Leather Spiked Cuff From Scratch
4,982
10
Posted
Introduction: Leather Spiked Cuff From Scratch
Hello everybody, this is my first Instructable. I've enjoyed this site for several years now, and I guess it's about time I give back to the wonderful community here.
I am an international student currently studying in China, and a die-hard metal head. Being a metal head in a conservative place such as China means that I have to be a lot more creative with making accessories for myself, such as spike cuffs, band t-shirts, and so on. So I have to get very creative with a limited range of supplies (and a limited Chinese vocabulary), and I think that has honed my creative skills for the greater good, despite the countless number of times I've superglued my fingers together while making things. ;)
Here I will show you how to make a leather spike cuff from scratch, using leather and some studs that you might have lying around.
Step 1: Things You Will Need
Things you will need for making your own spiked leather cuff:
- Thick Leather, any color you like (either ask for scraps from your local leather shoesmith, rip up an old leather bag, use leather sofa samples, or simply buy some online. The leather I used was 1.2mm, but I still double-layered the cuff)
- Studs and/or spikes (I bought mine online, you do not have to use the same design as mine, feel free to come up with your own!)
- Needle and strong thread (make sure your needle is strong and not too flimsy, it is hard to push the needle through the thick leather)
- Snap Buttons (mine are sew-on snap buttons, cause I had a lot of trouble with the ones that you had to hammer in)
- Scissors (You need VERY, VERY SHARP ones if you want to cut leather in a straight, clean line. It is best to use a new pair, or one that is reserved for cutting leather and fabrics)
- Pliers (for bending back the prongs on the studs)
- Large thick leather needle (I am not sure of the proper name for this, but I know that it is very useful for poking holes through leather)
- Razor or craft knife (for scoring a line on your leather and when you need to trim little bits of leather)
- Screwdriver (for helping to affix the spikes)
- Superglue (for gluing the leather together)
Not pictured:
- Ruler (not pictured, but you will need this for drawing and scoring straight lines)
- Gel ink pen (not pictured, for marking on your leather, make sure you can rub this off the leather!)
A WARNING ABOUT SUPERGLUE: Please use a good quality brand of superglue. In the picture I've attached are two brands of superglue that I tried using. The cheap Chinese brand exploded and leaked all over my fingers when I gingerly squeezed it out on some leather scraps and it was absolute heck to get off. For the sake of your fingers, please use a good brand of superglue. The skin on your fingers will thank you for this. It is not good to get superglue on your fingers, and when trying to get it off you might rip off the skin on your hands in the process (trust me, I know...)
That being said, accidents do happen. If you do get superglue on your hands, pour acetone-based nail polish remover over the affected areas ​immediately. Your fingers will be unstuck, but there will still be dried superglue residue on your skin. Be very careful when scraping this off, try not to take your skin away with it. Keep pouring nail polish remover.
Do not use cotton swabs to wipe it off. Superglue and cotton do not mix together and they can react and heat up.
Be careful with the razor, and if you use a bare one like I did, wrap the end up in lots of tape to protect your skin from the sharp and narrow edges.
Step 2: How the Spiked Cuff Is Laid Out
This diagram I drew should be clear enough for you (those cones are spikes, the smaller cones are the studs), but if you have any questions I have included a brief explanation of the cuff layout.
There are two layers to this spike cuff, the top layer, which you can see, and the bottom one. These two layers are superglued together to add strength and durability to the cuff. It is attached by snap buttons which are sewn on. The pronged studs and male half of snap button are attached to the top layer, and the female half of the snap button and the screw of the spikes go through the bottom layer.
Why two layers? And why this odd attachment of studs and buttons and two layers of leather?
This is to give the spike cuff a seamless look, so that the pattern of studs and spikes flow together without an awkward button in the way. Where the female half of the snap button is, above it is a stud. When the cuff is worn you will not see any buttons, just the studs.
The studs are attached to the top layer because the prongs were not long enough to go through to the bottom layer. Likewise, the spikes go through both layers because the screws were too long to go through just one layer. It was more snug with two layers of leather instead.
