End
Working away from the end with the round end punch make a mark at 5" from the last rivet hole and mark this as a “Pin Hole ¼"” on the pattern so we know we need a specific size hole. Draw in a Round End punch 1" further on this end of the pattern (giving us a tab on the outside of the pin hole).
Step 6: Begin to Make Tongue Strap Billet Pattern
To make the tongue strap billet pattern, take a piece of pattern paper cut to 1" x 12" and draw a center line lengthwise. From one end or the other, make a mark at ¾" in from the end of the pattern paper and one more mark at 1 ¼" further in. These will be the rivet holes to secure the strap to the main body.
Step 7: Mark 5 Size Holes
Picture of Mark 5 Size Holes
From this second rivet hole, measure 2" and mark. This will be the first of five “size” holes, so mark four more holes at 1" increments working away from the two rivet holes.
Step 8: Mark Buckle Tip
Picture of Mark Buckle Tip
And for the last mark on the tongue strap make a mark 1 ½" past the last size hole. This will be the center mark for the buckle tip.
Step 9: Make 2 ½" Round and English Point Template
Picture of Make 2 ½" Round and English Point Template
When going to the main body and extension patterns, we’ll need a 2 ½" round and English point; however, those sizes of tools are not readily available, so we’ll make a template. Take a 2 ½" wide (same as main body width) piece of paper approximately 8" long and draw a center line lengthwise. Fold this in half lengthwise, and on the edge away from the fold make a mark 1 ¾" in from the end on both ends.
Step 10: Cut English Point on Template
On the first end, draw a line in from the end of the pattern on the center line, or fold, to the point 1 ¾" on the outside edge, and make this line similar to half of an arrowhead. This will create an English point. Cut this while still folded to get a symmetrical point.
Step 11: Cut Round End on Template
Picture of Cut Round End on Template
On the other end, draw a rounded line in from the end of the pattern at the center line, or fold, to the 1 ¾" mark on the outside edge and cut while still folded. You can use a can of paint or glue to make this as circular as possible. This will be the round end punch on the template.
Step 12: Measure for Guitar Strap Length
Picture of Measure for Guitar Strap Length
Before moving to the main body, we need a size for the full length of the guitar strap. To get a good measurement, take a tape measure and wrap it around you or the recipient and measure from, roughly, 4" above the waist line, over the shoulder and around to the bottom of the back pocket. These instructions are for a 51", but, when following these instructions, any length can be made easily.
Step 13: Begin to Make Main Body Pattern
To make the main body pattern, take a piece of paper 2 ½" wide by roughly 48" long (more than enough for this size strap) and draw in a center line lengthwise.
Step 14: Mark English Point on Main Body Pattern
Starting on either end, lay the English point side of the template on the end of the pattern and draw in the English point.
Step 15: Mark Rivet Holes on Main Body Pattern
Picture of Mark Rivet Holes on Main Body Pattern
From this end of the pattern, make a mark at 1" and then at 1 ¼" beyond that hole on the center line. These will be the rivet holes to secure the buckle tongue onto the main body.
Step 16: Place Tongue Strap Pattern on Main Body Pattern
Picture of Place Tongue Strap Pattern on Main Body Pattern
Take the tongue strap and lay it on top of the main body so the rivet-hole marks coincide with the rivet-hole marks on the main body with the tip pointing away from the body.
Step 17: Lay Buckle Strap Pattern on Tongue Strap Pattern
Picture of Lay Buckle Strap Pattern on Tongue Strap Pattern
With the tongue strap lying on the body, take the buckle strap and fold it in the middle of the oblong just like we were adding a buckle. Lay the folded edge on the third size hole with the pin hole away from the main body.
Step 18: Make a Mark at Your Size
Picture of Make a Mark at Your Size
With these two billets lying in place, take a Straight Edge or tape measure and make a mark 51" on the center line of the main body away from the billets/English point end. This is where the sizing is easy to measure. Just lay out the billet patterns first, and measure from the pin hole to the other end at whatever size is needed.
Step 19: Mark a Mark 1 ½" Past Your Size Mark
Circle the mark at 51" and write “¼" hole.” From this mark and away from the main body, make a mark at 1 ½" out. This will be the end of the strap.
Step 20: Create Extension Piece Pattern
While still working with this end of the main body strap, cut a piece of paper to 12" x 2 ½", draw in a center line, and lay this extension piece next to this end of the main body pattern starting 1 ½" to 2" past the pin hole and extending towards the main body.
Step 21: Mark ¼" Hole on Pattern
Picture of Mark ¼" Hole on Pattern
The pin hole on the main body will be cut off and replaced with the pin hole on the extension, so with a Steel Square make a mark on the extension parallel to the pin hole on the main body and circle with “ ¼" hole.”
Step 22: Draw Lines on Pattern
Working away from the end of the pattern, draw a line 2" from the pin hole across both pattern pieces. Draw a second line 1 ¼" from that line. On the extension only, draw 3 more lines at 1 ¼" increments. Note: You can extend the extension with more lines, but for now we should have five lines and a pin hole on the extension.
