Introduction: Leather Steampunk Top Hat
If you've got some basic leatherworking know-how and need a spiffy hat for your steampunk getup, give this one a try. It took me 3 hours of construction and alteration on day 1, and 2 hours dyeing and finishing on day 2.
Step 1: Materials
From your leatherworking tool kit:
rivet setter
hammer
knife or rotary cutter
cutting mat
rulers
leather hole punch
marking pencil
Supplies:
LEATHER (I used a cheap-ass utility hide I bought off a sale rack because the price was too good to ignore.)
Dye and a dauber
20 or so rivets
mink oil
leather finish
bailing wire
AND either a good quality sewing machine (I used my home sewing Viking machine, but it's got a great motor) or leather stitching supplies for hand sewing (ick)
rivet setter
hammer
cutting mat
rulers
leather hole punch
marking pencil
Supplies:
Dye and a dauber
20 or so rivets
mink oil
leather finish
bailing wire
Step 2: Take Measurements
I measured the interior height of an old hat, and around my fiancee's head.
Step 3: Cut Your Brim
If you're not real confident about your pattern drafting skillz, do this on paper first. I started by cutting the hole in the brim to the same circumference as the head measurement. It should be an oval. Then, I traced the outside edge, adding 3/4" for hem allowance.
Step 4: Cut the Top
I wanted a very dramatic curve on the side band, so I make the top oval much larger than the hole in the brim. Don't forget to add 1/2" for seam allowance.
Step 5: Cut Your Side Band
The sideband starts as a rectangle 2 1/2 inches taller than the hat height you decided on before. The hat I measured was 7 1/2 inches deep, so I cut a 10" high rectangle. The rectangle should be the same length as the circumference of the hole in the brim.
Step 6: Making Waves
This is where we hack up the rectangle to give us that dashing profile and steamy look. The "high" parts of the wave are the front and rear, the low parts are the side. Next, cut it in half to make room for the triangle inserts on the sides.
Step 7: Finish Cutting
Cut your triangle inserts. Cut them big; this lets us adjust things as we go. Here are all your parts, ready for assembly!
Step 8:
Sew the flat part of the sides to the top piece. Center them on the long part of the oval. Next, sew the inserts to the top to cover the gaps. DO NOT sew the inserts to the sides. Pull the brim over the sides and sew it on. Make sure to line your long points of the ovals up. Roll the outer edges of your brim over and hem, inserting the bailing wire as you go. I used a zipper foot. Go SLOWLY.
Step 9: Rivet in the Inserts.
Carefully mark and punch your rivet holes where your sides overlap your inserts. Set your rivets.
Step 10: Steam Some Shape Into It!
I have a big Jiffy Steamer in my basement, but for little stuff like this my electric teakettle works just fine. Hold a small section of the hat over the steam for 20 seconds, then remove and bend the hat into the desired shape as it cools. Repeat until the hat has the desired shape.
Step 11: Dye It!
I originally wanted to airbrush the dye on, but Matt wanted it darker so I used a fully saturated dauber instead.
On a side note, if you KNOW you want to use a dauber, dye first, then steam. You'll loose some shape when you dye.
Select an appropriate finish for your needs. I chose a heavy coating of mink oil.
I let it sit overnight, then buffed off the excess mink oil.
Step 12: All Done!
The completed hat. STEAMY!