Step 3: Cut the Leather Strip
Measure your wrist, making sure to have allowance for where the buttons will go. Decide how wide you want your cuff to be.
With a gel ink pen (make sure you can rub this off the leather later!) and a ruler, draw the outline of your cuff lightly on the shiny side of the leather with your measurements.
I made this for my friend Jean, so I used his measurements.
Place the ruler on the lines you drew, and use your razor or craft knife to score along the lines. Make sure your blade is perpendicular and cutting the leather at a 90 degree angle. You do not want to end up with a cuff with slanted, scruffy edges.
Then use your scissors to cut the leather out, again making sure to cut at a 90 degree angle, and cut out along the scored lines.
It is vital you make the edges of your leather straight and at 90 degrees. It would look very awkward later when you glue it on the other piece of leather and the edges aren't matching up. This is why I scored the lines with a razor first, partially cutting straight through the leather makes it easier for my scissors to follow a straight line.
(Also, in the background you can see a thin wristband with stars on it. With that wristband I cut the edges only with scissors, and ended up with a wonky, wiggly side. :( Not very professional looking...)
Step 4: Figure Out the Layout of Your Spikes
Now roughly arrange your studs and spikes in the order and design that you want. Have fun with this! Come up with a combination and design that you like. I find it handy to make a quick little sketch of my design. Remember this combination! For the next step you'll need to knock these all off in order to attach the buttons. So don't be too precise with this.
Have your snap buttons ready for the next step.
Step 5: Attaching the Button
Now first off, we will attach the male half of the snap button.
Mark the placement of the button carefully.
Now, with your needle, make holes on the markings. This is to help with ease of sewing later. The leather is hard to push a needle through. I recommend you use pliers to help you pull the needle through (be careful not to pull it to hard and poke yourself in the eye though) or use a thimble to protect your thumbs.
Sew the button. I will have another Instructable later that will explain the details of how I sew the buttons. But it's really simple. Make stitches through the holes and to the leather. Go over your stitches again for added strength. The button is the most stressed part of the cuff and will go through a lot of wear and tear, so it pays off to have sewn with strong thread and with strong, durable stitches.
Step 6: Marking the Placements of Your Spikes
Now arrange your studs and spikes back on to the leather strip. This time, though, take into account the spacing and try and arrange them equally. Use a ruler to help you. You may need to do a little math. (I measured the whole length of the leather strip and divided them by the number of studs/spikes and the button I had, so in the end I had an estimate of how far apart each spike/stud should be from each other.)
Mark the placement of your studs. I marked the placement of the studs by lightly pressing them pronged-side down on the leather, so that the prongs leave a little indent. Then I used my pen to go over that indent as a guide for me to arrange them later.
Now we will prep the spikes and make holes for the screws. Mark where your spikes will go and the hole for where the screw will come through the leather and attach to the spike.
Step 7: Punching Holes and Checking the Fit of the Screws
Use the big needle and poke holes through the spots where you marked. Be careful not to poke yourself, it's really easy to do so when fighting to get the needle through the leather.
Then put the screws through the holes. Use the needle to make the hole bigger if you must, but try not to be too forceful and rip the leather. This is so that you can check that the holes you have made are big enough for the screws.
Step 8: Attaching Pronged Studs
This is very easy, and one of my favorite parts. :D
Place the studs on the markings you have made earlier. Press the stud through the leather. Be careful of the points of the prongs, they can cut skin if you are too rough with them. Then, using something with a hard, flat edge, bend back the prongs under the leather back in on itself. The points of the prongs should now be embedded into the leather.
For the next step, remove the screws. Keep the studs on. You are going to glue the whole thing down on another piece of leather.
Step 9: Glue the Leather Strip on Another Piece of Leather
Now glue the leather strip on the piece of leather that you had originally cut out from. If you had cut it in a straight line, the edges of the strip should match up with the edges of the cut leather.
Glue everything, but DO NOT GLUE THE END OF THE LEATHER STRIP WHERE THE STUDS END. You may glue the end of the strip where the male snap button is, but do not glue the opposite end! You will sew the female snap button to the underlying leather strip, so please do not glue this area. Refer to the pictures to see where I am talking about if you are not sure.