Step 23: Mark Round End and English Point on Patterns
Picture of Mark Round End and English Point on Patterns
On the main body pattern, make a mark 1 ½" past the pin hole and away from the main part of the body. Drop in the template and mark your round end. On the extension, measure 1 ½" from the pin hole, away from the main part of the extension, and make a mark for an English point. On the opposite end of the extension, use the template to draw in a rounded end.
Step 24: Mark Patterns for Chicago Screws
Picture of Mark Patterns for Chicago Screws
To mark for the Chicago screws, draw in a line ½" in from each side to cover the two lines on the main body and the five lines on the extension. Circle these intersections. We should have four circles marked on the main body and 10 holes plus the pin hole marked on the extension.
Step 25: Cut Ends of Patterns
Picture of Cut Ends of Patterns
Cut the round and English point ends on the main body and the extension patterns.
Step 26: Mark Main Pattern for ¼" Nickel Spots
Picture of Mark Main Pattern for ¼" Nickel Spots
To mark for the ¼" nickel spots, return to the main body pattern and, on the center line, make a mark 2" from the inside rivet hole on the end with the English point. Continue to mark at 2" increments along the center line, and stop just short of the Chicago screw holes on the other end. For good pattern maintenance, mark these holes in red to denote that we “mark” the leather and do not punch a hole.
Step 27: Cut Straps
Picture of Cut Straps
With a Wooden Strap Cutter, or by hand, cut a 2 ½" strap for the main body and extension, and cut two 1" straps for the billets to match each pattern length.
Step 28: Mark and Punch Leather Pieces
Picture of Mark and Punch Leather Pieces
With an Awl, mark from the pattern to the leather for the pin holes, Chicago screw holes, oblong hole, rivet holes and the end cuts. Punch and cut each of four pieces on your Poly Cutting Board using your English Point Punch, Round Strap End Punch, ⅛" Belt Punch for rivet holes, 3/16" Belt Punch for Chicago screw holes, ¼" Belt Punch for pin holes, Oblong Punch and Rawhide Mallet.
Step 29: Make Slit for Pin Holes
Picture of Make Slit for Pin Holes
To make the slit for the pin holes, remember to cut away from the stress. Using your Knife, on the buckle strap cut an approximately ¾" slit from the pin hole and away from this end/towards the buckle and keeper. On the extension pieces, make the cut away from the English point and towards the Chicago screw holes.
Step 30: Bevel and Groove Leather
Picture of Bevel and Groove Leather
With your Edger and Groover, set at ⅛" to 3/16", bevel and groove all sides on all four pieces.
Step 31: Set Spots
Picture of Set Spots
From the main body pattern, mark the main body strap for spots. On your main body strap, set a Spot at each mark using your Spot Setter. Gently bend the Spot tines that poke through the back of the leather inward, flip the leather back over, and tap each spot with a Polyhead Mallet on your Tooling Slab.
Step 32: Assemble Buckle Strap
Picture of Assemble Buckle Strap
Assemble the buckle strap with the Keeper and Buckle with two Rivets.
Step 33: Add Buckle Tip
Picture of Add Buckle Tip
To add the Buckle Tip, lay the tip on the end of the buckle strap and make a mark with an Awl on the strap at the left and right side of the top of the tip (away from the point). Trace the edges of the tip to the point. Using your Knife, make a ⅛" cut in the left and right edge of the strap where we have marked for the top of the tip. From this cut, make a cut ⅛" inside of the line we have traced for the tip edge. You may have to trim further to make the Buckle Tip fit snuggly, but, that’s what we want. Tightly screw in the one, or two, screws that come with the buckle set into the back of the tip. Sand off the excess. Note: If the leather is too thick, skive down the tip area with a Skife Knife until the tip fits tightly.
Step 34: Set 2 Rivets
Picture of Set 2 Rivets
Using the two rivet holes on the main body, use your Rivet Setter to set two Rivets to connect the tongue strap to the main body.
Step 35: Add 4 Chicago Screws
Picture of Add 4 Chicago Screws
On the opposite end of the main body strap, add four Chicago Screws in the four holes inside of the pin hole.
Step 36: Connect Leather Pieces
Picture of Connect Leather Pieces
With the main body strap lying face down on your work surface, place the extension piece onto the Chicago Screws face down and with the pin hole away from the middle of the body. IMPORTANT: When the proper adjustment is found, add a dab of white glue to the screws. (A light glue is best. We just need these to stay where they are, but we also need to be able to remove them to adjust the sizing.)
Your guitar strap is now complete!
About This Instructable
1,141views
14favorites
License:
Bio: With over 40 years in the supply business, Weaver Leather has developed a reputation for bringing you top quality leather, hand tools, hardware, machines and ... More »
More by weaverleathercraftsupply:Leather Guitar StrapLeather Feather EarringsLeather Tassel Keychain
Add instructable to:
