3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Leather iPod Touch Case using Water!
Step 3Stitch it
Stitch it
Now that its dry we need to sew the two sections together.
Take the awl (or other pointy thing) and go around the edge of your case, making a hole roughly every 5 mm, keeping about 2-3mm away from the edge of the mould.
Once this is done, you now need to sew. Thread up your needle, i used a nice red thread, and clamp the leather so that the hole remained lined up (trust me, this makes it alot easier)
The best way to stitch is to use two needles, then pass them through the same hole in opposite directions, this gives you a continuous stitch all the way around. You can manage this with one needle by doing a running stitch, then going back on yourself filling in the gaps.
Once you have gone all the way around, tie off the end, then glue the ends inside the case using a small dab of glue. Now is a good time to double check the fit of your case.
1 comment
Jun 13, 2011. 7:28 PMshawa1 says:
Would it be easier to stick when wet?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
589
Author:gmjhowe(gmjhowe graphic design)
I am a British Graphic Designer, when I am not working I spend my time making an array of projects, from electronic instruments and chessboards to cyberpunk rifles and steampunk props. If you have an...
more »
