Leather Hoaning Block
2,234
35
Posted
Introduction: Leather Hoaning Block
How you going guys this is my very first instructble so pardon my explanations and try to follow along. leave some feed back or some info would be much appreciated
Have fun and keep tinkering :)
I decided to make a small hoaning block for when I'm out hunting in my bag and after doing a couple of skins the blade goes dull, I seen a friend hoan on his boot but I thought it looked a bit awkward so I came up with my idea
Step 1: Start
The things I have used (not all pictured) and all you really need is
1 pair of welding gloves new or used I was lucky enough to get a new pair others wise you can pick them up from a hard ware shop for like $8 no name brand
2 of those little super glues you get from the HW shop
1 pair of scissors
1 marker black or blue
1 ruler
A length of wood your choice mine was about 150 mm long buy 85 mm wide buy 20 mm thick
Step 2: Mark It Out
Pretty easy just grab a glove I used the top side either is fine grabbed my peace of cut up wood the traced it with my marker, added about 5mm around the out line (to fold down the wood) I then used a pair of scissors nothing special just a normal pair pierced a whole in a spot and cut away
Step 3: Adding the Wood Plus Leather
So I took my leather cut out layed it flat with the marker marks on the side getting glued so it looked neater
Then I added some glue and quickly put my wood on it flipped it over and used a flat wood worker pencil to smooth it out did both sides then let it dry
Step 4: Last Bit
I don't have a photo but with the excess leather hanging over I folded it down then used somthing to rub it hard to look neat then used a couple of small nails to hold it down
Step 5: End
So the end result is a flat little leather block that seems to work well after I sharpen a knive on my stone I then proceed to hoan it on my block wich works well ( the way IV been shown)
So thanks for the read guys much appreciated again if you've got tips share up or a picture of your end result don't be afraid to ask a question :))
    • Microcontroller Contest
    • Spotless Contest
      Spotless Contest
    • Science of Cooking
      Science of Cooking