Hold the edges together with binder clips while it dries. Bear in mind that the binder clips may leave an indent in the leather if left for too long, though.
Step 10: Poking Holes and Attaching Screws Through the Bottom Layer of Leather
Now you see the holes you poked for your spikes/screws earlier? Using your needle, poke holes through the holes you have made earlier through the bottom layer of leather. Then you may put the screws in. Again, be careful with the needle. You may get frustrated pulling it through, it's okay, but be careful not to pull too hard and rip the leather or poke yourself.
When putting the screws in, don't just push them in, make a twisting motion with them so that it goes into the holes snugly.
Step 11: Cut the Leather Strip Out
You should now have a nice double-layered strip of leather, screws and studs attached. Carefully cut it out with scissors or a sharp razor. Just like when you were cutting out the leather earlier, cut the leather at a ninety degree angle so you get nice edges for your cuff.
Be very careful not to cut through the top layer of leather as you are cutting.
Step 12: Marking the Placement of the Female Snap Button
Now we will attach the other half of the snap button. We need to line up the buttons very carefully, so that we don't end up with a cuff that doesn't overlap the other edge properly when it is worn.
Affix the female snap button temporarily to the male one. Fold the whole cuff over into a circle, with the end that you have not glued over the buttons. Make sure the overlapped edges line up nicely. Press the point of the buttons into the leather -  hard. This is so you make a visible indent in the leather so you can have an easier time attaching the female button accurately. Then before the indent fades, mark it with your pen. The pictures can explain better than I can, please refer to them if you are not sure.
If you don't do this and simply sew the buttons anyhow, you will end up with a cuff that does not overlap properly, with one edge partially overlapping the other and the rest sticking out over your wrist.
Step 13: Sew the Female Half of Button on and Glue the Leather Above It
Remove the female button from the male and place it on the marking you have made. Now sew it, but only through the bottom layer of leather, not the top! (Besides, there is a stud in the way on the top part of the leather - this is on purpose) Don't worry if your sewing looks messy from the back, as long as it's strong, it won't matter. You will conceal the stitching anyway.
When the button is firmly sewn in place, glue the edges of the leather down around it. Hold in place with binder clips.
Step 14: Fine-tuning the Edges
When I curled the cuff around, I found that the edges of the cuff were not glued down properly and so it kind of scrunched up on itself. This is easy to fix, just add more glue on the edges. It is a bit more fiddly though trying to get the nozzle of the superglue into the small space, I should have glued it more thoroughly earlier. Pay attention to the corners since they are the most likely places to become unstuck with wear and tear.
It is worth noting that superglue makes the fuzzy side of the leather really hard and scratchy and dark, so try not to get it there. The fuzzy side of the leather will very quickly soak the superglue up, so it is best to place glue on the shiny side of the leather.
You can use a razor to trim down the edges if they are not quite lined up properly.
Step 15: Adding the Spikes
Get out your spikes and twist them on to the screws. You can use a screwdriver to help you tighten the screws.
Step 16: Done! Wear Your Cuff!
It is finally done! Put it on and enjoy. :D
This was the first spike cuff I handmade myself, and when I was done I kept it on the whole day not wanting to take it off. :D But I made this as a gift for my friend Jean, for his birthday, so I gave it to him. He seemed to like it, so that was satisfaction enough. :D
Hopefully anybody who wishes to make a spiked cuff out of simple materials and methods can learn from my tutorial. :) If you do make one of your own, please post a photograph, I would love to see how yours turned out. :D
Now looking back, perhaps to improve the design of the cuff, perhaps you could use a heavy-duty sewing machine to make decorative stitching around the edges, and perhaps buff the edges of the leather. I would have done this if I could, but I don't have a sewing machine and I do not know how to buff leather edges. Maybe another time. :D
Thank you for taking the time to read this! Comments would be very much appreciated!
    • Trash to Treasure
      Trash to Treasure
    • Spotless Contest
      Spotless Contest
    • Pocket-Sized Contest
